[GRASS-windows] Compiling WINGrass - MinGW problem
Johannes Radinger JRadinger at gmx.at
Mon Oct 31 06:15:17 EDT 2011
Hello,
sorry for my late response.
I tried to follow your suggestion and renamed the MinGW folder (which
was created some other time ago, I don't need it and should get rid of it)
Probably this folder is causing my problems.
After renaming the folder I tried to compile GRASS 7.0 (newest revision from today) in Mysys.
I get following error logs:
package.log:
Mon Oct 31 09:30:26 CEST 2011: STARTING remove old logs
Mon Oct 31 09:30:26 CEST 2011: FINISHED remove old logs AFTER 0s
Mon Oct 31 09:30:26 CEST 2011: STARTING configure
checking host system type... i686-pc-mingw32
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... no
configure: error: installation or configuration problem: C compiler cannot create executables.
config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:749: checking host system type
configure:772: checking for gcc
configure:876: checking whether the C compiler (gcc  ) works
configure:892: gcc -o conftest    conftest.c  1>&5
gcc.exe: installation problem, cannot exec `cc1': No such file or directory
configure: failed program was:
#line 887 "configure"
#include "confdefs.h"
main(){return(0);}
This is a different error from the error before (I can reproduce the old erorr by renaming the MinGW folder to the original name). So it seems it is an error associated the older MinGW installation.
I found the environmental variable C:/MinGW/bin in the PATH. So I removed it and even restarted the computer but there is no difference - still the same problem.
To ensure that it isn't a problem with the GRASS source I also tried to compile GRASS 6.5 but I get the same error as in GRASS 7.0.
How should I proceed? What should I check? Is there any other thing like environmental variables which is pointing to my old MinGW?
best regards,
Johannes
> Message: 1
> Date: Tue, 18 Oct 2011 18:29:10 +0200
> From: Helmut Kudrnovsky <hellik at web.de>
> Subject: Re: [GRASS-windows] Re: Compiling WINGrass 7.0SVN
> To: Johannes Radinger <JRadinger at gmx.at>,	Glynn Clements
> 	<glynn at gclements.plus.com>
> Cc: grass-windows at lists.osgeo.org
> Message-ID: <e87d1e9c-e478-422f-bf91-7df953b9205b at email.android.com>
> Content-Type: text/plain; charset=UTF-8
> some remarks belief
> >Before I want to uninstall/reinstall MinGW some questions:
> >1) There is a C://MinGW directory existing. I don't know if that was
> >created by the Osgeo4W setup resp. the procedure according to the
> >wiki. It is also possible that this is from older trials (I think some
> >months
> >ago a procedure with installing MinGW etc. was mentioned somewhere, and
> >I followed but stopped because it seemed to complicated for me)
> >So this can be also old remainings (the C://MinGW folder)  which may
> >conflict.
> >If it is the caseof old and maybe interfeering remainings, how can they
> >be uninstalled?
> >I ask this as there is no possibilty for me in windows to uninstall it
> via
> >the Control Panel -> Programs and features.
> I can't remember that this MinGw-folder is created by osgeo4w. If there is
> no uninstall, I would rename it first and see if there's something broken.
> if not, just delete the folder.
> >2) @Glynn: How can I uninstall and reinstall MinGW correctly in Windows?
> Via
> >the Osgeo4w installer? If yes which parts?
> >There are these three parts according to the wiki, and all of them were
> >downloaded
> >last week.
> >  * *mingw32-make* from here
> <http://downloads.sourceforge.net/mingw/mingw32-make-3.81-20080326-3.tar.gz>
> >  * *mingw-runtime* from here
> <http://downloads.sourceforge.net/mingw/mingwrt-3.15.2-mingw32-dev.tar.gz>
> >  * *mingw-utils* from here
> >    <http://downloads.sourceforge.net/mingw/mingw-utils-0.3.tar.gz>
> >3) @ Helmut: All the files are now copied. Copied folders are merged and
> >in case of already existing files the were replaced. I did that now
> >again for
> >all manually downloaded packages (msyscore.....w32api,bison...readline).
> >So according to the wiki everything should be in place. But that doesn't
> >solve the configure problem. Still the same error.
> I can't reproduce it here. Maybe there are some updated versions of these
> files. have you tried the latest ones?
> Helmut
> grass-windows mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-windows
> End of grass-windows Digest, Vol 60, Issue 16
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
More information about the grass-windows mailing list
