[Liblas-commits] r1004 - in trunk: include/liblas
include/liblas/detail python/tests src src/detail
liblas-commits at liblas.org
Mon Feb 9 22:34:17 EST 2009
Author: hobu
Date: Mon Feb 9 22:34:16 2009
New Revision: 1004
URL: http://liblas.org/changeset/1004
reorganize LASReader. Tests (cppUnit and Python) all still pass
trunk/include/liblas/detail/fwd.hpp
trunk/include/liblas/detail/reader.hpp
trunk/include/liblas/detail/reader10.hpp
trunk/include/liblas/detail/reader11.hpp
trunk/include/liblas/detail/reader12.hpp
trunk/include/liblas/detail/utility.hpp
trunk/include/liblas/laspoint.hpp
trunk/include/liblas/lasreader.hpp
trunk/python/tests/File.txt
trunk/src/detail/reader.cpp
trunk/src/detail/reader10.cpp
trunk/src/detail/reader11.cpp
trunk/src/detail/reader12.cpp
trunk/src/laspoint.cpp
trunk/src/lasreader.cpp
Modified: trunk/include/liblas/detail/fwd.hpp
--- trunk/include/liblas/detail/fwd.hpp (original)
+++ trunk/include/liblas/detail/fwd.hpp Mon Feb 9 22:34:16 2009
@@ -55,6 +55,7 @@
class Reader;
class Writer;
struct PointRecord;
+struct Color;
}} // namespace liblas::detail
Modified: trunk/include/liblas/detail/reader.hpp
--- trunk/include/liblas/detail/reader.hpp (original)
+++ trunk/include/liblas/detail/reader.hpp Mon Feb 9 22:34:16 2009
@@ -59,13 +59,12 @@
virtual ~Reader();
virtual std::size_t GetVersion() const = 0;
virtual bool ReadHeader(LASHeader& header) = 0;
- virtual bool ReadNextPoint(PointRecord& record) = 0;
- virtual bool ReadNextPoint(PointRecord& record, double& time) = 0;
- virtual bool ReadPointAt(std::size_t n, PointRecord& record) = 0;
- virtual bool ReadPointAt(std::size_t n, PointRecord& record, double& time) = 0;
+ virtual bool ReadNextPoint(LASPoint& point, const LASHeader& header) = 0;
+ virtual bool ReadPointAt(std::size_t n, LASPoint& point, const LASHeader& header) = 0;
virtual bool ReadVLR(LASHeader& header) = 0;
virtual bool ReadGeoreference(LASHeader& header) = 0;
virtual std::istream& GetStream() const = 0;
+ void FillPoint(PointRecord& record, LASPoint& point);
protected:
Modified: trunk/include/liblas/detail/reader10.hpp
--- trunk/include/liblas/detail/reader10.hpp (original)
+++ trunk/include/liblas/detail/reader10.hpp Mon Feb 9 22:34:16 2009
@@ -58,10 +58,8 @@
ReaderImpl(std::istream& ifs);
std::size_t GetVersion() const;
bool ReadHeader(LASHeader& header);
- bool ReadNextPoint(PointRecord& record);
- bool ReadNextPoint(PointRecord& record, double& time);
- bool ReadPointAt(std::size_t n, PointRecord& record);
- bool ReadPointAt(std::size_t n, PointRecord& record, double& time);
+ bool ReadNextPoint(LASPoint& point, const LASHeader& header);
+ bool ReadPointAt(std::size_t n, LASPoint& record, const LASHeader& header);
bool ReadVLR(LASHeader& header);
bool ReadGeoreference(LASHeader& header);
std::istream& GetStream() const;
Modified: trunk/include/liblas/detail/reader11.hpp
--- trunk/include/liblas/detail/reader11.hpp (original)
+++ trunk/include/liblas/detail/reader11.hpp Mon Feb 9 22:34:16 2009
@@ -58,10 +58,8 @@
- bool ReadNextPoint(detail::PointRecord& record);
- bool ReadNextPoint(detail::PointRecord& record, double& time);
Modified: trunk/include/liblas/detail/reader12.hpp
--- trunk/include/liblas/detail/reader12.hpp (original)
+++ trunk/include/liblas/detail/reader12.hpp Mon Feb 9 22:34:16 2009
@@ -58,10 +58,8 @@
Modified: trunk/include/liblas/detail/utility.hpp
--- trunk/include/liblas/detail/utility.hpp (original)
+++ trunk/include/liblas/detail/utility.hpp Mon Feb 9 22:34:16 2009
@@ -193,6 +193,17 @@
uint16_t point_source_id; // 1.0: User Bit field / 1.1: Point Source ID
+struct Color
+ Color() :
+ red(0), blue(0), green(0)
+ uint16_t red;
+ uint16_t blue;
+ uint16_t green;
template <typename T>
bool compare_distance(const T& actual, const T& expected);
