[GRASS-windows] Creating Python scripts that call GRASS functionality from outside (UNCLASSIFIED)
    Glynn Clements
    glynn at gclements.plus.com
    Fri Dec 21 13:40:19 PST 2012
Brian Sanjeewa Rupasinghe wrote:
> I checked the file but it is not available in drive C: However, GRASS works.
> On Fri, Dec 21, 2012 at 7:57 PM, Gade, David SWT
> <David.Gade at usace.army.mil>wrote:
> > '.grassrc6'
The normal location for GRASS 6.x on Windows is:
	%APPDATA%\GRASS6\grassrc6
On Windows 7, a typical setting for %APPDATA% is
	C:\Users\<username>\AppData\Roaming
The file needs to contain settings for GISDBASE, LOCATION_NAME and
MAPSET. GRASS_DB_ENCODING may need to be set for vector modules.
More information about the grass-windows
