[Java-collab] JUMP Lib and GeoScript
Jody Garnett
jody.garnett at gmail.com
Sat Oct 6 20:59:44 PDT 2012
Recommended reading (witch between the languages to get a feel for what is going on):
- http://geoscript.org/tutorials/data-basic/index.html#tutorials-data-basic
- http://geoscript.org/py/api/index.html#api (API reference Python)
- http://geoscript.org/scala/api/#org.geoscript.feature.Schema (API reference Scala)
As indicated GeoScript represents a solid charge away from feature models .. and towards a simple to understand/simple to implement data structure. I may of gone one step further and used Record rather then Feature (just as an out reach effort to normal non GIS developers).
Jody Garnett
On Saturday, 6 October 2012 at 11:22 AM, Stefan Steiniger wrote:
> Hi Justin,
> OpenJUMP does not utilize GeoTools. We have some things for plugins from
> older GeoTools versions, but in general there isn't any dependency as it
> is rather built on JTS.
> so, nothing new to you
> stefan
> Am 05.10.12 20:19, schrieb Justin Deoliveira:
> > Hey Landon,
> > A java geoscript implementation has been an idea that has floated
> > around. The idea behind geoscript is to provide a higher level api for
> > geotools that is much easier to use and focused purely on convenience
> > for scripting languages. The same could certainly apply to straight java
> > as well.
> > I admit I am not up to the latest on how OpenJUMP and geotools fit
> > together. Does OpenJUMP utilize geotools in any way?
> > Anyways, certainly interested in continuing the conversation.
> > -Justin
> > On Fri, Oct 5, 2012 at 6:03 PM, Landon Blake
> > <sunburned.surveyor at gmail.com <mailto:sunburned.surveyor at gmail.com>> wrote:
> > I recently posted a message to the OpenJUMP and deegree Project
> > mailing lists about organizing an effort to extract core parts of
> > OpenJUMP (especially the simple feature model) into a stand alone
> > library called JUMP Lib. (My original message is here:
> > http://sourceforge.net/mailarchive/forum.php?thread_name=CALJ1OBUVo3AtKykAP6MqX%2BuO5d--pMDZdFq0cFPizJ2HZoJSCw%40mail.gmail.com&forum_name=jump-pilot-devel
> > Jody Garnett was listening in. He mentioned the simple feature model
> > in OpenJUMP was fairly close to the one in GeoScript, and suggested
> > that GeoScript would benefit from a Java implementation of its API. I
> > know very little about LocationTech, but with Jody's encouragement I'm
> > trying to explore common ground and opportunities for collaboration.
> > I posted a message on this topic to the LocationTech mailing list, but
> > I wanted to post here as well. I'm trying to avoid doing a bunch of
> > independent work before I talk to potential collaborators.
> > Thanks.
> > Landon
> > PS - My message to Jody about the challenges to this approach,
> > including the use of wrappers, is here:
> > http://sourceforge.net/mailarchive/message.php?msg_id=29929818
> > Java-collab mailing list
> > Java-collab at lists.osgeo.org <mailto:Java-collab at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/java-collab
> > Justin Deoliveira
> > OpenGeo - http://opengeo.org
> > Enterprise support for open source geospatial.
> > Java-collab at lists.osgeo.org (mailto:Java-collab at lists.osgeo.org)
URL: <http://lists.osgeo.org/pipermail/java-collab/attachments/20121007/a6c3136f/attachment.html>
More information about the Java-collab
