[Ica-osgeo-labs] Lidar Format Wars [Boldly] Creep Into Geospatial
Hogan, Patrick (ARC-PX)
patrick.hogan at nasa.gov
Sat Apr 25 09:07:09 PDT 2015
Martin and all of us,
There is no more important issue than the ability to communicate. Exchange of information, whether the medium or the data, should not be controlled by financial interests, otherwise we becomes slaves to those interests increasingly serving themselves, [chuckle] not unlike the circumstances we have today that here and now we try to repair with maximum integrity.
Fortunately we have a window of opportunity, albeit not a big one, but still a place where integrity for the principles we believe in have a chance to breathe fresh air and thrive. It is my opinion that OGC needs to pick up this banner and press for the principles on which that organization is founded, Open Geospatial Standards. OGC needs to step up to the plate and start swinging.
Martin has held the line for years and Adena Schutzberg has charted next steps with her "tips on how to approach geospatial media outlets to get them to run a story." http://blog.abs-cg.com/2015/04/lidar-format-wars-creep-into-geospatial.html
1. Identify and reach out to the publications of interest. Learn the process for submitting press releases and articles.
2. Write a press release. Nearly all GIS publications can and will post press releases the day they are submitted.
3. Write an opinion piece with a call to action for readers. Publish the piece on supporters' blogs or submit it as a guest editorial to technology and news sites.
4. Ask publications that write editorials to consider writing one on the topic.
Where is a good OGC when you need one?
-Patrick
From: Martin Isenburg [mailto:martin.isenburg at gmail.com]
Sent: Saturday, April 25, 2015 3:52 AM
To: standards at lists.osgeo.org<mailto:standards at lists.osgeo.org>
Subject: Re: [OSGeo-Standards] [OSGeo-Discuss] [Ica-osgeo-labs] [TC-Discuss] Open Letter for the need for Open Standards in LiDAR
Hello,
thank you all (and especially the board) for taking time to work on this.
Getting the issue into the media will take more effort than usual as mentioned in a discussion on the OSGeo board [1]. The IT portal "heise group" in Germany picked it up [2,3] after a German "open format" fan wrote a personal email to the editor about the story. Similarly the attention of other media [4,5] was awakened with personal effort (after the story had already broken on blogs, in mailing lists, and the German site).
[1] http://lists.osgeo.org/pipermail/board/2015-April/012720.html
[2] http://www.heise.de/newsticker/meldung/LIDAR-offenes-Dateiformat-LAS-in-Bedraengnis-2609710.html
[3] http://www.heise.de/newsticker/meldung/Lidar-Format-War-Geo-Softwarehaus-Esri-vs-Geo-Community-2615341.html
[4] http://www.itnews.com.au/News/402914,open-source-devs-in-uproar-over-esri-lidar-lock-in-plans.aspx
[5] http://www.spatialsource.com.au/2015/04/21/os-developers-concerned-over-new-esri-lidar-format/
But it will be hard to get wide geospatial media coverage. There seems to be an incredible hesitation to publish anything negative about a particular vendor no matter how "hot" the topic. The geospatial media outlets are well aware of the story but literally "refuse" to cover it.
This seems especially evident for "LiDAR news" - the most obvious place for this story to run - who blogged about every tiny little advance [1] [2] [3] [4] [5] [6] [7] of "Optimized LAS" or "zLAS" (aka the "LAZ clone") but did not run a single headline on the screaming controversy. If I were to approach this editor I think my request will be ignored or denied.
[1] http://blog.lidarnews.com/esri-announces-the-las-optimizer
[2] http://blog.lidarnews.com/faq-on-esri-las-optimizer
[3] http://blog.lidarnews.com/early-positive-reviews-for-esri-las-optimizer
[4] http://blog.lidarnews.com/esri-las-optimizer-updated-to-include-parallel-decompression
[5] http://blog.lidarnews.com/esri-las-optimizer-updated
[6] http://blog.lidarnews.com/esri-announces-beta-program-for-optimized-las
[7] http://blog.lidarnews.com/esris-zlas-io-library-now-available
There are some interesting thoughts by Adena Schutzberg who worked for a number of GIS publications. She picked up the story in her private blog [1] and added some tips on how to approach geospatial media outlets to get them to run a story. I have beem "too outspoken" on the issue to do this myself but getting media coverage is the next step.
Volunteers?
[1] http://blog.abs-cg.com/2015/04/lidar-format-wars-creep-into-geospatial.html
Regards and Thanks for your help in "keeping LiDAR open".
Martin @rapidlasso
On Mon, Apr 20, 2015 at 8:11 PM, Martin Isenburg <martin.isenburg at gmail.com<mailto:martin.isenburg at gmail.com>> wrote:
Michael talks about this tool:
The newest product of rapidlasso is an open source tool aiming to liberate LiDAR points locked-up in proprietary "Optimized LAS", a highly controversial, closed format with a *.zlas file extension. The new LASliberator comes as both, a DOS command line tool for scripting and with an easy-to-use graphical interface ...
http://rapidlasso.com/2015/04/20/new-lasliberator-frees-lidar-from-closed-format/
Martin
On Apr 20, 2015 9:54 AM, "Michael Gerlek" <mpg at flaxen.com<mailto:mpg at flaxen.com>> wrote:
After some of us raised concerns about ESRI's announcement, they clarified that their intended position was as Martin describes.
They clearly didn't (don't?) understand the *intent* of the Apache license and the term "open source". While perfectly legal, it was (and is) very misleading of them to use the term "open source" anywhere in that repo...
aside: They also say in that repo that "it's easy and free to convert between standard LAS and zLAS". Until Martin's new tool came out today, I don't believe that conversion could possibly be considered either "free" or "easy" :-(
-mpg
On Apr 18, 2015, at 9:25 PM, Martin Isenburg <martin.isenburg at gmail.com<mailto:martin.isenburg at gmail.com>> wrote:
Hello,
ESRI's github repository contain *no* source code, except a sample *.cpp file to show how to use their (Windows-only) binary dll and/or lib files. This is *not* open source in any sense of the word but an unusal of the Apache license. Below I quote someone whom I've dicussed this with:
It is allowed to use Apache License for binary-only software, but that is extremely rare that anyone does that, because it goes against the whole idea of "Open Source". It is only possible because Apache License is a so-called "permissive" license, whereas GPL, CDDL and other "copyleft" licenses will not allow such "source-less Open Source" non-sense:
See this section of the FAQ on the OSI site (Open Source Initiative):
http://opensource.org/faq#non-distribution
Also this Apache Foundation FAQ:
http://www.apache.org/foundation/license-faq.html#WhatDoesItMEAN
"[the Apache license] does not require you to include the source of the [..] software itself"
Regards,
Martin @rapidlasso
On Sat, Apr 18, 2015 at 1:51 PM, Cameron Shorter <cameron.shorter at gmail.com<mailto:cameron.shorter at gmail.com>> wrote:
Hi Martin,
Esri's reference below: https://github.com/Esri/esri-zlas-io-library states that the esri-zlas-io-library read/writes Optimized LAS, and is also Open Source, under the Apache license.
Does this mean that it is possible to reverse engineer the Optimized LAS format?
Would this open the possibility to integrate LASzip and Optimized LAS?
Thoughts?
Regards Cameron.
URL: <http://lists.osgeo.org/pipermail/ica-osgeo-labs/attachments/20150425/6765afb7/attachment.html>
More information about the ica-osgeo-labs
