[Liblas-commits] r1194 - trunk/src/detail
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Apr 9 13:15:55 EDT 2009
Author: hobu
Date: Thu Apr  9 13:15:55 2009
New Revision: 1194
URL: http://liblas.org/changeset/1194
clean up logic and allow pad bytes to be both directions #124 #125
   trunk/src/detail/reader.cpp
Modified: trunk/src/detail/reader.cpp
--- trunk/src/detail/reader.cpp	(original)
+++ trunk/src/detail/reader.cpp	Thu Apr  9 13:15:55 2009
@@ -284,15 +284,23 @@
     detail::read_n(pad1, m_ifs, sizeof(uint8_t));
     detail::read_n(pad2, m_ifs, sizeof(uint8_t));
+    LIBLAS_SWAP_BYTES(pad1);
+    LIBLAS_SWAP_BYTES(pad2);
     // FIXME: we have to worry about swapping issues
-    // for now, just check oppositely
-    if (! (sgn1 == pad2 && sgn2 == pad1))
+    // but some people write the pad bytes backwards
+    // anyway.  Let's check both ways.
+    bool found = false;
+    if (sgn1 == pad2 && sgn2 == pad1) found = true;
+    if (sgn1 == pad1 && sgn2 == pad2) found = true;
+    if (!found)
         // If the two bytes we read weren't signature bytes
         // we'll throw an exception.  Depending on the version
         // we may want ot throw an error to the user or
         // silently continue on.
         throw std::domain_error("point data signature (1.0's 0xCC and 0xDD padding) not found");
More information about the Liblas-commits mailing list
