[Landsat-pds] usgs service issues?
Frank Warmerdam
warmerdam at pobox.com
Sat Jan 10 08:07:38 PST 2015
Amit,
I was only downloading one scene on that connection, but other processes
were potentially processing others at the same time.
Currently I only ever pass one scene id to the request to get download urls
though it was using, not requesting the download url that failed.
Best regards,
Frank
On Sat, Jan 10, 2015 at 7:35 AM, Amit Kapadia <amit at mapbox.com> wrote:
> Hi Frank,
> Documentation says each download request takes up to 50,000 scene ids. In
> practice the limit is lower, where the limiting factor is the size of the
> request. How many scenes where you requesting?
> Cheers,
> Amit
> On Sat, Jan 10, 2015 at 12:16 AM, Frank Warmerdam <warmerdam at pobox.com>
> wrote:
>> Amit,
>> I ran into this once when using a download url for the usgs service:
>> requests.exceptions.HTTPError: 503 Server Error: Service Temporarily
>> Unavailable
>> Are there limits on the number of download urls I should be fetching at
>> once? Is this a common problem?
>> I haven't run enough at once to know if this is going to be a broader
>> problem, but if so it will mean I need to reconsider my approach which can
>> result in quite a few parallel downloads.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/landsat-pds/attachments/20150110/5113e0f7/attachment.html>
More information about the Landsat-pds
