[Liblas-commits] r1220 - in trunk: build/msvc90/liblas_lib include/liblas src test/unit
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Apr 16 11:21:53 EDT 2009
Author: mloskot
Date: Thu Apr 16 11:21:53 2009
New Revision: 1220
URL: http://liblas.org/changeset/1220
* Compute LASClassification::class_table_size in compile_time according to current definition of lookup table (no need to keep hardcoded size of array).
* Implemented LASClassification::GetClassName() function to return classification description.
* Added tests corresponding to this update.
* src/Makefile.am and src/makefile.vc updated as well.
Added:
   trunk/src/lasclassification.cpp
   trunk/build/msvc90/liblas_lib/liblas_lib.vcproj
   trunk/include/liblas/lasclassification.hpp
   trunk/src/Makefile.am
   trunk/src/makefile.vc
   trunk/test/unit/lasclassification_test.cpp
Modified: trunk/build/msvc90/liblas_lib/liblas_lib.vcproj
--- trunk/build/msvc90/liblas_lib/liblas_lib.vcproj	(original)
+++ trunk/build/msvc90/liblas_lib/liblas_lib.vcproj	Thu Apr 16 11:21:53 2009
@@ -293,6 +293,10 @@
 			</File>
 			<File
+				RelativePath="..\..\..\src\lasclassification.cpp"
+			</File>
+			<File
 				RelativePath="..\..\..\src\lascolor.cpp"
 			</File>
Modified: trunk/include/liblas/lasclassification.hpp
--- trunk/include/liblas/lasclassification.hpp	(original)
+++ trunk/include/liblas/lasclassification.hpp	Thu Apr 16 11:21:53 2009
@@ -65,7 +65,7 @@
     /// Number of classes in lookup table as defined in ASPRS LAS 1.1+.
     /// For LAS 1.0, this static number may be invalid and
     /// extend up to 255 classes stored in variable-length records.
-    static std::size_t const class_table_size = 32;
+    static std::size_t const class_table_size;
     enum
@@ -125,17 +125,18 @@
     /// as defined in classification object.
     /// \todo TODO: To be implemented
-    std::string GetClassName() const
-        return std::string("");
+    std::string GetClassName() const;
     uint8_t GetClass() const
         bitset_type bits(m_flags);
-        bitset_type mask(class_table_size - 1);
+        bitset_type const mask(class_table_size - 1);
         bits &= mask;
-        return (static_cast<uint8_t>(bits.to_ulong()));
+        uint8_t const index = static_cast<uint8_t>(bits.to_ulong());
+        assert(index < class_table_size);
+        return index;
     void SetClass(uint8_t index)
@@ -190,7 +191,7 @@
     bitset_type m_flags;
-    void check_class_index(std::size_t index)
+    void check_class_index(std::size_t index) const
         if (index > (class_table_size - 1))
Modified: trunk/src/Makefile.am
--- trunk/src/Makefile.am	(original)
+++ trunk/src/Makefile.am	Thu Apr 16 11:21:53 2009
@@ -14,6 +14,8 @@
 lib_LTLIBRARIES = liblas.la
 liblas_la_SOURCES = \
+    lasclassification.cpp \
+    lascolor.cpp \
 	laserror.cpp \
 	laspoint.cpp \
 	lasheader.cpp \
@@ -22,7 +24,6 @@
 	laswriter.cpp \
 	lasfile.cpp \
 	las_c_api.cpp \
-	lascolor.cpp \
 	lasspatialreference.cpp \
     detail/reader.cpp \
     detail/reader10.cpp \
Added: trunk/src/lasclassification.cpp
--- (empty file)
+++ trunk/src/lasclassification.cpp	Thu Apr 16 11:21:53 2009
@@ -0,0 +1,101 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  Definition LASClassification type.
+ * Author:   Mateusz Loskot, mateusz at loskot.net
+ * Copyright (c) 2009, Mateusz Loskot
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#include <liblas/lasclassification.hpp>
+#include <liblas/cstdint.hpp>
+#include <liblas/detail/utility.hpp>
+// std
+#include <cstddef>
+#include <string>
+namespace {
+static std::string g_class_names[] =
+    "Created, never classified",
+    "Unclassified",
+    "Ground",
+    "Low Vegetation",
+    "Medium Vegetation",
+    "High Vegetation",
+    "Building",
+    "Low Point (noise)",
+    "Model Key-point (mass point)",
+    "Water",
+    "Reserved for ASPRS Definition",
+    "Overlap Points",
+} // namespace anonymous
+namespace liblas {
+std::size_t const LASClassification::class_table_size = detail::static_array_size(g_class_names);
+std::string LASClassification::GetClassName() const
+    std::size_t const index = GetClass();
+    check_class_index(index);
+    return g_class_names[index];
+} // namespace liblas
Modified: trunk/src/makefile.vc
--- trunk/src/makefile.vc	(original)
+++ trunk/src/makefile.vc	Thu Apr 16 11:21:53 2009
@@ -5,6 +5,7 @@
 !INCLUDE $(LAS_ROOT)\nmake.opt
 LAS_OBJS = \
+    lasclassification.obj \
     lascolor.obj \
     laswriter.obj \
     lasreader.obj \
Modified: trunk/test/unit/lasclassification_test.cpp
--- trunk/test/unit/lasclassification_test.cpp	(original)
+++ trunk/test/unit/lasclassification_test.cpp	Thu Apr 16 11:21:53 2009
@@ -369,4 +369,12 @@
         oss << c;
         ensure_equals(oss.str(), sbits);
+    template<>
+    template<>
+    void to::test<20>()
+        std::string const cn("Created, never classified");
+        ensure_equals(m_default.GetClassName(), cn);
More information about the Liblas-commits mailing list
