[GRASS-windows] Creating Python scripts that call GRASS functionality from outside (UNCLASSIFIED)
    Glynn Clements
    glynn at gclements.plus.com
    Sat Dec 22 05:39:26 PST 2012
Brian Sanjeewa Rupasinghe wrote:
> Thanks. It is found in  C:\Users\<username>\AppData\Roaming. However the
> file name is grassrc6 and not .grassrc6.
> Is it ok?
Yes.
It doesn't matter what the file is called, so long as %GISRC% points
to it and it contains the necessary settings.
More information about the grass-windows
