[Liblas-commits] r992 - in trunk/build/xcode: . xcode.xcodeproj
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 3 22:26:01 EST 2009
Author: hobu
Date: Tue Feb  3 22:26:01 2009
New Revision: 992
URL: http://liblas.org/changeset/992
xcode projects
   trunk/build/xcode/   (props changed)
   trunk/build/xcode/xcode.xcodeproj/hobu.mode1v3
   trunk/build/xcode/xcode.xcodeproj/hobu.pbxuser
   trunk/build/xcode/xcode.xcodeproj/project.pbxproj
Modified: trunk/build/xcode/xcode.xcodeproj/hobu.mode1v3
--- trunk/build/xcode/xcode.xcodeproj/hobu.mode1v3	(original)
+++ trunk/build/xcode/xcode.xcodeproj/hobu.mode1v3	Tue Feb  3 22:26:01 2009
@@ -216,10 +216,10 @@
 						<key>_historyCapacity</key>
 						<integer>0</integer>
 						<key>bookmark</key>
-						<string>C800395D0F0C685F0080C499</string>
+						<string>C892EFC00F1FAAD800655EE0</string>
 						<key>history</key>
 						<array>
-							<string>C80038A90F0C3CF90080C499</string>
+							<string>C8D9E04D0F13E27D00CD654B</string>
 						</array>
 					</dict>
 					<key>SplitCount</key>
@@ -231,11 +231,11 @@
 			<key>Geometry</key>
 			<dict>
 				<key>Frame</key>
-				<string>{{0, 20}, {1246, 837}}</string>
+				<string>{{0, 20}, {1246, 590}}</string>
 				<key>PBXModuleWindowStatusBarHidden2</key>
 				<false/>
 				<key>RubberWindowFrame</key>
-				<string>107 211 1246 878 0 0 1920 1178 </string>
+				<string>5 147 1246 631 0 0 1280 778 </string>
 			</dict>
 		</dict>
 	</array>
@@ -312,26 +312,18 @@
 								<string>C80037E80F0C3B200080C499</string>
 								<string>C80038250F0C3B210080C499</string>
 								<string>1C37FBAC04509CD000000102</string>
-								<string>C80039370F0C617C0080C499</string>
-								<string>C80039380F0C617C0080C499</string>
-								<string>C80039390F0C617C0080C499</string>
-								<string>C800393A0F0C617C0080C499</string>
-								<string>C800393B0F0C617C0080C499</string>
-								<string>C800393C0F0C617C0080C499</string>
-								<string>C800393D0F0C617C0080C499</string>
-								<string>C800393E0F0C617C0080C499</string>
 								<string>1C37FAAC04509CD000000102</string>
 								<string>1C37FABC05509CD000000102</string>
 							</array>
 							<key>PBXSmartGroupTreeModuleOutlineStateSelectionKey</key>
 							<array>
 								<array>
-									<integer>19</integer>
-									<integer>0</integer>
+									<integer>28</integer>
+									<integer>25</integer>
 								</array>
 							</array>
 							<key>PBXSmartGroupTreeModuleOutlineStateVisibleRectKey</key>
-							<string>{{0, 0}, {259, 895}}</string>
+							<string>{{0, 0}, {259, 573}}</string>
 						</dict>
 						<key>PBXTopSmartGroupGIDs</key>
 						<array/>
@@ -343,14 +335,14 @@
 					<key>GeometryConfiguration</key>
 					<dict>
 						<key>Frame</key>
-						<string>{{0, 0}, {276, 913}}</string>
+						<string>{{0, 0}, {276, 591}}</string>
 						<key>GroupTreeTableConfiguration</key>
 						<array>
 							<string>MainColumn</string>
 							<real>259</real>
 						</array>
-						<string>252 222 1521 954 0 0 1920 1178 </string>
+						<string>75 146 1440 632 0 0 1280 778 </string>