Modified: trunk/include/liblas/laspoint.hpp
--- trunk/include/liblas/laspoint.hpp (original)
+++ trunk/include/liblas/laspoint.hpp Mon Feb 9 22:34:16 2009
@@ -44,6 +44,7 @@
#include <liblas/cstdint.hpp>
#include <liblas/detail/fwd.hpp>
+#include <liblas/detail/utility.hpp>
// std
#include <stdexcept> // std::out_of_range
#include <cstdlib> // std::size_t
@@ -187,6 +188,9 @@
bool Validate() const;
bool IsValid() const;
+ /// Scale the coordinates by the Offset and Scale in the given header
+ void ScaleCoordinates(const LASHeader& header);
private:
static std::size_t const coords_size = 3;
@@ -198,10 +202,10 @@
uint8_t m_userData;
uint16_t m_pointSourceId;
double m_gpsTime;
- uint16_t m_red;
- uint16_t m_green;
- uint16_t m_blue;
+ detail::Color m_color;
+ detail::PointRecord m_rec;
void throw_out_of_range() const
throw std::out_of_range("coordinate subscript out of range");
@@ -343,32 +347,32 @@
inline uint16_t LASPoint::GetRed() const
- return m_red;
+ return m_color.red;
inline void LASPoint::SetRed(uint16_t const& value)
- m_red = value;
+ m_color.red = value;
inline uint16_t LASPoint::GetBlue() const
- return m_blue;
+ return m_color.blue;
inline void LASPoint::SetBlue(uint16_t const& value)
- m_blue = value;
+ m_color.blue = value;
inline uint16_t LASPoint::GetGreen() const
- return m_green;
+ return m_color.green;
inline void LASPoint::SetGreen(uint16_t const& value)
- m_green = value;
+ m_color.green = value;
inline double& LASPoint::operator[](std::size_t const& n)
Modified: trunk/include/liblas/lasreader.hpp
--- trunk/include/liblas/lasreader.hpp (original)
+++ trunk/include/liblas/lasreader.hpp Mon Feb 9 22:34:16 2009
@@ -96,7 +96,7 @@
std::auto_ptr<detail::Reader> m_pimpl;
LASHeader m_header;
LASPoint m_point;
- detail::PointRecord m_record;
+// detail::PointRecord m_record;
std::vector<LASVLR> m_vlrs;
Modified: trunk/python/tests/File.txt
--- trunk/python/tests/File.txt (original)
+++ trunk/python/tests/File.txt Mon Feb 9 22:34:16 2009
@@ -97,4 +97,9 @@
>>> f.close()
>>> import os
- >>> os.remove('junk.las')
\ No newline at end of file
+ >>> os.remove('junk.las')
+ >>> f = file.File('junk.las2')
+ Traceback (most recent call last):
+ LASException: LASError in "LASReader_Create": can not open file /Users/hobu/svn/liblas/trunk/python/junk.las2
Modified: trunk/src/detail/reader.cpp
--- trunk/src/detail/reader.cpp (original)
+++ trunk/src/detail/reader.cpp Mon Feb 9 22:34:16 2009
@@ -62,6 +62,20 @@
+void Reader::FillPoint(PointRecord& record, LASPoint& point)
+ point.SetX(record.x);
+ point.SetY(record.y);
+ point.SetZ(record.z);
+ point.SetIntensity(record.intensity);
+ point.SetScanFlags(record.flags);
+ point.SetClassification(record.classification);
+ point.SetScanAngleRank(record.scan_angle_rank);
+ point.SetUserData(record.user_data);
+ point.SetPointSourceID(record.point_source_id);
Reader* ReaderFactory::Create(std::istream& ifs)
if (!ifs)
Modified: trunk/src/detail/reader10.cpp
--- trunk/src/detail/reader10.cpp (original)
+++ trunk/src/detail/reader10.cpp Mon Feb 9 22:34:16 2009
@@ -153,13 +153,22 @@
// 16. Point Data Format ID
read_n(n1, m_ifs, sizeof(n1));
- if (n1 == LASHeader::ePointFormat0)
+ if (n1 == LASHeader::ePointFormat0) {
header.SetDataFormatId(LASHeader::ePointFormat0);
- else if (n1 == LASHeader::ePointFormat1)
+ else if (n1 == LASHeader::ePointFormat1) {
header.SetDataFormatId(LASHeader::ePointFormat1);
- else
+ else if (n1 == LASHeader::ePointFormat2) {
+ header.SetDataFormatId(LASHeader::ePointFormat2);
+ else if (n1 == LASHeader::ePointFormat3) {
+ header.SetDataFormatId(LASHeader::ePointFormat3);
+ else {
throw std::domain_error("invalid point data format");
// 17. Point Data Record Length
// NOTE: No need to set record length because it's
// determined on basis of point data format.
