[GRASS-windows] g.mremove fails when used with wildcard in WinGRASS-6.4.0-1 on windows 7
Luigi Ponti lponti at inbox.com
Tue Sep 14 10:05:51 EDT 2010
Dear list,
WinGRASS-6.4.0-1 on Windows 7;
wxgui g.mremove called on vector with * wildcard does not work:
(Tue Sep 14 15:24:09
2010)
g.mremove -f
vect=map*
Removing vector <mapBloomday_Olive_11set10_Avg>
Unable to delete file
'C:\cygwin\home\andy/latlong/luigi/vector/mapBloomday_Olive_11set10_Avg/hist'
couldn't be removed
<mapBloomday_Olive_11set10_Avg> nothing removed
(Tue Sep 14 15:24:10 2010) Command finished (0 sec)
wxgui g.mremove called with full vector name works fine:
(Tue Sep 14 15:27:01
2010)
g.mremove -f
vect=mapBloomday_Olive_11set10_Avg
(Tue Sep 14 15:27:01 2010) Command finished (0
sec)
There was only that vector map starting with map* in current location.
Deleting rasters with g.mremove works fine both ways.
Trying same test with an old (May 29) WinGRASS-6.4.svn installed on the
same machine;
Wildcards work:
(Tue Sep 14 15:49:46
2010)
g.mremove -f
vect=map*
(Tue Sep 14 15:49:47 2010) Command finished (1 sec)
I have created a ticket for this.
Kind regards and thanks for any pointer,
Luigi
More information about the grass-windows mailing list
