[Liblas-commits] r1197 - trunk/src/detail
liblas-commits at liblas.org
Thu Apr 9 14:53:46 EDT 2009
Author: hobu
Date: Thu Apr 9 14:53:43 2009
New Revision: 1197
URL: http://liblas.org/changeset/1197
fix the tests for the case when we have a file that is just header and has no padding #124 #125
trunk/src/detail/reader10.cpp
trunk/src/detail/reader11.cpp
trunk/src/detail/reader12.cpp
Modified: trunk/src/detail/reader10.cpp
--- trunk/src/detail/reader10.cpp (original)
+++ trunk/src/detail/reader10.cpp Thu Apr 9 14:53:43 2009
@@ -210,10 +210,17 @@
// The 1.0 version *requires* the pad bytes, but in
// many instances, there are files without them. What
// a fucking mess -- hobu.
+ m_has_pad_bytes = false;
try {
SkipPointDataSignature();
m_has_pad_bytes = true;
+ catch (std::out_of_range const& e)
+ // Ignore the out_of_range here for the case of a
+ // file with just a header and no pad
catch (std::domain_error const& e)
// TODO: We'll want to put this error on the validation errors stack
Modified: trunk/src/detail/reader11.cpp
--- trunk/src/detail/reader11.cpp (original)
+++ trunk/src/detail/reader11.cpp Thu Apr 9 14:53:43 2009
@@ -211,6 +211,8 @@
header.SetMax(x1, y1, z1);
header.SetMin(x2, y2, z2);
m_ifs.seekg(header.GetDataOffset(), std::ios::beg);
try {
// If this call succeeds, we'll want to put this on the
@@ -219,6 +221,12 @@
Modified: trunk/src/detail/reader12.cpp
--- trunk/src/detail/reader12.cpp (original)
+++ trunk/src/detail/reader12.cpp Thu Apr 9 14:53:43 2009
@@ -216,6 +216,8 @@
try {
@@ -225,10 +227,15 @@
Reset(header);
More information about the Liblas-commits
