[gvSIG-devel] Errors with gvSIG 2.4.0
Mario Carrera mcarrera at gvsig.com
Fri Jan 11 03:50:59 PST 2019
Hi Heinz,
welcome again to the gvSIG project. The current 2.x versions are much
more stable and with more functionalities than the old gvSIG 1.x versions.
About your problems:
1) It seems a persistence error, wherethat the piechart symbology is not
saved where you save a project. You can send us the gvSIG.log file, that
contains information about the error. Here you can see how to get it:
https://blog.gvsig.org/2015/06/17/what-to-do-when-we-get-an-error-in-gvsig/
2) It has been fixed for the next version:
https://redmine.gvsig.net/redmine/issues/4833
Now you can use this tool: Open the table, and then go to Table->Add
measure->Add X and Y.
It's easier than using field calculator, and it will add 2 new fields
with X and Y coordinates. It's working on gvSIG 2.4.
Best regards,
   Mario
El 10/1/19 a las 0:31, Heinz Mundhenk escribió:
> After Years using QGIS i switched back (better forward ?) to gvSIG because
> many WIN-Aplications with WIN7 have problems with the C++-Runtime-Libs
> since WIN10 was born. So QGIS !
> My problems with gvSIG now
> (1) Trouble with PieChart symbolised - Layer *when saving the project*
> (2) the FieldCalculators *x() - Function* delivers y-values.
> I am Using gvSIG 2.4.0.2850 final Desktop for 64Bit AMD
> and UNIX MINT 19.1. Both with german surface.
> Details see attched *screenshot* (Error-Log,
> where can i find the hole log-file ?).
> Test with the attached *shape-file*, if you want.
> Projection is 25832 (UTM, Middel- Europe).
> Heinz Mundhenk
> gvSIG-Desktop-Devel mailing list
> gvSIG-Desktop-Devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gvsig-desktop-devel
*Mario Carrera*
Asociación gvSIG
http://www.gvsig.com <http://www.gvsig.com/>
Antes de imprimir este e-mail piense bien si es necesario hacerlo.
AVISO LEGAL: Este mensaje y sus archivos adjuntos van dirigidos
exclusivamente a su destinatario, pudiendo contener información
confidencial sometida a secreto profesional. No está permitida su
comunicación, reproducción o distribución sin la autorización expresa de
la Asociación gvSIG. Si usted no es el destinatario final, por favor
elimínelo e infórmenos por esta vía.
PROTECCIÓN DE DATOS: De conformidad con lo dispuesto en las normativas
vigentes en protección de datos personales, el Reglamento (UE) 2016/679
de 27 de abril de 2016 (GDPR) y la Ley Orgánica (ES) 15/1999 de 13 de
diciembre (LOPD), le informamos que los datos personales y dirección de
correo electrónico, recabados del propio interesado o de fuentes
públicas, serán tratados bajo la responsabilidad de la /Asociación gvSIG
/para el envío de comunicaciones sobre nuestros productos y servicios y
se conservarán mientras exista un interés mutuo para ello. Los datos no
serán comunicados a terceros, salvo obligación legal. Le informamos que
puede ejercer los derechos de acceso, rectificación, portabilidad y
supresión de sus datos y los de limitación y oposición a su tratamiento
dirigiéndose enviando un mensaje al correo electrónico a info at gvsig.com
<mailto:info at gvsig.com>. Si considera que el tratamiento no se ajusta a
la normativa vigente, podrá presentar una reclamación ante la autoridad
de control en www.agpd.es <http://www.agpd.es/>.
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20190111/9eb19444/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20190111/9eb19444/attachment.jpe>
More information about the gvSIG-Desktop-Devel mailing list
