[Gvsig_italian] Problema java su win7 x64
Damjan Gerl
damjan a damjan.net
Mer 3 Ott 2012 05:54:56 PDT
Salve! Ho installato l'ultima versione di gvSig (1.12.0) su un pc con
win7 x64. Funziona, perņ ha qualche problema nella conversione con le
librerie proj (allego log). E' un problema di java VM. Io ho installato
sia la versione 1.7 x64 sia la x32 ed anche la 1.6 x32. Perņ gvSig
sembrerebbe usare sempre quella x64. C'č qualche possibilitą per
lanciarlo oppure configurarlo che usi la JVM x32?
Grazie
Damjan G.
INFO main com.iver.andami.ui.fonts.FontUtils - Fonts configuration was not necessary
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Cannot find translation for 1.12.0 final
ERROR main com.iver.andami.Launcher - Unsatisfied plugin dependencyes.unex.sextante: org.gvsig.remotesensing
WARN main com.iver.andami.PluginServices - Cannot find translation for setting_up_event_queue
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.core
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.core.menus.ToolbarMenus...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.core.PreferencesExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.core.Consola...
INFO AWT-EventQueue-0 com.iver.andami.messages.NotificationManager - Se a?ade un listener al manager de notificaciones
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.core.StatusBar...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.About...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.IntializeApplicationExtension...
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - gvSIG version: 1.12.0 final (Build 1417)
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - gvSIG app exec path: C:\Program Files (x86)\gvSIG desktop 1.12.0
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - gvSIG user app home: C:\Users\damjan\gvSIG\
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - gvSIG extension path: C:\Program Files (x86)\gvSIG desktop 1.12.0\gvSIG\extensiones
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - gvSIG locale language: sl
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - OS name: Windows 7
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - arch:amd64
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - version:6.1
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - JAVA vendor: Oracle Corporation
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - version:1.7.0_07
INFO AWT-EventQueue-0 com.iver.cit.gvsig.IntializeApplicationExtension - home: C:\Program Files\Java\jre7
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayerOrderExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TOCImplementationExtension...
INFO AWT-EventQueue-0 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.fmap.swing.toc.TOCLibrary'.
INFO AWT-EventQueue-0 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.fmap.swing.toc.TOCLibrary'.
INFO AWT-EventQueue-0 org.gvsig.tools.library.AbstractLibrary - Initializing library 'org.gvsig.fmap.swing.impl.toc.TOCDefaultImplLibrary'.
INFO AWT-EventQueue-0 org.gvsig.tools.library.AbstractLibrary - PostInitializing library 'org.gvsig.fmap.swing.impl.toc.TOCDefaultImplLibrary'.
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ShalomExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewControls...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.MeasureExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewSelectionControls...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InfoToolExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.AddLayer...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.BasicSymbologyExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.CopyPasteExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ProjectExtension...
INFO AWT-EventQueue-0 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - *-----------------------------------------------------------------------*
INFO AWT-EventQueue-0 es.prodevelop.cit.gvsig.fmap.drivers.jdbc.oracle.OracleSpatialDriver - * Found the Oracle JDBC library! :) *
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExtDB_Spatial...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.SingleVectorialDBConnectionExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.AboutContributors...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.FFrameLegendExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RestoreViewInfoExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PaletteViewInfoExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Export...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PrintProperties...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PrintTable...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Print...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ShowTable...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewProjectWindow...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RemoveTableLink...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RemoveTableUnion...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.FiltroExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableRowsOperations...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableNumericFieldOperations...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableFieldOperations...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditPasteExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditCutExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditCopyExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableManageFields...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditRemoveRowExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditInsertExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditStartExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableEditStopExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.UndoTableExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RedoTableExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableOperations...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutCommandStackExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutUndoExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutRedoExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutGraphicControls...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.FFrameViewExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutInsertToolsExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutEditVertexExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutEditableControls...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.LayoutExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExportLayoutExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ClearSelectionExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ZoomToSelectExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewPropertiesExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ZoomPrev...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.geoprocess
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.geoprocess.manager.GeoprocessManagerExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.centerviewpoint
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.gvsig.centerviewpoint.CenterViewToPointExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.oracle_spatial
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.prodevelop.cit.gvsig.jdbc_spatial.NewOracleSpatialTableExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.prodevelop.cit.gvsig.jdbc_spatial.ExportOracleExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.crs
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.crs.JCrsExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.chartlegend
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.chartlegend.ChartExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.jdbc_spatial
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.jdbc_spatial.ExtJDBC_Spatial...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.datalocator
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.gvsig.datalocator.DataLocatorExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.addeventtheme
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.gvsig.addeventtheme.AddEventThemeExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.backup
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.backup.BackUpProjectExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.backup.AboutBackUpProjectExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.hyperlink
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.hyperlink.LinkControls...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.iconThemeBase
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.iconThemeBase.ExtensionIcon16Theme...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.selectduplicates
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.selectduplicates.DuplicateSelectionExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.help
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.help.HelpExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.layerLoadingOrder
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.layerLoadingOrder.SmartOrderExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from es.gva.cit.gvsig.catalogClient
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.gazetteer.GazetteerExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.catalog.CatalogClientExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.catalog.CatalogClientAboutExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.gva.cit.gvsig.gazetteer.DeleteSearchesExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.georeferencing
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.georeferencing.GeoreferencingModule...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.wcs
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wcs.WCSClientExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.installer.app.extension
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.installer.app.extension.execution.InstallPackageExtension...