 					</dict>
 					<key>Module</key>
 					<string>PBXSmartGroupTreeModule</string>
@@ -378,18 +370,16 @@
 										<key>bookmark</key>
-										<string>C800395C0F0C685F0080C499</string>
+										<string>C892EFBF0F1FAAD800655EE0</string>
 										<key>history</key>
 										<array>
 											<string>C80038F00F0C60870080C499</string>
-											<string>C80038F10F0C60870080C499</string>
 											<string>C80038F30F0C60870080C499</string>
-											<string>C80038F40F0C60870080C499</string>
+											<string>C8D9E04A0F13E27D00CD654B</string>
 										</array>
 										<key>prevStack</key>
 										<array>
 											<string>C80038F50F0C60870080C499</string>
-											<string>C80038F60F0C60870080C499</string>
 											<string>C80038F80F0C60870080C499</string>
 										</array>
 									</dict>
@@ -402,14 +392,14 @@
 							<dict>
 								<key>Frame</key>
-								<string>{{0, 0}, {1240, 577}}</string>
+								<string>{{0, 0}, {1159, 372}}</string>
 							</dict>
 							<key>Module</key>
 							<string>PBXNavigatorGroup</string>
 							<key>Proportion</key>
-							<string>577pt</string>
+							<string>372pt</string>
 						</dict>
 						<dict>
 							<key>ContentConfiguration</key>
@@ -422,18 +412,18 @@
 							<dict>
 								<key>Frame</key>
-								<string>{{0, 582}, {1240, 331}}</string>
+								<string>{{0, 377}, {1159, 214}}</string>
 							</dict>
 							<key>Module</key>
 							<string>XCDetailModule</string>
-							<string>331pt</string>
+							<string>214pt</string>
 						</dict>
 					</array>
-					<string>1240pt</string>
+					<string>1159pt</string>
 				</dict>
 			</array>
 			<key>Name</key>
@@ -448,9 +438,9 @@
 			</array>
 			<key>TableOfContents</key>
 			<array>
-				<string>C80038FA0F0C60870080C499</string>
+				<string>C892EFBB0F1FAAD800655EE0</string>
 				<string>1CE0B1FE06471DED0097A5F4</string>
-				<string>C80038FB0F0C60870080C499</string>
+				<string>C892EFBC0F1FAAD800655EE0</string>
 				<string>1CE0B20306471E060097A5F4</string>
 				<string>1CE0B20506471E060097A5F4</string>
 			</array>
@@ -584,15 +574,12 @@
 	<integer>5</integer>
 	<key>WindowOrderList</key>
 	<array>
-		<string>1C0AD2AF069F1E9B00FABCE6</string>
-		<string>1C78EAAD065D492600B07095</string>
-		<string>1CD10A99069EF8BA00B06720</string>
-		<string>C80038FD0F0C60870080C499</string>
 		<string>C80039000F0C60870080C499</string>
-		<string>/Users/hobu/svn/liblas/trunk/build/xcode/xcode.xcodeproj</string>
+		<string>C80038FD0F0C60870080C499</string>
+		<string>/Users/hobu/dev/svn/liblas/trunk/build/xcode/xcode.xcodeproj</string>
 	</array>
 	<key>WindowString</key>
 	<key>WindowToolsV3</key>
 	<array>
 		<dict>
@@ -613,27 +600,27 @@
 								<key>PBXProjectModuleGUID</key>
 								<string>1CD0528F0623707200166675</string>
 								<key>PBXProjectModuleLabel</key>
-								<string>file.cpp</string>
+								<string></string>
 								<key>StatusBarVisibility</key>
 								<true/>
 							</dict>
 							<dict>
 								<key>Frame</key>
