[gvSIG-devel] Errors with gvSIG 2.4.0
Mario Carrera
mcarrera at gvsig.com
Mon Jan 14 01:40:07 PST 2019
Hi Heinz,
yes, it seems that there's a problem saving projects with pie or bar
legends. I've opened a ticket at the bugtracker:
https://redmine.gvsig.net/redmine/issues/4961
We'll try to fix it in the next versions.
Best regards,
Mario
El 11/1/19 a las 17:17, Heinz Mundhenk escribió:
> Hi Mario,
> the xy-problem was solved with "Add mesaure", thanks.
> The piechart-save-project-error could reproduced with a new projekt
> and a new shape-file.
> Try it yourself.
> Everthing you want and need is attached.
> Greetings
> Heinz
> *Gesendet:* Freitag, 11. Januar 2019 um 12:50 Uhr
> *Von:* "Mario Carrera" <mcarrera at gvsig.com>
> *An:* gvsig-desktop-devel at lists.osgeo.org
> *Betreff:* Re: [gvSIG-devel] Errors with gvSIG 2.4.0
> Hi Heinz,
> welcome again to the gvSIG project. The current 2.x versions are much
> more stable and with more functionalities than the old gvSIG 1.x versions.
> About your problems:
> 1) It seems a persistence error, wherethat the piechart symbology is
> not saved where you save a project. You can send us the gvSIG.log
> file, that contains information about the error. Here you can see how
> to get it:
> https://blog.gvsig.org/2015/06/17/what-to-do-when-we-get-an-error-in-gvsig/
> 2) It has been fixed for the next version:
> https://redmine.gvsig.net/redmine/issues/4833
> Now you can use this tool: Open the table, and then go to Table->Add
> measure->Add X and Y.
> It's easier than using field calculator, and it will add 2 new fields
> with X and Y coordinates. It's working on gvSIG 2.4.
> Best regards,
> Mario
> El 10/1/19 a las 0:31, Heinz Mundhenk escribió:
> After Years using QGIS i switched back (better forward ?) to gvSIG
> because
> many WIN-Aplications with WIN7 have problems with the C++-Runtime-Libs
> since WIN10 was born. So QGIS !
> My problems with gvSIG now
> (1) Trouble with PieChart symbolised - Layer *when saving the project*
> (2) the FieldCalculators *x() - Function* delivers y-values.
> I am Using gvSIG 2.4.0.2850 final Desktop for 64Bit AMD
> and UNIX MINT 19.1. Both with german surface.
> Details see attched *screenshot* (Error-Log,
> where can i find the hole log-file ?).
> Test with the attached *shape-file*, if you want.
> Projection is 25832 (UTM, Middel- Europe).
> Heinz Mundhenk
> gvSIG-Desktop-Devel mailing list
> gvSIG-Desktop-Devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gvsig-desktop-devel
> *Mario Carrera*
> Asociación gvSIG
> http://www.gvsig.com <http://www.gvsig.com/>
> Antes de imprimir este e-mail piense bien si es necesario hacerlo.
> AVISO LEGAL: Este mensaje y sus archivos adjuntos van dirigidos
> exclusivamente a su destinatario, pudiendo contener información
> confidencial sometida a secreto profesional. No está permitida su
> comunicación, reproducción o distribución sin la autorización expresa
> de la Asociación gvSIG. Si usted no es el destinatario final, por
> favor elimínelo e infórmenos por esta vía.
> PROTECCIÓN DE DATOS: De conformidad con lo dispuesto en las normativas
> vigentes en protección de datos personales, el Reglamento (UE)
> 2016/679 de 27 de abril de 2016 (GDPR) y la Ley Orgánica (ES) 15/1999
> de 13 de diciembre (LOPD), le informamos que los datos personales y
> dirección de correo electrónico, recabados del propio interesado o de
> fuentes públicas, serán tratados bajo la responsabilidad de la
> /Asociación gvSIG /para el envío de comunicaciones sobre nuestros
> productos y servicios y se conservarán mientras exista un interés
> mutuo para ello. Los datos no serán comunicados a terceros, salvo
> obligación legal. Le informamos que puede ejercer los derechos de
> acceso, rectificación, portabilidad y supresión de sus datos y los de
> limitación y oposición a su tratamiento dirigiéndose enviando un
> mensaje al correo electrónico a info at gvsig.com
> <mailto:info at gvsig.com>. Si considera que el tratamiento no se ajusta
> a la normativa vigente, podrá presentar una reclamación ante la
> autoridad de control en www.agpd.es <http://www.agpd.es/>.
> _______________________________________________ gvSIG-Desktop-Devel
> mailing list gvSIG-Desktop-Devel at lists.osgeo.org
*Mario Carrera*
Asociación gvSIG
comunicación, reproducción o distribución sin la autorización expresa de
la Asociación gvSIG. Si usted no es el destinatario final, por favor
vigentes en protección de datos personales, el Reglamento (UE) 2016/679
de 27 de abril de 2016 (GDPR) y la Ley Orgánica (ES) 15/1999 de 13 de
diciembre (LOPD), le informamos que los datos personales y dirección de
correo electrónico, recabados del propio interesado o de fuentes
públicas, serán tratados bajo la responsabilidad de la /Asociación gvSIG
/para el envío de comunicaciones sobre nuestros productos y servicios y
se conservarán mientras exista un interés mutuo para ello. Los datos no
serán comunicados a terceros, salvo obligación legal. Le informamos que
puede ejercer los derechos de acceso, rectificación, portabilidad y
supresión de sus datos y los de limitación y oposición a su tratamiento
dirigiéndose enviando un mensaje al correo electrónico a info at gvsig.com
<mailto:info at gvsig.com>. Si considera que el tratamiento no se ajusta a
la normativa vigente, podrá presentar una reclamación ante la autoridad
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20190114/a915818a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20190114/a915818a/attachment.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20190114/a915818a/attachment.jpe>
More information about the gvSIG-Desktop-Devel
