[Liblas-commits] r986 - trunk/test/sample
liblas-commits at liblas.org
Tue Feb 3 09:50:12 EST 2009
Author: mloskot
Date: Tue Feb 3 09:50:12 2009
New Revision: 986
URL: http://liblas.org/changeset/986
Added print_point() function to sample/utility.hpp header.
trunk/test/sample/utility.hpp
Modified: trunk/test/sample/utility.hpp
--- trunk/test/sample/utility.hpp (original)
+++ trunk/test/sample/utility.hpp Tue Feb 3 09:50:12 2009
@@ -33,9 +33,59 @@
<< "\nnor: " << p.GetNumberOfReturns()
<< "\nsd: " << p.GetScanDirection()
<< "\neofl: " << p.GetFlightLineEdge()
- << "\ncls: " << p.GetClassification()
- << "\n";
+ << "\ntime: " << p.GetTime()
+ << std::endl;
return os;
+inline void print_point(std::ostream& os, liblas::LASPoint const& p, liblas::uint8_t const& minor)
+ os << std::fixed << std::setprecision(6)
+ << "\nx: " << p.GetX()
+ << "\ny: " << p.GetY()
+ << "\nz: " << p.GetZ()
+ << "\nint: " << p.GetIntensity()
+ << "\nrn: " << p.GetReturnNumber()
+ << "\nnor: " << p.GetNumberOfReturns()
+ << "\nsd: " << p.GetScanDirection()
+ << "\neofl: " << p.GetFlightLineEdge()
+ << "\ntime: " << p.GetTime();
+ if (1 == minor)
+ const int len = 13;
+ static std::string meaning[len] =
+ "Created, never classified",
+ "Unclassified",
+ "Ground",
+ "Low Vegetation",
+ "Medium Vegetation",
+ "High Vegetation",
+ "Building",
+ "Low Point (noise)",
+ "Model Key-point (mass point)",
+ "Water",
+ "Reserved for ASPRS Definition",
+ "Overlap Points",
+ // bit 0:4
+ liblas::uint8_t chClass = p.GetClassification();
+ unsigned int idx = (unsigned int)((chClass >> 3) & 0x1F);
+ std::cout << "\nClassification: "
+ << ((idx >= 0 && idx < len) ? meaning[idx] : "Reserved for ASPRS Definition");
+ std::cout << "\n- Synthetic: " << ((1 == (short)((chClass >> 2) & 0x1)) ? -1 : 0);
+ std::cout << "\n- Model_Key_Point: " << ((1 == (short)((chClass >> 1) & 0x1)) ? -1 : 0);
+ std::cout << "\n- Withheld: " << ((1 == (short)(chClass & 0x1)) ? -1 : 0);
+ else
+ std::cout << "\ncls: " << (int)p.GetClassification();
+ std::cout << std::endl;
#endif // LIBLAS_SAMPLE_UTILITY_HPP_INCLUDED
More information about the Liblas-commits
