[Inspire-data] Re: [inspire-foss-devel] State of INSPIRE with FOSS
(long)
Just van den Broecke
just at justobjects.nl
Mon May 2 08:42:31 EDT 2011
Markus, thanks for your extensive answer ! And good to see deegree
moving forward. In hinsight I may have sounded too negative in my
original mail. That was certainly not my intention. I see so many
opportunities for FOSS within INSPIRE, not only for the obvious reasons,
but also since INSPIRE is a lot about integration and standards in
constant flux, any product will need to be agile and reactive. So I feel
the various FOSS projects should stick together on this.
I have experienced that INSPIRE is very knowledge-intense, with lots of
nasty details that come up during implementation, in particular when
testing. So while we may have a diversity in products, there is a great
deal of commonality we can have at least in knowledge sharing and
user/integrator-involvement, maybe even at the code/config level like
common relational schemas and SLDs. Another area is "CITE-like" test
automation which was started in ESDIN.
I plan to be in Bolsena next month, and hope some of you are there as
well, so maybe we can move things further under the Italian sun.
best,
Just
On 28-04-11 21:57, Markus Schneider wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Just,
> sorry for the slow reply.
> Am 21.04.2011 12:20, schrieb Just van den Broecke:
>> - The way out: the inspire-foss project has always been geared on
>> multiple INSPIRE solutions, e.g. not just deegree-only, though this is
>> still a very strong solution for ETL+fast WFS serving. As said, part of
>> this mail is to clarify what I think is the current situation but also
>> to possibly get ideas from you. Others may think that INSPIRE is just a
>> nasty heavy beast designed top-down without any rational software
>> engineering constraints and will just fade away as so many
>> all-encompassing standards' frameworks that had no prior proven
>> implementation (remember the ISO 7-Layer OSI stack?). We may find
>> INSPIRE back in another format (OSM?). Basically this mail comes back to
>> what Jeroen Ticheler, Arnulf, Jo Walsh and others had already formulated
>> 2/3 years ago:
>> http://wiki.osgeo.org/wiki/INSPIRE and
>> http://wiki.osgeo.org/wiki/INSPIRE_data_experiments
>> I think we have come a long way since then and have proven/diverse
>> INSPIRE FOSS solutions though in various stages. I realize I have maybe
>> been too much focused on technique/software, loosing the bigger picture,
>> and that we need to have something more integrated both in organization
>> (OSGeo?) and in the software ("INSPIRE Stack" with component options).
>> If you got as far as here thanks for reading !
> I would like to comment on the status of deegree 3 components for
> INSPIRE and what to expect in the next months:
> 1. Download Services: In order to get a complete INSPIRE solution based
> on deegree 3, the following things need to be addressed:
> - - Relational/hybrid storage: Is happening right now. In the last weeks,
> I got AU, CP and AD themes (automatically) mapped to a relational schema
> (with every optional element and attribute). Both queries and
> transactions are working. I hope to be able to provide a demo (and
> possibly a screencast) next week. Note that the relational mapping can
> also be configured manually, so using deegree 3 WFS with custom
> relational schemas (e.g. the one created by ESRI) will be possible.
> - - WFS 2.0 / INSPIRE Download Service protocol extensions: No timeframe
> yet. Will probably be implemented this year, because of lat/lon's
> involvment in the INSPIRE portal.
> 2. View Services: deegree 3 WMS supports WMS 1.3.0 for quite some time.
> Original INSPIRE styles (Symbology Encoding) can be used out of the box
> to style the unmodified INSPIRE features. Things to be done:
> - - INSPIRE View Service protocol extensions: Not much to be done (as WMS
> 1.3.0 is already implemented). Probably a few weeks of work. Should also
> happen during the INSPIRE portal tasks.
> - - Performance: In order to compete with other solutions, profiling is
> needed. However, the WMS is already pretty scalable as it's based on a
> streaming architecture.
> - - Tiling: Support for tile caching needs to be done.
> 3. Discovery Services: deegree 3 CSW supports the ISO application
> profile together with INSPIRE extensions. The (BLOB-based) storage has
> recently been improved and some customer projects are currently being
> worked on that prove that the CSW scales to dozens of millions of
> records. Things to be done:
> - - Integrate CSW records with metadata configuration of deegree WFS / WMS
> and WPS
> 4. Transformation Services: deegree 3 WPS implements the WPS 1.0.0
> protocol and should be ready for INSPIRE. Things to be done:
> - - Add INSPIRE protocol extensions
> - - Implement required processes
> If all the above is finished, deegree inspireNode will provide a full
> suite of INSPIRE services. Alternatively, there's the option to combine
> deegree 3 with other (FOSS) products, such as GeoServer / MapServer and
> GeoNetworks. Once deegree 3 WFS can be configured to work on a
> relational schema usable by GeoServer, a possible scenario is to use
> deegree 3 for INSPIRE data access / management and GeoServer for fast
> map rendering.
> Any feedback / cooperation is very much welcome.
> Best regards,
> Markus
> P.S.: Just, feel free to post this mail to inspire-data (I am still not
> a member).
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk25xqkACgkQLM5hjXxU/E5UjwCgm/pW/JtRjBNOZPf+MwLN9GiD
> ursAni4/GvSu7SmbjN0gc0M//EE2IEqe
> =CMav
> -----END PGP SIGNATURE-----
More information about the Inspire-data
