[Liblas-commits] r1240 - in trunk: include/liblas
include/liblas/detail test/unit
liblas-commits at liblas.org
Mon Apr 20 11:59:31 EDT 2009
Author: mloskot
Date: Mon Apr 20 11:59:30 2009
New Revision: 1240
URL: http://liblas.org/changeset/1240
Check std::remove error code in lasfile_test. Use stricter casting in sha1 and guide classes.
trunk/include/liblas/detail/sha1.hpp
trunk/include/liblas/guid.hpp
trunk/test/unit/lasfile_test.cpp
Modified: trunk/include/liblas/detail/sha1.hpp
--- trunk/include/liblas/detail/sha1.hpp (original)
+++ trunk/include/liblas/detail/sha1.hpp Mon Apr 20 11:59:30 2009
@@ -53,6 +53,8 @@
#ifndef LIBLAS_SHA1_HPP_INCLUDED
#define LIBLAS_SHA1_HPP_INCLUDED
+#include <cassert>
namespace liblas { namespace detail {
class SHA1
@@ -114,21 +116,21 @@
* Comments:
- void Reset()
- Length_Low = 0;
- Length_High = 0;
- Message_Block_Index = 0;
- H[0] = 0x67452301;
- H[1] = 0xEFCDAB89;
- H[2] = 0x98BADCFE;
- H[3] = 0x10325476;
- H[4] = 0xC3D2E1F0;
- Computed = false;
- Corrupted = false;
+ void Reset()
+ Length_Low = 0;
+ Length_High = 0;
+ Message_Block_Index = 0;
+ H[0] = 0x67452301;
+ H[1] = 0xEFCDAB89;
+ H[2] = 0x98BADCFE;
+ H[3] = 0x10325476;
+ H[4] = 0xC3D2E1F0;
+ Computed = false;
+ Corrupted = false;
* Result
@@ -148,9 +150,11 @@
* Comments:
- bool Result(unsigned *message_digest_array)
+ bool Result(unsigned int* message_digest_array)
- int i; // Counter
+ assert(0 != message_digest_array);
+ int i = 0; // Counter
if (Corrupted)
@@ -189,9 +193,10 @@
* Comments:
- void Input( const unsigned char *message_array,
- unsigned length)
+ void Input(unsigned char const* message_array, unsigned int length)
+ assert(0 != message_array);
if (!length)
return;
@@ -248,10 +253,15 @@
* Comments:
- void Input( const char *message_array,
- unsigned length)
+ void Input(char const* message_array, unsigned length)
- Input((unsigned char *) message_array, length);
+ typedef unsigned char const* target_type;
+ typedef void const* proxy_type;
+ target_type p = static_cast<target_type>(static_cast<proxy_type>(message_array));
+ Input(p, length);
@@ -270,10 +280,10 @@
* Comments:
- void Input(unsigned char message_element)
- Input(&message_element, 1);
+ void Input(unsigned char message_element)
+ Input(&message_element, 1);
* Input
@@ -291,10 +301,11 @@
* Comments:
- void Input(char message_element)
- Input((unsigned char *) &message_element, 1);
+ void Input(char message_element)
+ unsigned char ch = static_cast<unsigned char>(message_element);
+ Input(&ch, 1);
* operator<<
@@ -314,18 +325,18 @@
* Each character is assumed to hold 8 bits of information.
- SHA1& operator<<(const char *message_array)
- const char *p = message_array;
- while(*p)
- Input(*p);
- p++;
- return *this;
+ SHA1& operator<<(const char *message_array)
+ const char* p = message_array;
+ while(*p)
+ Input(*p);
+ p++;
+ return *this;
* operator<<
@@ -347,6 +358,8 @@
SHA1& operator<<(const unsigned char *message_array)
const unsigned char *p = message_array;
while(*p)
@@ -426,94 +439,100 @@
* in the publication.
