[GRASS-windows] Re: Compiling WINGrass 7.0SVN
Johannes Radinger
JRadinger at gmx.at
Thu Oct 13 05:05:27 EDT 2011
Hi again,
of course I can help with improving the wiki. I just got the login
and now I have to find out how I can add/remove/change the text in the
compile-grass-for-windows page...
Your hint with copying the content from the subfolder helped.
What I did now was:
Copying the content of the subfolder: bin, share, include and lib
into the same folders of C:/OSGeo4W. In some cases there where already files in the parents folders with the same name. In such cases I skipped
the copying of these files.
I run the configure/compile process again... and I got a new output, so it seems the flex/lex is now at the place where it should be (no problem anymore)
Now my new problem is with the external Proj.4. I got following error in the package.log (the last lines):
checking for iconv in -liconv... no
checking for iconv in -lgiconv... no
checking for libiconv... no
checking for libiconv in -liconv... yes
checking for socket... no
checking for socket in -lsocket... no
configure: warning: *** Unable to locate socket() function.
checking for location of zlib includes...
checking for zlib.h... yes
checking for location of zlib library...
checking for deflate in -lz... yes
checking for location of External PROJ.4 includes...
checking for proj_api.h... yes
checking External PROJ.4 version... 480
checking for location of External PROJ.4 library...
checking for pj_get_def in -lproj... rm: cannot lstat `conftest.exe': Permission denied
no
configure: error: *** Unable to locate External PROJ.4 library.
I found http://trac.osgeo.org/proj/ where it is possible to download a windows prebuilt executable. I didn't proceed yet as I don't know if proj.4 has to be installed also a special way within the osgeo4w folder...
As there isn't anything stated in the wiki, I'd guess that the installation and how to of proj.4 should be added.
Thank you
Johannes
> Message: 4
> Date: Wed, 12 Oct 2011 10:46:40 -0700 (PDT)
> From: Helmut Kudrnovsky <hellik at web.de>
> Subject: [GRASS-windows] Re: Compiling WINGrass 7.0SVN
> To: grass-windows at lists.osgeo.org
> Message-ID: <1318441600074-6886005.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> >have a look at
> http://trac.osgeo.org/grass/wiki/CompileOnWindows#Pre-builtBinaries
> >=> "flex from here"
> >maybe this dependency wasn't unzipped in the same way as the other ones
> in
> >C:\OSGeo4W\bin ?
> I've added now some information in the wiki
> /"Unpack all to c:\osgeo4w (the content of the several sub-folders in the
> zip-files - i.e. bin, include, share, etc ... - should be copied into the
> related sub-folders of c:\osgeo4w)" /
> please help to improve the wiki if something is missing there.
> Helmut
> http://osgeo-org.1803224.n2.nabble.com/Re-Compiling-WINGrass-7-0SVN-tp6880311p6886005.html
> Sent from the Grass - Win mailing list archive at Nabble.com.
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
More information about the grass-windows