-								<string>{{0, 0}, {1033, 250}}</string>
+								<string>{{0, 0}, {1033, 99}}</string>
-								<string>2084 405 1033 532 1920 0 1920 1200 </string>
+								<string>56 246 1033 532 0 0 1280 778 </string>
 							</dict>
 							<key>Module</key>
-							<string>250pt</string>
+							<string>99pt</string>
 						</dict>
 						<dict>
-							<key>BecomeActive</key>
-							<true/>
 							<dict>
+								<key>PBXBuildLogShowsTranscriptDefaultKey</key>
+								<string>{{0, 90}, {1033, 297}}</string>
 								<string>XCMainBuildResultsModuleGUID</string>
@@ -646,14 +633,14 @@
 							<dict>
 								<key>Frame</key>
-								<string>{{0, 255}, {1033, 236}}</string>
+								<string>{{0, 104}, {1033, 387}}</string>
 							</dict>
 							<key>Module</key>
 							<string>PBXBuildResultsModule</string>
-							<string>236pt</string>
+							<string>387pt</string>
 						</dict>
 					</array>
@@ -671,18 +658,18 @@
 			<array>
-				<string>C80039010F0C60870080C499</string>
+				<string>C892EFBE0F1FAAD800655EE0</string>
 			</array>
 			<key>ToolbarConfiguration</key>
 			<string>xcode.toolbar.config.buildV3</string>
 			<key>WindowToolGUID</key>
 			<key>WindowToolIsVisible</key>
-			<true/>
+			<false/>
 		</dict>
 		<dict>
 			<key>FirstTimeWindowDisplayed</key>
Modified: trunk/build/xcode/xcode.xcodeproj/hobu.pbxuser
--- trunk/build/xcode/xcode.xcodeproj/hobu.pbxuser	(original)
+++ trunk/build/xcode/xcode.xcodeproj/hobu.pbxuser	Tue Feb  3 22:26:01 2009
@@ -3,7 +3,7 @@
 	0867D690FE84028FC02AAC07 /* Project object */ = {
 		activeBuildConfigurationName = Debug;
 		activeExecutable = C800390F0F0C60D10080C499 /* las2las */;
-		activeTarget = C800390D0F0C60D10080C499 /* las2las */;
+		activeTarget = D2AAC09C05546B4700DB518D /* libLAS.dylib */;
 		addToTargets = (
 			C80039290F0C613F0080C499 /* txt2las */,
@@ -35,7 +35,7 @@
 				PBXFileTableDataSourceColumnSortingKey = PBXFileDataSource_Filename_ColumnID;
 				PBXFileTableDataSourceColumnWidthsKey = (
 					20,
-					1001,
+					920,
 					20,
 					48,
 					43,
@@ -57,7 +57,7 @@
 					20,
-					961,
+					880,
 					60,
 					20,
 					48,
@@ -74,30 +74,18 @@
 					PBXFileDataSource_Warnings_ColumnID,
-			PBXPerProjectTemplateStateSaveDate = 252459712;
-			PBXWorkspaceStateSaveDate = 252459712;
+			PBXPerProjectTemplateStateSaveDate = 253733541;
+			PBXWorkspaceStateSaveDate = 253733541;
 		perUserProjectItems = {
-			C80038A90F0C3CF90080C499 /* PBXTextBookmark */ = C80038A90F0C3CF90080C499 /* PBXTextBookmark */;
 			C80038F00F0C60870080C499 /* PBXTextBookmark */ = C80038F00F0C60870080C499 /* PBXTextBookmark */;
-			C80038F10F0C60870080C499 /* XDModelBookmark */ = C80038F10F0C60870080C499 /* XDModelBookmark */;
 			C80038F30F0C60870080C499 /* PBXTextBookmark */ = C80038F30F0C60870080C499 /* PBXTextBookmark */;
-			C80038F40F0C60870080C499 /* PBXBookmark */ = C80038F40F0C60870080C499 /* PBXBookmark */;
 			C80038F50F0C60870080C499 /* PBXTextBookmark */ = C80038F50F0C60870080C499 /* PBXTextBookmark */;
-			C80038F60F0C60870080C499 /* XDModelBookmark */ = C80038F60F0C60870080C499 /* XDModelBookmark */;
