[Java-collab] Re: invokeOperation and Jody's stupid idea
Matthias Basler matthiasbasler at earthflight.org
Sat Aug 15 03:09:44 EDT 2009
Jody wrote:
> Define "CRS" as per a the crs info idea as a wrapper / adapter between
> the CoordinateReferenceSystem or CoordinateSystem choice and the
> geometry implementation. We would need to provide enough information
> here like Matthias indicates; and we could also include a Enum like
> GEOM2D, GEOM2DZ etc... since both Jorge and Markus like Enums to
> quickly make choices.
I am not a big fan of duplication of information, but in this case there is none. Imho each of 2D or 2D+Z or 3D geometries can have 2D *or* 3D CRS and are valid in any case, aren't they? (Not sure about 2D+M though.)
When I came across the 2D+Z vs. 3D problem I used the interface names to distinguish f.e. Triangle3D from Polygon2DZ, the latter being a polygon when looked from above, but with 3D coordinates
Having this info stored in an enum would just provide another, better way of accessing it. So I'm fine with it.
About this invokeOperation idea:
>From a programmer's POV this is a great idea, since it means that it is possible to add new operations without touching the geometry interface, which I consider a good design choice.
On the downside is that for the user buffer() or union() methods are more intuitive than an invokeOperation(), but this is imho acceptable.
P.S: The operations could be enumerations as well:
   mygeom.invokeOperation(Operation.Buffer);
That's it for now. I've got to catch a train and will be hiking the next two days. :-)
Matthias Basler
More information about the Java-collab mailing list
