[Liblas-commits] r1246 - in trunk: apps include/liblas src
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Apr 22 21:50:27 EDT 2009
Author: hobu
Date: Wed Apr 22 21:50:27 2009
New Revision: 1246
URL: http://liblas.org/changeset/1246
#ifdef's around the spatial indexing stuff for now
   trunk/apps/Makefile.am
   trunk/apps/lasindex.cpp
   trunk/include/liblas/lasreader.hpp
   trunk/src/Makefile.am
   trunk/src/lasreader.cpp
Modified: trunk/apps/Makefile.am
--- trunk/apps/Makefile.am	(original)
+++ trunk/apps/Makefile.am	Wed Apr 22 21:50:27 2009
@@ -21,7 +21,11 @@
 lasindex_SOURCES = lasindex.cpp
-bin_PROGRAMS = lasinfo las2las lasmerge las2txt txt2las ts2las lasindex
+bin_PROGRAMS = lasinfo las2las lasmerge las2txt txt2las ts2las
+if SPATIALINDEX_IS_CONFIG
+bin_PROGRAMS += lasindex
+endif
 bin_SCRIPTS = liblas-config
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp	(original)
+++ trunk/apps/lasindex.cpp	Wed Apr 22 21:50:27 2009
@@ -105,7 +105,7 @@
     LASHeader header = reader->GetHeader();
     std::cout << "number of points: " << header.GetPointRecordsCount() << std::endl;
-    for (int i=0; i< 23; i++) {
+    for (int i=0; i< header.GetPointRecordsCount(); i++) {
         bool read = reader->ReadPointAt(i);
         LASPoint p = reader->GetPoint();
         std::cout.precision(2);
Modified: trunk/include/liblas/lasreader.hpp
--- trunk/include/liblas/lasreader.hpp	(original)
+++ trunk/include/liblas/lasreader.hpp	Wed Apr 22 21:50:27 2009
@@ -47,8 +47,12 @@
 #include <liblas/laspoint.hpp>
 #include <liblas/lasvariablerecord.hpp>
 #include <liblas/lasspatialreference.hpp>
-#include <liblas/lasindex.hpp>
 #include <liblas/detail/fwd.hpp>
+#ifdef USE_SPATIALINDEX
+#include <liblas/lasindex.hpp>
+#endif
 // std
 #include <iosfwd>
 #include <string>
@@ -88,7 +92,9 @@
     void Index(std::string& filename);
     void Index();
     LASIndex* GetIndex();
+#endif
 private:
@@ -104,7 +110,12 @@
     std::vector<LASVariableRecord> m_vlrs;
     bool m_doindex;
     LASIndex* m_index;
+#else
+    typedef void* LASIndex;
+#endif
 } // namespace liblas
Modified: trunk/src/Makefile.am
--- trunk/src/Makefile.am	(original)
+++ trunk/src/Makefile.am	Wed Apr 22 21:50:27 2009
@@ -23,7 +23,6 @@
 	laserror.cpp \
 	laspoint.cpp \
 	lasheader.cpp \
-	lasindex.cpp \
 	lasvariablerecord.cpp \
 	lasreader.cpp \
 	laswriter.cpp \
@@ -43,5 +42,8 @@
 if GDAL_IS_CONFIG
 liblas_la_SOURCES += gt_wkt_srs.cpp
 endif
+liblas_la_SOURCES += lasindex.cpp
+endif
 liblas_la_LDFLAGS = -version-info 1:0:0
Modified: trunk/src/lasreader.cpp
--- trunk/src/lasreader.cpp	(original)
+++ trunk/src/lasreader.cpp	Wed Apr 22 21:50:27 2009
@@ -58,7 +58,9 @@
     m_pimpl(detail::ReaderFactory::Create(ifs)),
     m_doindex(false)
     m_index = 0;
+#endif
     Init();
@@ -66,7 +68,9 @@
     // empty, but required so we can implement PIMPL using
     // std::auto_ptr with incomplete type (Reader).
     if (m_index != 0) delete m_index;
+#endif
 std::size_t LASReader::GetVersion() const
@@ -93,7 +97,10 @@
 bool LASReader::ReadPointAt(std::size_t n)
     bool ret = m_pimpl->ReadPointAt(n, m_point, m_header);
     if (m_doindex) m_index->insert(m_point, n);
+#endif
     return ret;
@@ -152,20 +159,25 @@
 void LASReader::Index()
     m_doindex = true;
     m_index = new LASIndex();
+#endif
 void LASReader::Index(std::string& filename)
     m_doindex = true;
     m_index = new LASIndex(filename);
+#endif
 LASIndex* LASReader::GetIndex()
     return m_index;
+#endif
More information about the Liblas-commits mailing list
