[iTowns-dev] itowns2 release candidate discussion
Alexandre Devaux
Alexandre.Devaux at ign.fr
Wed Mar 15 03:21:03 PDT 2017
I forgot! let's discuss it directly here:
https://github.com/iTowns/itowns2/issues/272https://github.com/iTowns/itowns2/issues/272
Bests,
Alexandre Devaux
Chargé d'Etudes et de Recherche
Laboratoire MATIS, IGN
Tel: 01 43 98 85 73
De : Alexandre Devaux
Date d'envoi : mercredi 15 mars 2017 11:15
À : itowns-dev at lists.osgeo.org
Objet : itowns2 release candidate discussion
Hi all!
We are very close to launch a release candidate. Some important PR are still in work/test but one of the most important subject is now the API, which is in the middle of many discussions.
It seems we don't all (developers) have the exact same point of view for now:)
- As for now, iTowns leave access to a large part of the code as methods are usually not private. -> not good
- High level API is too messy and not generic enough. -> not good
We need to agree on the methods available from the API, usable for non professional users and coders but also protect method that should not be accessible directly.
A first proposition:
Remove ApiGlobe and replace it by a Viewer and a Map with generic methods.
Map could be plan, ellipsoidal or any other format.
Methods that should be in the High level api for the candidate release:
addImageryLayer / removeImageryLayer
addElevationLayer / removeElevationLayer
addFeatureLayer / removeFeatureLayer
setLayerVisibility
setLayerOpacity
moveLayerUp
moveLayerDown
moveLayerToIndex
getCenter
getRange
getHeading
getTilt
getCameraLocation
pan
setCenter
setHeading
setTilt
setRange
resetHeading
resetTilt
setAnimationEnabled
isAnimationEnabled
Bye!
Alexandre
Alexandre Devaux
Tel: 01 43 98 85 73
URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170315/3a54a434/attachment.html>
More information about the iTowns-dev