@@ -243,7 +252,7 @@
header.AddVLR(vlr);
return true;
@@ -293,7 +302,7 @@
header.SetProj4(tmp);
return true;
@@ -302,11 +311,15 @@
return false;
-bool ReaderImpl::ReadNextPoint(detail::PointRecord& record)
+bool ReaderImpl::ReadNextPoint(LASPoint& point, const LASHeader& header)
// Read point data record format 0
// TODO: Replace with compile-time assert
+ detail::PointRecord record;
+ double t=0;
assert(LASHeader::ePointSize0 == sizeof(record));
if (0 == m_current)
@@ -328,33 +341,43 @@
return false;
+ Reader::FillPoint(record, point);
+ point.ScaleCoordinates(header);
+ if (header.GetDataFormatId() == LASHeader::ePointFormat1) {
+ detail::read_n(t, m_ifs, sizeof(double));
+ point.SetTime(t);
return true;
return false;
-bool ReaderImpl::ReadNextPoint(detail::PointRecord& record, double& time)
- // Read point data record format 1
- // TODO: Replace with compile-time assert
- assert(LASHeader::ePointSize1 == sizeof(record) + sizeof(time));
+// bool ReaderImpl::ReadNextPoint(LASPoint& point, double& time)
+// // Read point data record format 1
+// assert(LASHeader::ePointSize1 == sizeof(record) + sizeof(time));
+// bool hasData = ReadNextPoint(record);
+// if (hasData)
+// detail::read_n(time, m_ifs, sizeof(double));
+// return hasData;
- bool hasData = ReadNextPoint(record);
- if (hasData)
- detail::read_n(time, m_ifs, sizeof(double));
- return hasData;
-bool ReaderImpl::ReadPointAt(std::size_t n, PointRecord& record)
+bool ReaderImpl::ReadPointAt(std::size_t n, LASPoint& point, const LASHeader& header)
+ double t=0;
if (m_size <= n)
@@ -366,25 +389,33 @@
m_ifs.seekg(pos, std::ios::beg);
detail::read_n(record, m_ifs, sizeof(record));
- return true;
-bool ReaderImpl::ReadPointAt(std::size_t n, PointRecord& record, double& time)
- bool hasData = ReadPointAt(n, record);
- if (hasData)
+ point.SetTime(t);
- return hasData;
+ return true;
+// bool ReaderImpl::ReadPointAt(std::size_t n, PointRecord& record, double& time)
+// // TODO: Replace with compile-time assert
+// bool hasData = ReadPointAt(n, record);
+// if (hasData)
+// return hasData;
std::istream& ReaderImpl::GetStream() const
return m_ifs;
Modified: trunk/src/detail/reader11.cpp
--- trunk/src/detail/reader11.cpp (original)
+++ trunk/src/detail/reader11.cpp Mon Feb 9 22:34:16 2009
@@ -157,13 +157,22 @@
// 17. Point Data Format ID
- else
+ else {
// 18. Point Data Record Length
@@ -216,11 +225,14 @@
return true;
+ double t = 0;
if (0 == m_current)
@@ -242,33 +254,28 @@
return false;
+ point.SetTime(t);
return true;
return false;
- if (hasData)
- return hasData;
+ double t = 0;
if (m_size <= n)
@@ -280,23 +287,14 @@
- return true;
- if (hasData)
+ point.SetTime(t);
- return hasData;
+ return true;
Modified: trunk/src/detail/reader12.cpp
--- trunk/src/detail/reader12.cpp (original)
+++ trunk/src/detail/reader12.cpp Mon Feb 9 22:34:16 2009
@@ -225,11 +225,14 @@
return true;
+ double t = 0;
if (0 == m_current)
@@ -250,34 +253,46 @@
std::cerr << e.what() << std::endl;
return false;
+ // TODO: not working yet for the various point formats
+ // if (header.GetDataFormatId() == LASHeader::ePointFormat1) {
+ // detail::read_n(t, m_ifs, sizeof(double));
+ // point.SetTime(t);
return true;
return false;
- if (hasData)
- return hasData;
+// bool ReaderImpl::ReadNextPoint(detail::PointRecord& record, double& time)
+// if (hasData)
+// return hasData;
+ double t = 0;
if (m_size <= n)
@@ -289,25 +304,33 @@
- return true;
- if (hasData)
+ point.SetTime(t);
- return hasData;
+ return true;
+// if (hasData)
+// return hasData;
return m_ifs;
Modified: trunk/src/laspoint.cpp
--- trunk/src/laspoint.cpp (original)
+++ trunk/src/laspoint.cpp Mon Feb 9 22:34:16 2009
@@ -56,12 +56,12 @@
m_angleRank(0),
