[GRASS-windows] Fwd: Re: mapcalc/mapcalculator in python script
Johannes Radinger
JRadinger at gmx.at
Thu Feb 3 11:19:23 EST 2011
Hello,
I posted the same problem already at the GRASS-user list, but
I think here is the better platform:
my Problem is that I run WinGRASS 6.5SVN and want to use
the grass.mapcalc function in python but it doesn't work.
I am running excactly:
> grass.mapcalc("$upstream_shreve = if(${upstream_part},${shreve})",
> upstream_shreve = options['upstream_shreve'],
> upstream_part = options['upstream_part'],
> shreve = options['shreve'])
and according to users this code should work but it doesn't. I get following answer from the python shell:
File "C:\Users\XY\Documents\Pyhton Scripts\test3.py", line 40, in <module>
sys.exit(main())
File "C:\Users\XY\Documents\Pyhton Scripts\test3.py", line 32, in main
KeyError: 'upstream_shreve'
does anyone know what the problem is? It is assumed that it is a bug...
all other grass.run_commands are working...it's just the mapcalculator...
I'm somehow bound to 6.5 as there is also the r.stream.* module integrated in the install-package.
thank you
cheers
johannes
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
More information about the grass-windows
