[Java-collab] geometry factory vs interface
    Jody Garnett
    jody.garnett at gmail.com
    Tue Aug 11 20:32:12 EDT 2009
On 12/08/2009, at 3:58 AM, Markus Schneider wrote:
> Concerning interfaces vs. classes: I agree that it's good to keep it
> as simple as possible, so one should provide
> classes whenever we can rule out that different implementations just
> don't make sense.
I understand the temptation; and agree we will probably go with
interfaces/factory/builder? However I wonder if that is a decision
being made to make our life as library providers easier; and may not
be in the  best interest of adoption and ease of use by developers?
The central implementation decision we need to have flexibility with
is the implementation of operations behind the various geometry
methods; this is t he point where we need to grow the library over
time. The actual front end (ie geometry data structure) will probably
not change much; and we may consider using classes. Even if it does
change it is easier to add methods to classes then it is to interfaces.
To follow up on that last point it is often a good idea to use
abstract classes rather then interfaces where possible.
> Especially, for Point and Envelope I would also like to have
> constructors alternatively to a factory:
> Point p = new Point (0,1);
> is just nicer to write than
> GeometryFactory.getInstance().createPoint (0,1);
You have highlighted one place where I was sure I would need an
interface :-) Indeed when a Points data structure provides access to a
single Point it often would use a light weight implementation of Point
that would delegate onto the backing double[] for example. Or another
implementation could make use of a List<PointImpl> etc... I see later
in this email you talk about recycling a Point object when iterating;
to accomplish this you will need to define Point as a data object and
add equals and hashcode to the interface.
> But I can very well imagine rather important use cases for having
> multiple implementations of the geometry types:
> - A straightforward implementation that just provides beans for the
> interfaces.
Fair enough.
> - An implementation that is backed by JTS, i.e. that actually uses
> JTS objects to represent SFS geometries.
Long term I would recommend using JTS to implement the operations; and
not tie it directly into the implementation of a set of geometry
classes.
> - Implementations that are backed by Oracle / PostGIS geometry types
I am not really interested in this one. Let me think about it.
Well actually I could be. If we had our front end geometry data
structures - which would basically act as an adapter between an
original Oracle SDO_GEOMETRY Struct and a host of operation
implementations (some using JTS, some using geodetic implementations
etc...) it would be a pretty good story.
Okay that could be very nice; you would not accept the unpacking over
head - just wrap around the "origional" geometry object. A few
operations may be implemented directly (toEnvelope() for example); and
the rest relying on the geometry api to present a unified view of the
data to the appropriate operations.
As you can see I am very attracted to this from an implementation
standpoint; I just worry the above benefit represents a "happy place
in the future" and we may have a better short term "right here right
now" in terms of library adoption if we make use of classes.
> I would opt for keeping the interfaces ease experimenting with
> different implementations.
> I also think that providing factories can make it easier for novice
> users to approach the quite intricate geometry type
> system. In deegree 3, we currently have a small factory for people
> with simple geometry needs (SFS):
> - https://svn.wald.intevation.org/svn/deegree/deegree3/core/trunk/src/org/deegree/geometry/SimpleGeometryFactory.java
> and one for those who need all the complex stuff
> - https://svn.wald.intevation.org/svn/deegree/deegree3/core/trunk/src/org/deegree/geometry/GeometryFactory.java
I really like the direction of different factories for different
target communities. One thing we have moved to in the geotools code
base is:
- the creation of a simple complete factory with no logic and no
duplication
- the creation of a "builder" that uses a factory; but is willing to
use logic and duplication; and default values and so on to make
constructing and code examples easier
Jody
URL: http://lists.osgeo.org/pipermail/java-collab/attachments/20090812/87df90be/attachment-0001.html
More information about the Java-collab
