[GRASS-windows] viewshed integration
Brian Sanjeewa Rupasinghe
jinkabs at gmail.com
Sun Jan 6 10:26:35 PST 2013
Hi all,
I am going to calculate cumulative viewshed analysis by adding each
viewshed result of several observer locations
with r.mapcalc using Python. Observer locations are read from a file.
GenerateViewshed method is executed inside the Iterate
File method (see the methods below). When i execute this it fails create
the output with following errors:
ERROR: Sorry, <r> is not a valid flag
ERROR: Sorry, <o> is not a valid flag
ERROR: Sorry, <u> is not a valid flag
ERROR: Sorry, <t> is not a valid flag
ERROR: Sorry, <p> is not a valid flag
ERROR: Sorry, < > is not a valid flag
ERROR: Sorry, <=> is not a valid flag
and in the command console
Command 'd.rast map=brian at PERMANENT' failed
Details: Unknown display driver <cairo>
The name of the output file i gave is brian which is referred by parameter
routput in GenerateViewshed method. Any idea on the errors??
Cheers, Brian
----Python code-------------
def IterateFile(infile):
i=0
for line in fileinput.input(infile):
values = string.split(line,",")
pid = values[0]
print pid
e = values[2]
print e
n = values[1]
print n
z = values[3]
print z
GenerateViewshed(e,n,1.5,25,i)
i = i + 1
def GenerateViewshed(x,y,oelv,th,i):
grass.run_command('r.viewshed', input = rinput, output = 'viewshed',
coordinate = [x,y], obs_elev = oelv, tgt_elev = th, memory = 4098,
overwrite = True, quiet = True)
if i==0:
grass.run_command('r.mapcalc', 'routput = viewshed + 0', overwrite
if i>=1:
grass.run_command('r.mapcalc', 'routput = viewshed + routput',
URL: <http://lists.osgeo.org/pipermail/grass-windows/attachments/20130106/efc73359/attachment.html>
More information about the grass-windows
