[GRASS-windows] syntax for v.db.select run by grass.run_command
Liu, Huili HLiu at ap.org
Tue Mar 13 10:32:35 EDT 2012
Hi Markus,
I am running GRASS GIS 6.4.1 (Windows).
Thanks,
Willie
-----Original Message-----
From: grass-windows-bounces at lists.osgeo.org [mailto:grass-windows-bounces at lists.osgeo.org] On Behalf Of Markus Neteler
Sent: Monday, March 12, 2012 7:27 PM
To: Liu, Huili
Cc: grass-windows at lists.osgeo.org
Subject: Re: [GRASS-windows] syntax for v.db.select run by grass.run_command
On Fri, Mar 9, 2012 at 3:46 PM, Liu, Huili <HLiu at ap.org> wrote:
> Thanks Markus. That is a great example to generate a report.
> DBF driver doesn't support for join tables
No because DBF is really only a table format.
> so I have to add a color column in the table to shade polygon. But
> grass.run_command('v.db.addcol', map='from_shape', columns='WINNER_COLOR, VARCHAR()') requires awk. After I installed awk, it still show the same error. awk is in environment variable and ran fine by cmd. Not sure if it is a bug on Windows.
It will be some path problem... Do you use GRASS 6 or 7?
(maybe I forgot).
Markus
grass-windows mailing list
http://lists.osgeo.org/mailman/listinfo/grass-windows
The information contained in this communication is intended for the use
of the designated recipients named above. If the reader of this
communication is not the intended recipient, you are hereby notified
that you have received this communication in error, and that any review,
dissemination, distribution or copying of this communication is strictly
prohibited. If you have received this communication in error, please
notify The Associated Press immediately by telephone at +1-212-621-1898
and delete this email. Thank you.
[IP_US_DISC]
msk dccc60c6d2c3a6438f0cf467d9a4938
More information about the grass-windows mailing list
