[Liblas-commits] r981 - branches/1.0/apps
liblas-commits at liblas.org
Fri Dec 26 00:40:11 EST 2008
Author: hobu
Date: Fri Dec 26 00:40:11 2008
New Revision: 981
URL: http://liblas.org/changeset/981
add index parse option to las2txt #86 (backport of r980)
branches/1.0/apps/las2txt.c
Modified: branches/1.0/apps/las2txt.c
--- branches/1.0/apps/las2txt.c (original)
+++ branches/1.0/apps/las2txt.c Fri Dec 26 00:40:11 2008
@@ -56,7 +56,8 @@
fprintf(stderr," u - user data (does not currently work)\n");
fprintf(stderr," p - point source ID\n");
fprintf(stderr," e - edge of flight line\n");
- fprintf(stderr," d - direction of scan flag\n\n");
+ fprintf(stderr," d - direction of scan flag\n");
+ fprintf(stderr," M - vertex index number\n\n");
fprintf(stderr,"----------------------------------------------------------\n");
fprintf(stderr," The '--sep space' flag specifies what separator to use. The\n");
@@ -106,7 +107,9 @@
LASPointH p = NULL;
FILE* file_out = NULL;
int len;
+ uint32_t index = 0;
for (i = 1; i < argc; i++)
if ( strcmp(argv[i],"-h") == 0 ||
@@ -464,11 +467,13 @@
p = LASReader_GetNextPoint(reader);
while (p)
if (skip_invalid && !LASPoint_IsValid(p)) {
if (verbose) {
LASError_Print("Skipping writing invalid point...");
+ index -=1;
continue;
@@ -517,6 +522,10 @@
case 'n':
fprintf(file_out, "%d", LASPoint_GetNumberOfReturns(p));
break;
+ case 'M':
+ fprintf(file_out, "%d", index);
+ break;
case 'p': // the point source ID
fprintf(file_out, "%d", lasreader->point.point_source_ID);
@@ -545,6 +554,7 @@
+ index +=1;
More information about the Liblas-commits
