[Java-collab] First contents in osgeom repository
    Markus Schneider
    schneider at lat-lon.de
    Fri Aug 21 04:35:09 EDT 2009
Hi Ugo,
Ugo Taddei wrote:
> you're right. I don't know why, I keep assuming only hobbits have maps
> where north is along the x axis
> (http://www.douglas.eckhart.btinternet.co.uk/maps-thrors-map-01.jpg).
See. There you have another important use-case for inverted axis order ;-)
> Seems logical to me to almost always think in terms of longitude -> x,
> and latitude -> y because that's the way meridians and parallels are
> oriented, respectively. Anyway, this is all based on conventions and
> not worth the discussion here at such length. (For me it's anyway, getX
> == getOrd1; x is always the first ordinate, y the second, z the third,
> independent of how the CRS is oriented)
Right.
> Apart from that, I'll take you're not being biased by the name of the
> company you work for  ;-)
I hope so, but who can tell for certain ;-)
Best regards,
Markus
Markus Schneider
l a t / l o n  GmbH
Aennchenstrasse 19           53177 Bonn, Germany
phone ++49 +228 184960       fax ++49 +228 1849629
http://www.lat-lon.de        http://www.deegree.org
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/java-collab/attachments/20090821/dbc62091/signature.bin
More information about the Java-collab
