[Landsat-pds] Converting MTL.txt to JSON
Charlie Loyd
charlie at mapbox.com
Wed Feb 25 14:45:42 PST 2015
Hi all,
Hurray, JSON! Thanks, Jeff!
It’s just a detail, but should the numeric values be converted to numbers? For example, this line of JSON:
> "REFLECTANCE_MULT_BAND_9": "2.0000E-05",
could be replaced by:
> "REFLECTANCE_MULT_BAND_9": 2e-05,
This would mean one less conversion-and-check necessary on the end user’s side in order to use the value.
I won’t push on this – it’s a very small thing and it might add complexity in ways I’m not seeing. Just asking.
—Charlie
> On Feb 25, 2015, at 1:13 PM, Layton, Jeff <jefflay at amazon.com> wrote:
> Hello everyone,
> I just joined the mailing list and I’m working with Jed from AWS (I work for AWS as well). The first project I did was write a simple Python tool to convert the MTL.txt files to JSON. I’m attaching a sample MTL file and the resulting JSON. Let me know what you think!
> Thanks!
> Jeff
> Dr. Jeff Layton
> Solutions Architect – HPC
> Amazon Web Services
> 678-310-3685
> <LC80361102015008LGN00_MTL.txt><testfile>_______________________________________________
> Landsat-pds mailing list
> Landsat-pds at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/landsat-pds
More information about the Landsat-pds