 			C80038F80F0C60870080C499 /* PBXTextBookmark */ = C80038F80F0C60870080C499 /* PBXTextBookmark */;
-			C80038F90F0C60870080C499 /* PBXTextBookmark */ = C80038F90F0C60870080C499 /* PBXTextBookmark */;
-			C80038FF0F0C60870080C499 /* PBXTextBookmark */ = C80038FF0F0C60870080C499 /* PBXTextBookmark */;
-			C800393F0F0C617C0080C499 /* PBXTextBookmark */ = C800393F0F0C617C0080C499 /* PBXTextBookmark */;
-			C80039400F0C617C0080C499 /* PBXTextBookmark */ = C80039400F0C617C0080C499 /* PBXTextBookmark */;
-			C800394C0F0C61D20080C499 /* PBXTextBookmark */ = C800394C0F0C61D20080C499 /* PBXTextBookmark */;
-			C800394D0F0C61D20080C499 /* PBXTextBookmark */ = C800394D0F0C61D20080C499 /* PBXTextBookmark */;
-			C80039550F0C68260080C499 /* PBXTextBookmark */ = C80039550F0C68260080C499 /* PBXTextBookmark */;
-			C80039560F0C68260080C499 /* PBXTextBookmark */ = C80039560F0C68260080C499 /* PBXTextBookmark */;
-			C80039590F0C685D0080C499 /* PBXTextBookmark */ = C80039590F0C685D0080C499 /* PBXTextBookmark */;
-			C800395A0F0C685D0080C499 /* PBXTextBookmark */ = C800395A0F0C685D0080C499 /* PBXTextBookmark */;
-			C800395C0F0C685F0080C499 /* PBXTextBookmark */ = C800395C0F0C685F0080C499 /* PBXTextBookmark */;
-			C800395D0F0C685F0080C499 /* PBXTextBookmark */ = C800395D0F0C685F0080C499 /* PBXTextBookmark */;
+			C892EFBF0F1FAAD800655EE0 /* PBXTextBookmark */ = C892EFBF0F1FAAD800655EE0 /* PBXTextBookmark */;
+			C892EFC00F1FAAD800655EE0 /* PBXTextBookmark */ = C892EFC00F1FAAD800655EE0 /* PBXTextBookmark */;
+			C8D9E04A0F13E27D00CD654B /* PBXTextBookmark */ = C8D9E04A0F13E27D00CD654B /* PBXTextBookmark */;
+			C8D9E04D0F13E27D00CD654B /* PBXTextBookmark */ = C8D9E04D0F13E27D00CD654B /* PBXTextBookmark */;
 		sourceControlManager = C80037E60F0C3ADE0080C499 /* Source Control */;
 		userBuildSettings = {
@@ -116,9 +104,10 @@
 	C80038020F0C3B210080C499 /* file.cpp */ = {
 		uiCtxt = {
-			sepNavIntBoundsRect = "{{0, 0}, {1187, 2839}}";
+			sepNavIntBoundsRect = "{{0, 0}, {1187, 2352}}";
 			sepNavSelRange = "{2208, 34}";
-			sepNavVisRange = "{0, 2344}";
+			sepNavVisRange = "{406, 1957}";
+			sepNavWindowFrame = "{{5, 91}, {1246, 687}}";
 	C800381B0F0C3B210080C499 /* lasfile.cpp */ = {
@@ -135,14 +124,6 @@
 			sepNavVisRange = "{0, 1609}";
-	C80038A90F0C3CF90080C499 /* PBXTextBookmark */ = {
-		isa = PBXTextBookmark;
-		comments = "error: liblas/detail/file.hpp: No such file or directory";
-		fRef = C80038020F0C3B210080C499 /* file.cpp */;
-		rLen = 1;
-		rLoc = 42;
-		rType = 1;
 	C80038C20F0C5E230080C499 /* lasinfo */ = {
 		activeExec = 0;
 		executables = (
@@ -175,9 +156,9 @@
 	C80038D10F0C5F2E0080C499 /* lascommon.c */ = {
 		uiCtxt = {
-			sepNavIntBoundsRect = "{{0, 0}, {1179, 9724}}";
+			sepNavIntBoundsRect = "{{0, 0}, {1098, 8008}}";
 			sepNavSelRange = "{0, 0}";
-			sepNavVisRange = "{0, 745}";
+			sepNavVisRange = "{0, 535}";
 	C80038DB0F0C5FF10080C499 /* lasmerge */ = {
@@ -219,149 +200,6 @@
 		vrLen = 1609;
 		vrLoc = 0;
-	C80038F10F0C60870080C499 /* XDModelBookmark */ = {
-		isa = XDModelBookmark;
