[GRASS-windows] RE: Compiling WINGrass
    Johannes Radinger
    JRadinger at gmx.at
    Thu Nov 10 11:32:18 EST 2011
> > login in http://trac.osgeo.org/grass/wiki/CompileOnWindows with your
> > osgeo-id, scroll down the long page,
> > there is a "Edit this page"-button.
> thank you! I'll update the lines in the wiki ...
As promised I did some minor updates in the wiki about the mentioned
things...
Does anyone have any idea about the problems I face when I want to compile?
My errors are in
> > Errors in:
> > /osgeo4w/usr/src/grass-6.5.svn/lib/python
> > /osgeo4w/usr/src/grass-6.5.svn/gui/icons
> > /osgeo4w/usr/src/grass-6.5.svn/gui/images
> > /osgeo4w/usr/src/grass-6.5.svn/gui/wxpython/scripts
and what does the output mean when I run make:
> Johannes Radinger at JOHANNES /osgeo4w/usr/src/grass-6.5.svn/lib/python
> $ make
> make: *** No rule to make target `|', needed by
> `/osgeo4w/usr/src/grass-6.5.svn
> /dist.i686-pc-mingw32/etc/python/grass/script/core.py'.  Stop.
Thank you very much for your help.
Hopefully I'll finish this project to compile GRASS on windows soon.
cheers,
Johannes
> > >m.nviz.image.exe System Error
> > >MSVCR90.dll missing ... please install it...
> > see
> > http://lists.osgeo.org/pipermail/grass-dev/2011-October/056249.html
> > [GRASS-dev] Re: compiling wingrass (branches, trunk) - problems with
> > missing msvcrt90.dll
> I found that and went back to an older version of libtiff as recommended.
> > RETUREN to continue....
> > >Redirection is not supported.
> > have you more than one python installed at your box?
> Yes there is a python26 folder which is used by arcgis.
> My main python is 2.7 which is in c://pyhton27. This is
> also the python which should be used by the GRASS as there
> are all the addtional python packages I need in my scripts.
> The python26 is only for ArcGIS (will be hopefully deinstalled
> in future)
> > please have a look in your log-file:
> > Started compilation: Thu Nov  3 09:00:36 CEST 2011
> > Errors in:
> > In case of errors please change into the directory with error and run
> > 'make'.
> > If you get multiple errors, you need to deal with them in the order they
> > appear in the error log.  If you get an error building a library, you
> will
> >  also get errors from anything which uses the library.
> After downgrading to the old libtiff, make distclean etc. and reconfigure
> and compile (no problems anymore with the msvcrt90.dll etc.) I got the same
> 4 error in the error.log.
> Thus I changed into the first directory and just typed make. Thats what I
> did and get:
> $ make
> I don't know what that means? Is it as simple as to just type make?
> best regards,
> Johannes
> NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
> End of grass-windows Digest, Vol 61, Issue 5
More information about the grass-windows
