[Liblas-commits] r1339 - trunk
liblas-commits at liblas.org
Fri Aug 14 20:04:47 EDT 2009
Author: mloskot
Date: Fri Aug 14 20:04:46 2009
New Revision: 1339
URL: http://liblas.org/changeset/1339
Improved reporting of Boost detection from ./configure script.
trunk/configure.ac
Modified: trunk/configure.ac
--- trunk/configure.ac (original)
+++ trunk/configure.ac Fri Aug 14 20:04:46 2009
@@ -280,7 +280,12 @@
AX_BOOST_BASE()
AM_CONDITIONAL([BOOST_IS_CONFIG], [test ! x$HAVE_BOOST = xno])
-echo ${HAVE_BOOST}
+AC_MSG_CHECKING([if Boost C++ Libraries support requested and configured])
+if test -z ${HAVE_BOOST}; then
+ HAVE_BOOST="no"
+fi
+AC_MSG_RESULT([$HAVE_BOOST])
if test "${HAVE_BOOST}" == "yes" ; then
HAVE_BOOST="yes"
LIBS="$BOOST_LDFLAGS -lboost_iostreams-gcc40-mt $LIBS"
More information about the Liblas-commits