-		fRef = C80038F20F0C60870080C499 /* xcode_6.xcclassmodel */;
-		fallbackIsa = PBXBookmark;
-		uiCtxt = {
-			UIContextForClassArea = {
-				_indexOfSelectedView = 0;
-				chosenTableColumnns = (
-					"CT Class",
-					"CT Kind",
-					"CT Superclass",
-					"CT Documentation",
-				chosenTableColumnns_sortDirections = (
-				chosenTableColumnns_sortKeys = (
-				chosenTableColumnns_sortSelectors = (
-				chosenTableWidths = (
-					76.000000,
-					45.000000,
-					94.454102,
-					22.000000,
-			UIContextForDetailArea = {
-				_indexOfSelectedView = 1;
-			UIContextForLayoutManager = {
-				detailSplitGeometry = {
-					_collapsingFrameDimension = 0;
-					_indexOfCollapsedView = 0;
-					_percentageOfCollapsedView = 0;
-					isCollapsed = yes;
-					sizes = (
-						"{{0, 0}, {808, 177}}",
-						"{{813, 0}, {425, 177}}",
-				diagramSplitGeometry = {
-					sizes = (
-						"{{0, 0}, {1238, 179}}",
-						"{{0, 184}, {1238, 376}}",
-				tableSplitGeometry = {
-					sizes = (
-						"{{0, 0}, {265, 177}}",
-						"{{270, 0}, {538, 177}}",
-			UIContextForPropertyArea = {
-				chosenTableColumnnsAT = (
-					"PR Type Icon",
-					"PR Member",
-					"PR Kind",
-					"PR Type",
-					"PR Visibility",
-					"PR Documentation",
-				chosenTableColumnnsAT_sortDirections = (
-				chosenTableColumnnsAT_sortKeys = (
-				chosenTableColumnnsAT_sortSelectors = (
-				chosenTableColumnnsPT = (
-					"AL Type Icon",
-					"AL Member",
-					"AL Kind",
-					"AL Type",
-					"AL Visibility",
-					"AL Documentation",
-				chosenTableColumnnsPT_sortDirections = (
-				chosenTableColumnnsPT_sortKeys = (
-				chosenTableColumnnsPT_sortSelectors = (
-				chosenTableColumnnsRT = (
-					"OP Type Icon",
-					"OP Member",
-					"OP Kind",
-					"OP Type",
-					"OP Visibility",
-					"OP Documentation",
-				chosenTableColumnnsRT_sortDirections = (
-				chosenTableColumnnsRT_sortKeys = (
-				chosenTableColumnnsRT_sortSelectors = (
-				chosenTableWidthsAT = (
-					22.000000,
-					122.000000,
-					66.000000,
-					82.000000,
-					44.000000,
-					22.000000,
-				chosenTableWidthsPT = (
-					22.000000,
-					122.000000,
-					61.000000,
-					87.000000,
-					189.000000,
-					22.000000,
-				chosenTableWidthsRT = (
-					22.000000,
-					122.000000,
-					62.000000,
-					86.000000,
-					44.000000,
-					22.000000,
-			"xdesign model browser state key - shown/hidden" = 1;
-			"xdesign model diagram view visible rect key" = "{{-288, 0}, {1223, 361}}";
-			"xdesign model selected entities key" = (
-			"xdesign model selected properties key" = (
-	C80038F20F0C60870080C499 /* xcode_6.xcclassmodel */ = {
-		isa = PBXFileReference;
-		path = xcode_6.xcclassmodel;
-		sourceTree = "<group>";
 	C80038F30F0C60870080C499 /* PBXTextBookmark */ = {
 		fRef = C800381B0F0C3B210080C499 /* lasfile.cpp */;
@@ -372,10 +210,6 @@
 		vrLen = 1541;
 		vrLoc = 0;
-	C80038F40F0C60870080C499 /* PBXBookmark */ = {
-		isa = PBXBookmark;
-		fRef = C80038D10F0C5F2E0080C499 /* lascommon.c */;
 	C80038F50F0C60870080C499 /* PBXTextBookmark */ = {
