[Liblas-commits] r1333 - branches/1.2/python/tests
liblas-commits at liblas.org liblas-commits at liblas.org
Sun Aug 2 00:47:12 EDT 2009
Author: hobu
Date: Sun Aug  2 00:47:12 2009
New Revision: 1333
URL: http://liblas.org/changeset/1333
new test for #134
   branches/1.2/python/tests/SRS.txt
Modified: branches/1.2/python/tests/SRS.txt
--- branches/1.2/python/tests/SRS.txt	(original)
+++ branches/1.2/python/tests/SRS.txt	Sun Aug  2 00:47:12 2009
@@ -1,4 +1,5 @@
   >>> from liblas import srs
+  >>> from liblas import point
   >>> import liblas
   >>> s = srs.SRS()
   >>> s.proj4
@@ -59,3 +60,49 @@
   True
   >>> del f
+  >>> f = file.File('../test/data/1.2_3.las',mode='r')
+  >>> f.header.data_offset
+  438L
+  >>> utm_wkt = """PROJCS["NAD83 / UTM zone 15N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26915"]]"""
+  >>> dd_wkt = """GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"""
+  >>> s_dd = srs.SRS()
+  >>> s_dd.wkt = dd_wkt
+  >>> s_utm = srs.SRS()
+  >>> s_utm.wkt = utm_wkt
+  >>> p = f.read(0)
+  >>> origx, origy = p.x, p.y
+  >>> origx, origy
+  (470692.44, 4602888.9000000004)
+  >>> f.set_srs(s_dd)
+  True
+  >>> p = f.read(0)
+  >>> p.descale(f.header)
+  >>> p.x, p.y
+  (-92.999999999999972, 89.999999999999972)
+  >>> dd_header = f.header
+  >>> dd_header.scale = [0.000001,0.000001,0.000001]
+  >>> dd_header.srs = s_dd
+  >>> f_project = file.File('junk_srs_project.las',mode='w',header=dd_header)
+  >>> dd_header.srs.proj4
+  '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs '
+  >>> f_project.write(p);f_project.write(p);f_project.write(p)
+  >>> f_project.close()
+  >>> del f_project
+  >>> f3 = file.File('junk_srs_project.las')
+  >>> f3.header.data_offset
+  476L
+  >>> p3 = f3.read(1)
+  >>> p3.x, p3.y
+  (-92.999999000000003, 89.999999000000003)
+  >>> p3 = f3.read(0)
+  >>> p3.x,p3.y
+  >>> import os
+  >>> os.remove('junk_srs_project.las')
\ No newline at end of file
More information about the Liblas-commits mailing list
