[Liblas-commits] r1222 - in trunk: build/msvc90 build/msvc90/las2ogr include/liblas src test/unit
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Apr 16 12:11:33 EDT 2009
Author: mloskot
Date: Thu Apr 16 12:11:33 2009
New Revision: 1222
URL: http://liblas.org/changeset/1222
* Use const mask in LASClassification.
* Added a couple of new test cases for LASClassification.
* Updated build/msvc90/las2ogr project.
   trunk/build/msvc90/las2ogr/las2ogr.vcproj
   trunk/build/msvc90/liblas.sln
   trunk/include/liblas/lasclassification.hpp
   trunk/src/lasclassification.cpp
   trunk/test/unit/lasclassification_test.cpp
Modified: trunk/build/msvc90/las2ogr/las2ogr.vcproj
--- trunk/build/msvc90/las2ogr/las2ogr.vcproj	(original)
+++ trunk/build/msvc90/las2ogr/las2ogr.vcproj	Thu Apr 16 12:11:33 2009
@@ -1,11 +1,12 @@
 <?xml version="1.0" encoding="Windows-1252"?>
 <VisualStudioProject
 	ProjectType="Visual C++"
-	Version="8.00"
+	Version="9.00"
 	Name="las2ogr"
 	ProjectGUID="{0CE46FF7-F5B6-4EE2-B8EE-37B5555CAC62}"
 	RootNamespace="las2ogr"
 	Keyword="Win32Proj"
+	TargetFrameworkVersion="131072"
 	<Platforms>
 		<Platform
@@ -20,7 +21,7 @@
 			OutputDirectory="$(SolutionDir)$(ConfigurationName)"
 			IntermediateDirectory="$(ConfigurationName)"
 			ConfigurationType="1"
-			InheritedPropertySheets="..\liblas.vsprops;.\las2ogr.vsprops"
+			InheritedPropertySheets="..\liblas.vsprops"
 			CharacterSet="1"
 			<Tool
@@ -65,6 +66,8 @@
 				LinkIncremental="2"
 				GenerateDebugInformation="true"
 				SubSystem="1"
+				RandomizedBaseAddress="1"
+				DataExecutionPrevention="0"
 				TargetMachine="1"
 			<Tool
@@ -86,9 +89,6 @@
 				Name="VCAppVerifierTool"
 			<Tool
-				Name="VCWebDeploymentTool"
-			<Tool
 				Name="VCPostBuildEventTool"
 		</Configuration>
@@ -97,7 +97,7 @@
 			CharacterSet="1"
 			WholeProgramOptimization="1"
@@ -141,6 +141,8 @@
 				SubSystem="1"
 				OptimizeReferences="2"
 				EnableCOMDATFolding="2"
 				TargetMachine="1"
 			<Tool
@@ -162,9 +164,6 @@
 			<Tool
-			<Tool
 		</Configuration>
Modified: trunk/build/msvc90/liblas.sln
--- trunk/build/msvc90/liblas.sln	(original)
+++ trunk/build/msvc90/liblas.sln	Thu Apr 16 12:11:33 2009
@@ -61,6 +61,11 @@
 		{EC92BE01-CFA3-46C6-998E-810484CC5860} = {EC92BE01-CFA3-46C6-998E-810484CC5860}
 	EndProjectSection
 EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "las2ogr", "las2ogr\las2ogr.vcproj", "{0CE46FF7-F5B6-4EE2-B8EE-37B5555CAC62}"
+	ProjectSection(ProjectDependencies) = postProject
+		{208417AE-D08E-4938-AC26-A16ABD55AA5B} = {208417AE-D08E-4938-AC26-A16ABD55AA5B}
+	EndProjectSection
+EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
 		Debug|Win32 = Debug|Win32
@@ -103,6 +108,10 @@
 		{C78B8A0D-12CE-49D6-8615-96B9735564D5}.Debug|Win32.Build.0 = Debug|Win32
 		{C78B8A0D-12CE-49D6-8615-96B9735564D5}.Release|Win32.ActiveCfg = Release|Win32
 		{C78B8A0D-12CE-49D6-8615-96B9735564D5}.Release|Win32.Build.0 = Release|Win32
+		{0CE46FF7-F5B6-4EE2-B8EE-37B5555CAC62}.Debug|Win32.ActiveCfg = Debug|Win32
+		{0CE46FF7-F5B6-4EE2-B8EE-37B5555CAC62}.Debug|Win32.Build.0 = Debug|Win32
+		{0CE46FF7-F5B6-4EE2-B8EE-37B5555CAC62}.Release|Win32.ActiveCfg = Release|Win32
+		{0CE46FF7-F5B6-4EE2-B8EE-37B5555CAC62}.Release|Win32.Build.0 = Release|Win32
 	EndGlobalSection
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
Modified: trunk/include/liblas/lasclassification.hpp
--- trunk/include/liblas/lasclassification.hpp	(original)
+++ trunk/include/liblas/lasclassification.hpp	Thu Apr 16 12:11:33 2009
@@ -130,7 +130,7 @@
     uint8_t GetClass() const
         bitset_type bits(m_flags);
-        bitset_type const mask(class_table_size - 1);
+        bitset_type const mask(static_cast<unsigned long>(class_table_size) - 1);
         bits &= mask;
         uint8_t const index = static_cast<uint8_t>(bits.to_ulong());
Modified: trunk/src/lasclassification.cpp
--- trunk/src/lasclassification.cpp	(original)
+++ trunk/src/lasclassification.cpp	Thu Apr 16 12:11:33 2009
@@ -47,41 +47,41 @@
 #include <string>
 namespace {
-static std::string g_class_names[] =
-    "Created, never classified",
-    "Unclassified",
-    "Ground",
-    "Low Vegetation",
-    "Medium Vegetation",
-    "High Vegetation",
-    "Building",
-    "Low Point (noise)",
-    "Model Key-point (mass point)",
-    "Water",
-    "Reserved for ASPRS Definition",
-    "Overlap Points",
+static std::string g_class_names[] =
+    "Created, never classified",
+    "Unclassified",
+    "Ground",
+    "Low Vegetation",
+    "Medium Vegetation",
+    "High Vegetation",
+    "Building",
+    "Low Point (noise)",
+    "Model Key-point (mass point)",
+    "Water",
+    "Reserved for ASPRS Definition",
+    "Overlap Points",
 } // namespace anonymous
Modified: trunk/test/unit/lasclassification_test.cpp
--- trunk/test/unit/lasclassification_test.cpp	(original)
+++ trunk/test/unit/lasclassification_test.cpp	Thu Apr 16 12:11:33 2009
@@ -377,4 +377,41 @@
         std::string const cn("Created, never classified");
         ensure_equals(m_default.GetClassName(), cn);
+    template<>
+    template<>
+    void to::test<21>()
+        std::string const cn("Low Point (noise)");
+        m_default.SetClass(7);
+        ensure_equals(m_default.GetClassName(), cn);
+    template<>
+    template<>
+    void to::test<22>()
+        std::string const cn("Reserved for ASPRS Definition");
+        m_default.SetClass(31);
+    template<>
+    template<>
+    void to::test<23>()
+        try
+            m_default.SetClass(32);
+            fail("std::out_of_range not thrown but expected");
+        catch (std::out_of_range const& e)
+            ensure(e.what(), true);
+        catch (...)
+            fail("unhandled exception expected");
More information about the Liblas-commits mailing list