INFO AWT-EventQueue-0 org.gvsig.installer.app.extension.BackportrHelper - BackportHelper inicialinig... (gvsig ver 1.12).
INFO AWT-EventQueue-0 org.gvsig.installer.app.extension.BackportrHelper - BackportHelper inicialzed.
INFO AWT-EventQueue-0 org.gvsig.installer.app.extension.BackportrHelper - defaultAddonsRepository = 'C:\Program Files (x86)\gvSIG desktop 1.12.0\gvSIG\extensiones'.
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from es.prodevelop.cit.gvsig.arcims
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.prodevelop.cit.gvsig.arcims.extension.ArcimsClientModule...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.extended-symbology
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.symbology.SLDExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.symbology.ExtendedSymbologyExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.dwg
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.geoprocessextensions
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.geoprocess.impl.RegisterGeoprocessExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.rastertools
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.rastertools.RasterModule...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.rastertools.GenericToolBarModule...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.sde
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.sde.ExtSDE...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.tableExport
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.tableExport.xls.ExportTableToExcelExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.tableExport.ExportTableToFileExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.scripting
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.scripting.ScriptingExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.tableSummarize
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.app.documents.table.summarize.TableSummarizeExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.quickPrint
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.iver.quickPrint.TemplateExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.i18n
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.i18n.extension.I18nExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.wms
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wmc.ExportWebMapContextExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wmc.ImportWebMapContextExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wms.WMSClientExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.cad
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.SplitGeometryCADToolExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.AutoCompletePolygonExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.PreviousSelectionExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.MatrixExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.SelectionGeometryExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ComplexSelectionGeometryExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.StretchExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InternalPolygonExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.JoinExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertPolygonExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertPolyLineExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertLineExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertMultiPointExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.InsertPointExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.MoveGeometryExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExploitExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.CADExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.TableCommandStackExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ViewCommandStackExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.RedoViewExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.UndoViewExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExportTo...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.StopEditing...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.StartEditing...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.CreateNewLayer...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.annotation
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.tools.annotations.labeling.SingleLabelingExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Annotation_ToolExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.Annotation_Extension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.gvsig.expressionfield
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.ExpressionFieldExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.copypastegeom
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.copypastegeom.PasteFeaturesExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.copypastegeom.CopyFeaturesExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.tableImport
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.tableImport.importfields.ImportFieldsExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.tableImport.addgeominfo.AddGeometricInfoExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.newgeoprocess
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.geoprocess.RegisterGeoprocessExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.quickInfo
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.quickInfo.QuickInfoToolExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.quickInfo.AboutQuickInfoExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.consecutivenumber
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.consecutivenumber.ConsecutiveFieldExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from es.unex.sextante
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteAboutExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextantePointCollectorExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteHelpExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteDataExplorerExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteAdditionalResultsExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteCommandLineExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteHistoryExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteModelerExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.unex.sextante.gvsig.extensions.SextanteToolboxExtension...
WARN AWT-EventQueue-0 com.iver.andami.plugins.PluginClassLoader - PluginLoaders[i] es nulo
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.selectionTools
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectByPolylineExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectByBufferExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectAllExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.SelectByCircleExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.selectionTools.AboutSelectionToolsExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from es.udc.cartolab.gvsig.navtable
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.udc.cartolab.gvsig.navtable.NavTableExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from org.gvsig.gpe
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.gpe.GPEReaderExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.gpe.AboutGPEExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing org.gvsig.gpe.GPEWriterExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from com.iver.cit.gvsig.wfs2
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing com.iver.cit.gvsig.wfs.WFSClientExtension...
DEBUG AWT-EventQueue-0 com.iver.andami.Launcher - Initializing extensions from es.iver.derivedGeom
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.iver.derivedGeom.AddDerivedGeometrySHPExtension...