- void ProcessMessageBlock()
- const unsigned K[] = { // Constants defined for SHA-1
- 0x5A827999,
- 0x6ED9EBA1,
- 0x8F1BBCDC,
- 0xCA62C1D6
- int t; // Loop counter
- unsigned temp; // Temporary word value
- unsigned W[80]; // Word sequence
- unsigned A, B, C, D, E; // Word buffers
- * Initialize the first 16 words in the array W
- for(t = 0; t < 16; t++)
- W[t] = ((unsigned) Message_Block[t * 4]) << 24;
- W[t] |= ((unsigned) Message_Block[t * 4 + 1]) << 16;
- W[t] |= ((unsigned) Message_Block[t * 4 + 2]) << 8;
- W[t] |= ((unsigned) Message_Block[t * 4 + 3]);
- for(t = 16; t < 80; t++)
- W[t] = CircularShift(1,W[t-3] ^ W[t-8] ^ W[t-14] ^ W[t-16]);
- A = H[0];
- B = H[1];
- C = H[2];
- D = H[3];
- E = H[4];
- for(t = 0; t < 20; t++)
- temp = CircularShift(5,A) + ((B & C) | ((~B) & D)) + E + W[t] + K[0];
- temp &= 0xFFFFFFFF;
- E = D;
- D = C;
- C = CircularShift(30,B);
- B = A;
- A = temp;
- for(t = 20; t < 40; t++)
- temp = CircularShift(5,A) + (B ^ C ^ D) + E + W[t] + K[1];
- E = D;
- D = C;
- B = A;
- A = temp;
- for(t = 40; t < 60; t++)
- ((B & C) | (B & D) | (C & D)) + E + W[t] + K[2];
- E = D;
- D = C;
- B = A;
- A = temp;
- for(t = 60; t < 80; t++)
- temp = CircularShift(5,A) + (B ^ C ^ D) + E + W[t] + K[3];
- E = D;
- D = C;
- B = A;
- A = temp;
- H[0] = (H[0] + A) & 0xFFFFFFFF;
- H[1] = (H[1] + B) & 0xFFFFFFFF;
- H[2] = (H[2] + C) & 0xFFFFFFFF;
- H[3] = (H[3] + D) & 0xFFFFFFFF;
- H[4] = (H[4] + E) & 0xFFFFFFFF;
+ void ProcessMessageBlock()
+ const unsigned K[] =
+ { // Constants defined for SHA-1
+ 0x5A827999,
+ 0x6ED9EBA1,
+ 0x8F1BBCDC,
+ 0xCA62C1D6
+ int t = 0; // Loop counter
+ unsigned int temp = 0; // Temporary word value
+ unsigned int W[80]; // Word sequence
+ unsigned int A = 0; // Word buffers
+ unsigned int B = 0;
+ unsigned int C = 0;
+ unsigned int D = 0;
+ unsigned int E = 0;
+ * Initialize the first 16 words in the array W
+ for(t = 0; t < 16; t++)
+ W[t] = ((unsigned) Message_Block[t * 4]) << 24;
+ W[t] |= ((unsigned) Message_Block[t * 4 + 1]) << 16;
+ W[t] |= ((unsigned) Message_Block[t * 4 + 2]) << 8;
+ W[t] |= ((unsigned) Message_Block[t * 4 + 3]);
+ for(t = 16; t < 80; t++)
+ W[t] = CircularShift(1,W[t-3] ^ W[t-8] ^ W[t-14] ^ W[t-16]);
+ A = H[0];
+ B = H[1];
+ C = H[2];
+ D = H[3];
+ E = H[4];
+ for(t = 0; t < 20; t++)
+ temp = CircularShift(5,A) + ((B & C) | ((~B) & D)) + E + W[t] + K[0];
+ temp &= 0xFFFFFFFF;
+ E = D;
+ D = C;
+ C = CircularShift(30,B);
+ B = A;
+ A = temp;
+ for(t = 20; t < 40; t++)
+ temp = CircularShift(5,A) + (B ^ C ^ D) + E + W[t] + K[1];
+ E = D;
+ D = C;
+ B = A;
+ A = temp;
+ for(t = 40; t < 60; t++)
+ ((B & C) | (B & D) | (C & D)) + E + W[t] + K[2];
+ E = D;
+ D = C;
+ B = A;
+ A = temp;
+ for(t = 60; t < 80; t++)
+ temp = CircularShift(5,A) + (B ^ C ^ D) + E + W[t] + K[3];
+ E = D;
+ D = C;
+ B = A;
+ A = temp;
+ H[0] = (H[0] + A) & 0xFFFFFFFF;
+ H[1] = (H[1] + B) & 0xFFFFFFFF;
+ H[2] = (H[2] + C) & 0xFFFFFFFF;
+ H[3] = (H[3] + D) & 0xFFFFFFFF;
+ H[4] = (H[4] + E) & 0xFFFFFFFF;
* PadMessage
@@ -536,54 +555,52 @@
* Comments:
- void PadMessage()
- * Check to see if the current message block is too small to hold
- * the initial padding bits and length. If so, we will pad the
- * block, process it, and then continue padding into a second block.