m_userData(0),
m_pointSourceId(0),
- m_gpsTime(0),
- m_red(0),
- m_green(0),
- m_blue(0)
+ m_gpsTime(0)
std::memset(m_coords, 0, sizeof(m_coords));
+ m_color.red = 0;
+ m_color.blue = 0;
+ m_color.green = 0;
LASPoint::LASPoint(LASPoint const& other) :
@@ -71,12 +71,12 @@
m_angleRank(other.m_angleRank),
m_userData(other.m_userData),
m_pointSourceId(other.m_pointSourceId),
- m_gpsTime(other.m_gpsTime),
- m_red(other.m_red),
- m_green(other.m_green),
- m_blue(other.m_blue)
+ m_gpsTime(other.m_gpsTime)
std::memcpy(m_coords, other.m_coords, sizeof(m_coords));
+ m_color.red = other.m_color.red;
+ m_color.blue = other.m_color.blue;
+ m_color.green = other.m_color.green;
LASPoint& LASPoint::operator=(LASPoint const& rhs)
@@ -93,9 +93,9 @@
m_userData = rhs.m_userData;
m_pointSourceId = rhs.m_pointSourceId;
m_gpsTime = rhs.m_gpsTime;
- m_red = rhs.m_red;
- m_green = rhs.m_green;
- m_blue = rhs.m_blue;
+ m_color.red = rhs.m_color.red;
+ m_color.blue = rhs.m_color.blue;
+ m_color.green = rhs.m_color.green;
return *this;
@@ -236,4 +236,16 @@
return true;
+void LASPoint::ScaleCoordinates(const LASHeader& header)
+ double const x = GetX() * header.GetScaleX() + header.GetOffsetX();
+ double const y = GetY() * header.GetScaleY() + header.GetOffsetY();
+ double const z = GetZ() * header.GetScaleZ() + header.GetOffsetZ();
+ SetCoordinates(x, y, z);
Modified: trunk/src/lasreader.cpp
--- trunk/src/lasreader.cpp (original)
+++ trunk/src/lasreader.cpp Mon Feb 9 22:34:16 2009
@@ -83,19 +83,8 @@
bool LASReader::ReadNextPoint()
bool ret = false;
- double time = 0;
-// std::cout << "Format id: " << m_header.GetDataFormatId() << std::endl;
- if (m_header.GetDataFormatId() == LASHeader::ePointFormat0)
- ret = m_pimpl->ReadNextPoint(m_record);
- else
- ret = m_pimpl->ReadNextPoint(m_record, time);
- if (ret)
- MakePoint(time);
+ ret = m_pimpl->ReadNextPoint(m_point, m_header);
return ret;
@@ -103,17 +92,8 @@
bool LASReader::ReadPointAt(std::size_t n)
bool ret = false;
- double time = 0;
- ret = m_pimpl->ReadPointAt(n, m_record);
- else
- ret = m_pimpl->ReadPointAt(n, m_record, time);
- if (ret)
- MakePoint(time);
+ ret = m_pimpl->ReadPointAt(n, m_point, m_header);
return ret;
@@ -126,19 +106,14 @@
bool ret = false;
- double time = 0;
- else
if (!ret)
throw std::out_of_range("no point record at given position");
- MakePoint(time);
return m_point;
@@ -165,18 +140,18 @@
void LASReader::MakePoint(double const& time)
- double const x = m_record.x * m_header.GetScaleX() + m_header.GetOffsetX();
- double const y = m_record.y * m_header.GetScaleY() + m_header.GetOffsetY();
- double const z = m_record.z * m_header.GetScaleZ() + m_header.GetOffsetZ();
- m_point.SetCoordinates(x, y, z);
- m_point.SetIntensity(m_record.intensity);
- m_point.SetScanFlags(m_record.flags);
- m_point.SetClassification(m_record.classification);
- m_point.SetScanAngleRank(m_record.scan_angle_rank);
- m_point.SetUserData(m_record.user_data);
- m_point.SetPointSourceID(m_record.point_source_id);
- m_point.SetTime(time);
+ // double const x = m_record.x * m_header.GetScaleX() + m_header.GetOffsetX();
+ // double const y = m_record.y * m_header.GetScaleY() + m_header.GetOffsetY();
+ // double const z = m_record.z * m_header.GetScaleZ() + m_header.GetOffsetZ();
+ // m_point.SetCoordinates(x, y, z);
+ // m_point.SetIntensity(m_record.intensity);
+ // m_point.SetScanFlags(m_record.flags);
+ // m_point.SetClassification(m_record.classification);
+ // m_point.SetScanAngleRank(m_record.scan_angle_rank);
+ // m_point.SetUserData(m_record.user_data);
+ // m_point.SetPointSourceID(m_record.point_source_id);
+ // m_point.SetTime(time);
std::istream& LASReader::GetStream() const
More information about the Liblas-commits
