[Java-collab] Simple Text Exchange Format
Sunburned Surveyor sunburned.surveyor at gmail.com
Tue May 27 15:13:58 EDT 2008
Paul wrote: "Someone suggested using an embedded database such as H2
with a spatial extension. I think that using a database is a much
better way to go for this kind of access."
I see two problems with this approach.
[1] It requires dealing with a database. This adds some overhead and
complexity, like the need to deal with JDBC.
[2] A raw binary format could be accessed from other programming
languages. I think a database like H2 will present some challenges in
this area.
I don't think the binary format has to meet all the requirements for
permanent storage of geospatial data. It's just a transfer medium like
GML or WKT. (Except its more compact and allows for faster access.)
Landon
On Tue, May 27, 2008 at 11:22 AM, Paul Austin <mail-lists at revolsys.com> wrote:
> All,
> I saw in one of the other posts there was a discussion of binary format to
> replace shape files quick random access to data. Someone suggested using an
> embedded database such as H2 with a spatial extension. I think that using a
> database is a much better way to go for this kind of access. Otherwise if we
> come up with our own binary format we'll need to deal with all the issues
> such as storage management and indexing that databases already do for us.
> I do however think that we need a simple format for exchange of data.
> Exchanging data may be via files or via a web service. GML in my view is
> very verbose and complex to read and write and does not include an embedded
> schema.
> I have been working on a CSV derivative which I'm calling Enhanced-CSV.
> Basically it's a CSV file where the format is strict about placement of
> commas and use of "". It also has two header sections. The first section is
> a list of properties about the file, such as type name, projection, author
> and a list of which attribute headers will follow. The next header is the
> attribute header (schema). There can be multiple attribute headers including
> the name,type, length, precision, required flag of the attribute. There is
> one entry for each data column (attribute). Finally there is the data
> section which is just all your rows of data encoded as CSV. Geometries are
> encoded as WKT
> Below is a sample of a ECSV file with the three sections.
> {http://ns.ecsv.org/ecsv}typeName,QName,{GFT}GFT_CAPTURE_METHOD_CODE
> {http://ns.ecsv.org/ecsv}srid,QName,{http://epsg.org}3005
> {http://ns.ecsv.org/ecsv}attributeHeaderTypes,list,"{http://ns.ecsv.org/ecsv}attributeName,{http://ns.ecsv.org/ecsv}attributeType,{http://ns.ecsv.org/ecsv}attributeLength,{http://ns.ecsv.org/ecsv}attributeScale,{http://ns.ecsv.org/ecsv}attributeRequired"
> CAPTURE_METHOD_CODE_ID,CODE_VALUE,WHO_CREATED,WHEN_CREATED
> integer,string,string,dateTime
> 3,255,255,2147483647
> 0,0,0,0
> false,false,false,false
> 1,Photogrammetric,PROXY_GFT,2008-05-26T00:00:00
> 2,Differential Gps,PROXY_GFT,2008-05-26T00:00:00
> 3,Tablet Digitizing,PROXY_GFT,2008-05-26T00:00:00
> I'm working on a specification for this format and hopefully should have a
> draft up in the next month or so. I have developed a reader and writer and a
> JUMP plug-in which I'll make available when I've finalized the
> specification.
> Is this something that would interest any one else?
> Paul
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
More information about the Java-collab mailing list