- if (Message_Block_Index > 55)
- Message_Block[Message_Block_Index++] = 0x80;
- while(Message_Block_Index < 64)
- Message_Block[Message_Block_Index++] = 0;
- ProcessMessageBlock();
- while(Message_Block_Index < 56)
- else
- * Store the message length as the last 8 octets
- Message_Block[56] = static_cast<unsigned char>((Length_High >> 24) & 0xFF);
- Message_Block[57] = static_cast<unsigned char>((Length_High >> 16) & 0xFF);
- Message_Block[58] = static_cast<unsigned char>((Length_High >> 8) & 0xFF);
- Message_Block[59] = static_cast<unsigned char>((Length_High) & 0xFF);
- Message_Block[60] = static_cast<unsigned char>((Length_Low >> 24) & 0xFF);
- Message_Block[61] = static_cast<unsigned char>((Length_Low >> 16) & 0xFF);
- Message_Block[62] = static_cast<unsigned char>((Length_Low >> 8) & 0xFF);
- Message_Block[63] = static_cast<unsigned char>((Length_Low) & 0xFF);
+ void PadMessage()
+ * Check to see if the current message block is too small to hold
+ * the initial padding bits and length. If so, we will pad the
+ * block, process it, and then continue padding into a second block.
+ if (Message_Block_Index > 55)
+ Message_Block[Message_Block_Index++] = 0x80;
+ while(Message_Block_Index < 64)
+ Message_Block[Message_Block_Index++] = 0;
+ ProcessMessageBlock();
+ while(Message_Block_Index < 56)
+ else
+ * Store the message length as the last 8 octets
+ Message_Block[56] = static_cast<unsigned char>((Length_High >> 24) & 0xFF);
+ Message_Block[57] = static_cast<unsigned char>((Length_High >> 16) & 0xFF);
+ Message_Block[58] = static_cast<unsigned char>((Length_High >> 8) & 0xFF);
+ Message_Block[59] = static_cast<unsigned char>((Length_High) & 0xFF);
+ Message_Block[60] = static_cast<unsigned char>((Length_Low >> 24) & 0xFF);
+ Message_Block[61] = static_cast<unsigned char>((Length_Low >> 16) & 0xFF);
+ Message_Block[62] = static_cast<unsigned char>((Length_Low >> 8) & 0xFF);
+ Message_Block[63] = static_cast<unsigned char>((Length_Low) & 0xFF);
* CircularShift
@@ -602,12 +619,13 @@
* Comments:
- unsigned CircularShift(int bits, unsigned word)
- return ((word << bits) & 0xFFFFFFFF) | ((word & 0xFFFFFFFF) >> (32-bits));
+ unsigned CircularShift(int bits, unsigned word)
+ return ((word << bits) & 0xFFFFFFFF) | ((word & 0xFFFFFFFF) >> (32-bits));
private:
unsigned H[5]; // Message digest buffers
unsigned Length_Low; // Message length in bits
Modified: trunk/include/liblas/guid.hpp
--- trunk/include/liblas/guid.hpp (original)
+++ trunk/include/liblas/guid.hpp Mon Apr 20 11:59:30 2009
@@ -435,7 +435,7 @@
detail::SHA1 sha1;
sha1.Input(namespace_guid.data_, namespace_guid.static_size);
sha1.Input(name, name_length);
- unsigned int digest[5];
+ unsigned int digest[5] = { 0 };
if (sha1.Result(digest) == false)
Modified: trunk/test/unit/lasfile_test.cpp
--- trunk/test/unit/lasfile_test.cpp (original)
+++ trunk/test/unit/lasfile_test.cpp Mon Apr 20 11:59:30 2009
@@ -10,6 +10,7 @@
#include <liblas/lasreader.hpp>
#include <liblas/laswriter.hpp>
#include <tut/tut.hpp>
+#include <iostream>
#include <stdexcept>
#include <string>
#include "liblas_test.hpp"
@@ -30,7 +31,11 @@
~lasfile_data()
// remove temporary file after each test case
- std::remove(tmpfile_.c_str());
+ int const ret = std::remove(tmpfile_.c_str());
+ if (0 != ret)
+ std::cerr << "Failed to remove \'" << tmpfile_ << "\' file\n";
More information about the Liblas-commits