 		fRef = C80038440F0C3B210080C499 /* liblas.hpp */;
@@ -386,149 +220,6 @@
 		vrLen = 1609;
 		vrLoc = 0;
-	C80038F60F0C60870080C499 /* XDModelBookmark */ = {
-		fRef = C80038F70F0C60870080C499 /* xcode_6.xcclassmodel */;
-		uiCtxt = {
-					"CT Class",
-					"CT Kind",
-					"CT Superclass",
-					76.000000,
-					45.000000,
-					94.454102,
-					22.000000,
-					sizes = (
-					sizes = (
-					sizes = (
-					"PR Type Icon",
-					"PR Member",
-					"PR Kind",
-					"PR Type",
-					"PR Visibility",
-					"AL Type Icon",
-					"AL Member",
-					"AL Kind",
-					"AL Type",
-					"AL Visibility",
-					"OP Type Icon",
-					"OP Member",
-					"OP Kind",
-					"OP Type",
-					"OP Visibility",
-					22.000000,
-					122.000000,
-					66.000000,
-					82.000000,
-					44.000000,
-					22.000000,
-					22.000000,
-					122.000000,
-					61.000000,
-					87.000000,
-					189.000000,
-					22.000000,
-					22.000000,
-					122.000000,
-					62.000000,
-					86.000000,
-					44.000000,
-					22.000000,
-	C80038F70F0C60870080C499 /* xcode_6.xcclassmodel */ = {
 	C80038F80F0C60870080C499 /* PBXTextBookmark */ = {
@@ -539,26 +230,6 @@
 		vrLen = 1541;
 		vrLoc = 0;
-	C80038F90F0C60870080C499 /* PBXTextBookmark */ = {
-		name = "lascommon.c: 1";
-		rLen = 0;
-		rLoc = 0;
-		rType = 0;
-		vrLen = 745;
-		vrLoc = 0;
-	C80038FF0F0C60870080C499 /* PBXTextBookmark */ = {
-		name = "file.cpp: 43";
-		rLen = 34;
-		rLoc = 2208;
-		rType = 0;
-		vrLen = 2344;
-		vrLoc = 0;
 	C800390D0F0C60D10080C499 /* las2las */ = {
 		activeExec = 0;
 		executables = (
@@ -646,102 +317,44 @@
 		sourceDirectories = (
-	C800393F0F0C617C0080C499 /* PBXTextBookmark */ = {
-		rLen = 0;
-		rLoc = 0;
-		rType = 0;
-		vrLen = 745;
-		vrLoc = 0;
-	C80039400F0C617C0080C499 /* PBXTextBookmark */ = {
-		rLen = 34;
-		rLoc = 2208;
-		rType = 0;
-		vrLen = 2344;
-		vrLoc = 0;
-	C800394C0F0C61D20080C499 /* PBXTextBookmark */ = {
-		rLen = 0;
-		rLoc = 0;
-		rType = 0;
-		vrLen = 745;
-		vrLoc = 0;
-	C800394D0F0C61D20080C499 /* PBXTextBookmark */ = {
-		rLen = 34;
-		rLoc = 2208;
-		rType = 0;
-		vrLen = 2344;
-		vrLoc = 0;
-	C80039550F0C68260080C499 /* PBXTextBookmark */ = {
+	C892EFBF0F1FAAD800655EE0 /* PBXTextBookmark */ = {
 		rLen = 0;
 		rLoc = 0;
 		rType = 0;
-		vrLen = 745;
+		vrLen = 535;
 		vrLoc = 0;
-	C80039560F0C68260080C499 /* PBXTextBookmark */ = {
-		rLen = 34;
-		rLoc = 2208;
-		rType = 0;
-		vrLen = 2344;
-		vrLoc = 0;
-	C80039590F0C685D0080C499 /* PBXTextBookmark */ = {
-		rLen = 1;
-		rLoc = 42;
-		rType = 1;
-	C800395A0F0C685D0080C499 /* PBXTextBookmark */ = {
+	C892EFC00F1FAAD800655EE0 /* PBXTextBookmark */ = {
 		rLen = 34;
 		rLoc = 2208;
 		rType = 0;
-		vrLen = 236;
-		vrLoc = 2207;
+		vrLen = 1957;
+		vrLoc = 406;
-	C800395C0F0C685F0080C499 /* PBXTextBookmark */ = {
+	C8D9E04A0F13E27D00CD654B /* PBXTextBookmark */ = {
 		rLen = 0;
 		rLoc = 0;
 		rType = 0;
-		vrLen = 745;
+		vrLen = 675;
 		vrLoc = 0;
-	C800395D0F0C685F0080C499 /* PBXTextBookmark */ = {
+	C8D9E04D0F13E27D00CD654B /* PBXTextBookmark */ = {
 		rLen = 34;
 		rLoc = 2208;
