[Java-collab] Simple system for designating units.
Sunburned Surveyor
sunburned.surveyor at gmail.com
Mon Jun 29 18:47:24 EDT 2009
Thanks for the links Martin.
Most of JUMP's code only allows primitive types like ints and doubles
to be used for attribute values. So I don't think I will be able to
use implementations of Measureable directly in OpenJUMP. I might be
able to make use of the Unit and SystemOfUnits classes. I'm going to
do some reading on the JSR, and I will report back to the list with my
conclusion.
Thank you.
Landon (The Sunburned Surveyor)
On Mon, Jun 29, 2009 at 2:51 PM, Martin
Desruisseaux<martin.desruisseaux at geomatys.fr> wrote:
> Sunburned Surveyor a écrit :
>> Perhaps JSR 108 would be a good starting point:
>> http://jsr-108.sourceforge.net/
> JSR-108 has been withdrawn by Sun because of lack of activity. It has been
> superceed by JSR-275, which is active:
> https://jsr-275.dev.java.net/
> Javadoc is there: http://jscience.org/jsr-275/api/
> There is some pages on the web about JSR-275, for example:
> http://www.infoq.com/news/2007/10/jsr275-units-measures
> http://www.javaworld.com/javaworld/jw-10-2007/jw-10-jsr275.html
> Martin
More information about the Java-collab