INFO AWT-EventQueue-0 com.iver.andami.Launcher - Initializing es.iver.derivedGeom.AboutDerivedGeomExtension...
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/sextante.gif'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/model.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/terminal.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/history.gif'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/chart.gif'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/documenter.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/help.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/bullseye.gif'
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Cannot find translation for Catch coordinates
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/view-quick-info-icon.png'
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin org.gvsig.centerviewpoint -- Cannot find translation for deberķa de estar activada
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.cit.gvsig.geoprocess -- Cannot find translation for deberķa de estar activada
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/table_refresh.png'
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.gvsig.addeventtheme -- Cannot find translation for deberķa de estar activada
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin es.unex.sextante -- Cannot find translation for SEXTANTE
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/oracle.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/binary.gif'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/Link.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/select-all-icon.png'
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/create-derivative-geometry-shape-icon.png'
WARN main com.iver.andami.PluginServices - Cannot find translation for creating_main_window
WARN AWT-EventQueue-0 com.iver.andami.iconthemes.AbstractIconTheme - Loading icon from resource: 'images/enabled.png'
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for core
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for copy-paste-features
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for SEXTANTE
INFO AWT-EventQueue-0 com.iver.andami.help.Help$DisplayHelpFromFocus - DisplayHelpFromFocus(id) id=Manual-usuario-gvSIG-1.10-Proyectos-de-gvSIG-Introdución
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for Project manager
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for Activate the window
DEBUG AWT-EventQueue-0 com.iver.core.mdiManager.NewSkin - Activando Project manager
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 153506 KB
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Cannot find translation for ArcSDE
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Cannot find translation for GPE
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 159340 KB
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for View properties
DEBUG AWT-EventQueue-0 com.iver.core.mdiManager.NewSkin - Activando View properties
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 95076 KB
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 100135 KB
DEBUG AWT-EventQueue-0 com.iver.core.mdiManager.NewSkin$FrameListener - Returns focus toProject manager
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for View : Untitled - 0
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 111848 KB
DEBUG AWT-EventQueue-0 com.iver.core.mdiManager.NewSkin - Activando View : Untitled - 0
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Execute command:
WARN AWT-EventQueue-0 es.prodevelop.cit.gvsig.arcims.gui.panels.ServiceNamesPanel - Property 'arcims-servers' not found in XML file.
DEBUG AWT-EventQueue-0 com.iver.andami.messages.NotificationManager - Application error. It's strongly recommended to close the application.
java.lang.UnsatisfiedLinkError: C:\Program Files (x86)\gvSIG desktop 1.12.0\CrsJniProj.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(Unknown Source)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.gvsig.crs.proj.JNIBaseCrs.<clinit>(JNIBaseCrs.java:78)
at org.gvsig.crs.CrsGT.getCrsProj(CrsGT.java:325)
at org.gvsig.crs.COperation.<init>(COperation.java:131)
at org.gvsig.crs.CrsGT.getCT(CrsGT.java:186)
at com.iver.cit.gvsig.AddLayer.checkProjection(AddLayer.java:162)
at com.iver.cit.gvsig.addlayer.fileopen.vectorial.VectorialFileOpen.createLayer(VectorialFileOpen.java:144)
at com.iver.cit.gvsig.addlayer.fileopen.MyFile.createLayer(MyFile.java:41)
at com.iver.cit.gvsig.addlayer.fileopen.FileOpenWizard.execute(FileOpenWizard.java:413)
at com.iver.cit.gvsig.AddLayer.loadGenericWizardPanelLayers(AddLayer.java:237)
at com.iver.cit.gvsig.AddLayer.addLayers(AddLayer.java:286)
at com.iver.cit.gvsig.AddLayer.execute(AddLayer.java:179)
at com.iver.andami.plugins.ExtensionDecorator.execute(ExtensionDecorator.java:89)
at com.iver.andami.ui.mdiFrame.MDIFrame.actionPerformed(MDIFrame.java:674)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.iver.andami.ui.AndamiEventQueue.dispatchEvent(AndamiEventQueue.java:58)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
WARN AWT-EventQueue-0 com.iver.andami.PluginServices - Plugin com.iver.core -- Cannot find translation for Information console
DEBUG AWT-EventQueue-0 com.iver.core.mdiManager.NewSkin - Activando Information console
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 155815 KB
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Memory usage 157930 KB
DEBUG AWT-EventQueue-0 com.iver.core.mdiManager.NewSkin$FrameListener - Returns focus toView : Untitled - 0
DEBUG AWT-EventQueue-0 com.iver.andami.ui.mdiFrame.MDIFrame - Execute command:SALIR
INFO AWT-EventQueue-0 com.iver.cit.gvsig.fmap.drivers.db.utils.SingleDBConnectionManager - Successfully closed all connections.
More information about the Gvsig_italian