 		rType = 0;
-		vrLen = 2344;
+		vrLen = 2363;
 		vrLoc = 0;
 	D2AAC09C05546B4700DB518D /* libLAS.dylib */ = {
Modified: trunk/build/xcode/xcode.xcodeproj/project.pbxproj
--- trunk/build/xcode/xcode.xcodeproj/project.pbxproj	(original)
+++ trunk/build/xcode/xcode.xcodeproj/project.pbxproj	Tue Feb  3 22:26:01 2009
@@ -72,35 +72,35 @@
 			isa = PBXContainerItemProxy;
 			containerPortal = 0867D690FE84028FC02AAC07 /* Project object */;
 			proxyType = 1;
-			remoteGlobalIDString = D2AAC09C05546B4700DB518D /* libLAS.dylib */;
+			remoteGlobalIDString = D2AAC09C05546B4700DB518D;
 			remoteInfo = libLAS.dylib;
 		C80039430F0C61AA0080C499 /* PBXContainerItemProxy */ = {
 			proxyType = 1;
 		C80039450F0C61B30080C499 /* PBXContainerItemProxy */ = {
 			proxyType = 1;
 		C80039470F0C61BA0080C499 /* PBXContainerItemProxy */ = {
 			proxyType = 1;
 		C80039490F0C61C30080C499 /* PBXContainerItemProxy */ = {
 			proxyType = 1;
 /* End PBXContainerItemProxy section */
@@ -155,11 +155,11 @@
 		C80038D10F0C5F2E0080C499 /* lascommon.c */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.c; name = lascommon.c; path = ../../apps/lascommon.c; sourceTree = SOURCE_ROOT; };
 		C80038DC0F0C5FF10080C499 /* lasmerge */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; path = lasmerge; sourceTree = BUILT_PRODUCTS_DIR; };
 		C80038E10F0C60300080C499 /* lasmerge.c */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.c; name = lasmerge.c; path = ../../apps/lasmerge.c; sourceTree = SOURCE_ROOT; };
-		C800390E0F0C60D10080C499 /* las2las */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; name = las2las; path = build/Debug/las2las; sourceTree = "<group>"; };
+		C800390E0F0C60D10080C499 /* las2las */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; path = las2las; sourceTree = BUILT_PRODUCTS_DIR; };
 		C80039130F0C60F10080C499 /* las2las.c */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.c; name = las2las.c; path = ../../apps/las2las.c; sourceTree = SOURCE_ROOT; };
-		C800391B0F0C60FE0080C499 /* las2txt */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; name = las2txt; path = build/Debug/las2txt; sourceTree = "<group>"; };
+		C800391B0F0C60FE0080C499 /* las2txt */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; path = las2txt; sourceTree = BUILT_PRODUCTS_DIR; };
 		C80039220F0C612F0080C499 /* las2txt.c */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.c; name = las2txt.c; path = ../../apps/las2txt.c; sourceTree = SOURCE_ROOT; };
-		C800392A0F0C613F0080C499 /* txt2las */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; name = txt2las; path = build/Debug/txt2las; sourceTree = "<group>"; };
+		C800392A0F0C613F0080C499 /* txt2las */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; path = txt2las; sourceTree = BUILT_PRODUCTS_DIR; };
 		C80039300F0C61620080C499 /* txt2las.c */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.c; name = txt2las.c; path = ../../apps/txt2las.c; sourceTree = SOURCE_ROOT; };
 /* End PBXFileReference section */
More information about the Liblas-commits mailing list
