[iTowns-user] Shadows in iTowns
Carsten Oldenburg
carsten.oldenburg at th-owl.de
Mon Jun 22 03:29:51 PDT 2020
Hi Gerald,
thanks for your reply.
Everything is fine now!!
Best regards,
Carsten
Carsten Oldenburg, M.Sc.
carsten.oldenburg at th-owl.de<mailto:carsten.oldenburg at th-owl.de>
Technische Hochschule Ostwestfalen-Lippe | University of Applied Sciences & Arts
Detmolder Schule für Architektur, Innenarchitektur und Stadtplanung
LivingLab Essigfabrik
Siegburger Straße 110, 50679 Köln
livinglab-essigfabrik at th-owl.de<mailto:livinglab-essigfabrik at th-owl.de>
https://livinglab-essigfabrik.eu
Forschungsschwerpunkt ’nextPlace’
Emilienstraße 45, 32756 Detmold
+49(0)5231-769 6032
http://www.nextplacelab.de
Von: Gerald Choqueux <Gerald.Choqueux at ign.fr>
Gesendet: Montag, 22. Juni 2020 11:32:13
An: Carsten Oldenburg; itowns-user at lists.osgeo.org
Betreff: RE:Shadows in iTowns
Hello
you need to enable renderer shadow map
view.mainLoop.gfxEngine.renderer.shadowMap.enabled = true;
view.mainLoop.gfxEngine.renderer.shadowMap.type = itowns.THREE.PCFShadowMap;
and move the light over the objects
var cP = view.controls.getLookAtCoordinate();
cP.altitude += 100;
sun.position.copy(cP.as(view.referenceCrs));
Beware the itowns ground doesn't handle shadows yet.
best regards
De : ITowns-user [itowns-user-bounces at lists.osgeo.org] de la part de Carsten Oldenburg [carsten.oldenburg at th-owl.de]
Envoyé : vendredi 19 juin 2020 08:51
À : itowns-user at lists.osgeo.org
Objet : [iTowns-user] Shadows in iTowns
Dear all,
is it possible to enable casting shadows in iTowns especially using 3DTiles?
Here is a minimal example with three.js 3D objects in iTowns.
I've set the castShadow and receiveShadow properties to true and added a new DirectionalLight casting shadows.
Might be possible that I've forgotten something!?!
<html>
<head>
<title>Shadow</title>
<meta charset="UTF-8">
<link rel="stylesheet" type="text/css" href="examples/css/example.css">
<link rel="stylesheet" type="text/css" href="examples/css/LoadingScreen.css">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<script src="https://cdnjs.cloudflare.com/ajax/libs/dat-gui/0.7.6/dat.gui.min.js"></script>
</head>
<body>
<div id="viewerDiv"></div>
<script src="examples/js/GUI/GuiTools.js"></script>
<script src="dist/itowns.js"></script>
<script src="examples/js/GUI/LoadingScreen.js"></script>
<script src="dist/debug.js"></script>
<script src="dist/three.min.js"></script>
<script type="text/javascript">
// Define initial camera position
var positionOnGlobe = { longitude: 6.956944, latitude: 50.938056, altitude: 5000 };
var placement = {
coord: new itowns.Coordinates('EPSG:4326', 6.978090, 50.922810), range: 1000, // Deutzer Hafen
//tilt: 45,
tilt: 10,
var viewerDiv = document.getElementById('viewerDiv');
var scene = new THREE.Scene();
scene.castShadow = true;
scene.receiveShadow = true;
var globeOptions = {
scene3D : scene,
var view = new itowns.GlobeView(viewerDiv, placement, globeOptions);
// delete original sun
view.tileLayer.object3d.remove (view.tileLayer.object3d.children[0]);
// Add new sun casting shadows
var sun = new THREE.DirectionalLight( 0xffffff, 1, 100 );
sun.position.set(9.3194, 0.30187, 4.0399);
sun.castShadow = true;
sun.updateMatrixWorld(true);
view.tileLayer.object3d.add(sun);
// position of the mesh
var cameraTargetPosition = view.controls.getLookAtCoordinate();
var meshCoord = cameraTargetPosition;
meshCoord.altitude += 30;
//Create a sphere that cast shadows (but does not receive them)
var sphereGeometry = new THREE.SphereBufferGeometry( 5, 32, 32 );
var sphereMaterial = new THREE.MeshStandardMaterial( { color: 0xff0000 } );
var sphere = new THREE.Mesh( sphereGeometry, sphereMaterial );
sphere.castShadow = true; //default is false
sphere.receiveShadow = true; //default
sphere.position.copy(meshCoord.as(view.referenceCrs));
view.tileLayer.object3d.add( sphere );
var meshCoord2 = cameraTargetPosition;
meshCoord2.altitude -= 10;
meshCoord2.latitude += 0.01;
//Create a plane that receives shadows (but does not cast them)
var planeGeometry = new THREE.PlaneBufferGeometry( 80, 80, 32, 32 );
var planeMaterial = new THREE.MeshStandardMaterial( { color: 0x00ff00 } )
var plane = new THREE.Mesh( planeGeometry, planeMaterial );
plane.castShadow = true; //default is false
plane.receiveShadow = true;
plane.rotateY(0.3*Math.PI);
plane.position.copy(meshCoord2.as(view.referenceCrs));
view.tileLayer.object3d.add( plane );
setupLoadingScreen(viewerDiv, view);
var menuGlobe = new GuiTools('menuDiv', view, 300);
// Add a debug UI
var d = new debug.Debug(view, menuGlobe.gui);
debug.createTileDebugUI(menuGlobe.gui, view, view.tileLayer, d);
</script>
</body>
</html>
Thanks in advance and all the best.
Carsten
URL: <http://lists.osgeo.org/pipermail/itowns-user/attachments/20200622/b40ae875/attachment-0001.html>
More information about the ITowns-user
