[Java-collab] Java 11 Code Sprint taking shape
    Jody Garnett
    jody.garnett at gmail.com
    Mon Sep 17 15:29:56 PDT 2018
When:  October 22-26th
Where: North America (Victoria, BC), Europe (Italy or UK proposed), Oceania
(recommendations welcome)
Wiki: https://wiki.osgeo.org/wiki/Java_2018_Code_Sprint
If you or your project is interested in taking part, even remotely, please
add yourself to the above wiki page!
The Java community has a challenge ahead, with recent policy changes the
Java platform is now seeing some change - *and we have a python 2 vs python
3 migration moment with the introduction a a "jigsaw module system".*
Top level applications like GeoServer and GeoNetwork need to make some
changes in order to run at all. Mostly this requires a dependency review,
upgrading to new libraries such that are compatible with Java 11.
Java libraries like JTS and GeoTools are put in an awkward position as they
are a bottleneck on using the module system (popularly referred to as
the module
hell problem
<http://blog.joda.org/2017/05/java-se-9-jpms-automatic-modules.html>). A
further complication for modules is a restriction preventing two jars from
making use of the same package.
Planning is currently underway:
   - GSIP 171 Java 18.9 Compatibility
   <https://github.com/geoserver/geoserver/wiki/GSIP-171> (GeoServer)
   - Strategy for GeoNetwork
   <https://github.com/geonetwork/core-geonetwork/wiki/OSGeo-Java-codesprint-2018>
   - Restructure GeoTools into Jigsaw modules
   <https://github.com/geotools/geotools/wiki/Restructure-GeoTools-into-Jigsaw-modules>
Recommended reading:
   - What Comes After JDK 8? <https://www.azul.com/what-comes-after-jdk-8/> -
   java release cycle changes
   - It's time! Migrating to Java 11
   <https://medium.com/criciumadev/its-time-migrating-to-java-11-5eb3868354f9>
   spring upgrade example
   - The State of the Module System
   <http://openjdk.java.net/projects/jigsaw/spec/sotms> - technical
   background
URL: <http://lists.osgeo.org/pipermail/java-collab/attachments/20180917/b1b7f7aa/attachment.html>
More information about the Java-collab
