[Liblas-commits] r1022 - in trunk: include/liblas
include/liblas/detail src src/detail
liblas-commits at liblas.org
Sun Feb 15 23:19:11 EST 2009
Author: hobu
Date: Sun Feb 15 23:19:09 2009
New Revision: 1022
URL: http://liblas.org/changeset/1022
more SRS stuff, quite broken right now unless you link GDAL in
trunk/include/liblas/detail/utility.hpp
trunk/include/liblas/lasheader.hpp
trunk/include/liblas/lassrs.hpp
trunk/src/detail/reader.cpp
trunk/src/lasheader.cpp
trunk/src/lassrs.cpp
Modified: trunk/include/liblas/detail/utility.hpp
--- trunk/include/liblas/detail/utility.hpp (original)
+++ trunk/include/liblas/detail/utility.hpp Sun Feb 15 23:19:09 2009
@@ -83,6 +83,18 @@
assert(0 != del_);
+ // FIXME: ooh, this is really, really bad. - hobu
+ raii_wrapper& operator=(raii_wrapper const& rhs)
+ if (&rhs != this)
+ p_ = rhs.p_;
+ del_ = NULL;
+ return *this;
~raii_wrapper()
do_delete(p_);
@@ -104,10 +116,11 @@
std::swap(p_, other.p_);
private:
raii_wrapper(raii_wrapper const& other);
- raii_wrapper& operator=(raii_wrapper const& rhs);
+ // raii_wrapper& operator=(raii_wrapper const& rhs);
void do_delete(T* p)
Modified: trunk/include/liblas/lasheader.hpp
--- trunk/include/liblas/lasheader.hpp (original)
+++ trunk/include/liblas/lasheader.hpp Sun Feb 15 23:19:09 2009
@@ -43,11 +43,12 @@
#ifndef LIBLAS_LASHEADER_HPP_INCLUDED
#define LIBLAS_LASHEADER_HPP_INCLUDED
+#include <liblas/lasrecordheader.hpp>
+#include <liblas/lassrs.hpp>
#include <liblas/cstdint.hpp>
#include <liblas/guid.hpp>
#include <liblas/detail/utility.hpp>
-#include <liblas/lasrecordheader.hpp>
-#include <liblas/lassrs.hpp>
+#include <liblas/detail/fwd.hpp>
//std
#include <string>
@@ -331,7 +332,10 @@
void SetGeoreference();
/// Fetch the georeference
- // LASSRS& GetSRS();
+ LASSRS& GetSRS();
+ /// Set the georeference
+ void SetSRS(LASSRS& srs);
private:
@@ -388,6 +392,7 @@
PointExtents m_extents;
std::vector<LASVLR> m_vlrs;
std::string m_proj4;
+ LASSRS m_srs;
} // namespace liblas
Modified: trunk/include/liblas/lassrs.hpp
--- trunk/include/liblas/lassrs.hpp (original)
+++ trunk/include/liblas/lassrs.hpp Sun Feb 15 23:19:09 2009
@@ -42,32 +42,16 @@
#ifndef LIBLAS_LASSRS_HPP_INCLUDED
#define LIBLAS_LASSRS_HPP_INCLUDED
-#include <liblas/lasheader.hpp>
-#include <liblas/cstdint.hpp>
#include <liblas/exception.hpp>
-#include <liblas/detail/utility.hpp>
-// GeoTIFF
-#ifdef HAVE_LIBGEOTIFF
-#include <geotiff.h>
-#include <geo_simpletags.h>
-#include "geo_normalize.h"
-#include "geo_simpletags.h"
-#include "geovalues.h"
-#endif // HAVE_LIBGEOTIFF
-// std
-#include <string>
// GDAL OSR
#ifdef HAVE_GDAL
-#include <ogr_srs_api.h>
+#include "ogr_srs_api.h"
#include "cpl_port.h"
#include "cpl_serv.h"
#include "geo_tiffp.h"
@@ -84,8 +68,8 @@
// GeoTIFF
+#include "geotiff.h"
+#include "geo_simpletags.h"
@@ -106,19 +90,27 @@
LASSRS();
- LASSRS(LASSRS const& other);
+ LASSRS(const std::vector<LASVLR>& vlrs);
+ ///LASSRS(LASSRS const& other);
LASSRS& operator=(LASSRS const& rhs);
std::string GetWKT() const;
void SetWKT(std::string const& v);
+ std::string GetProj4() const;
+ bool HasKeys();
private:
+ LASSRS(LASSRS const& other);
std::string m_wkt;
- GTIF* m_gtiff;
- ST_TIFF* m_tiff;
+ detail::raii_wrapper<ST_TIFF> m_tiff;
+ // detail::raii_wrapper<GTIF> m_gtiff;
protected:
Modified: trunk/src/detail/reader.cpp
--- trunk/src/detail/reader.cpp (original)
+++ trunk/src/detail/reader.cpp Sun Feb 15 23:19:09 2009
@@ -60,6 +60,7 @@
#include <cassert>
#include <cstdlib> // std::size_t
#include <stdexcept>
+#include <iostream>
namespace liblas { namespace detail {
@@ -127,57 +128,35 @@
bool Reader::ReadGeoreference(LASHeader& header)
-#ifndef HAVE_LIBGEOTIFF
- UNREFERENCED_PARAMETER(header);
-#else
+// #ifndef HAVE_LIBGEOTIFF
+// UNREFERENCED_PARAMETER(header);
+// #else
- std::string const uid("LASF_Projection");
- detail::raii_wrapper<ST_TIFF> st(ST_Create(), ST_Destroy);
+ std::vector<LASVLR> vlrs;
for (uint16_t i = 0; i < header.GetRecordsCount(); ++i)
LASVLR record = header.GetVLR(i);
- std::vector<uint8_t> data = record.GetData();
- if (uid == record.GetUserId(true).c_str() && 34735 == record.GetRecordId())
- int count = data.size()/sizeof(int16_t);
- ST_SetKey(st.get(), record.GetRecordId(), count, STT_SHORT, &(data[0]));
- if (uid == record.GetUserId(true).c_str() && 34736 == record.GetRecordId())
- int count = data.size() / sizeof(double);
- ST_SetKey(st.get(), record.GetRecordId(), count, STT_DOUBLE, &(data[0]));
- if (uid == record.GetUserId(true).c_str() && 34737 == record.GetRecordId())
- int count = data.size()/sizeof(uint8_t);
- ST_SetKey(st.get(), record.GetRecordId(), count, STT_ASCII, &(data[0]));
+ vlrs.push_back(record);
+ LASSRS* ref = new LASSRS(vlrs);
- if (st.get()->key_count)
- raii_wrapper<GTIF> gtif(GTIFNewSimpleTags(st.get()), GTIFFree);
- GTIFDefn defn;
- if (GTIFGetDefn(gtif.get(), &defn))
- char* proj4def = GTIFGetProj4Defn(&defn);
- std::string tmp(proj4def);
- std::free(proj4def);
- header.SetProj4(tmp);
+ LASSRS srs(vlrs);
+ header.SetSRS(srs);
+ header.SetProj4(ref->GetProj4());
+ std::cout << ref->GetWKT() << std::endl;
+ delete ref;
return true;
-#endif /* def HAVE_LIBGEOTIFF */
+//#endif /* def HAVE_LIBGEOTIFF */
- return false;
+// return false;
Reader* ReaderFactory::Create(std::istream& ifs)
Modified: trunk/src/lasheader.cpp
--- trunk/src/lasheader.cpp (original)
+++ trunk/src/lasheader.cpp Sun Feb 15 23:19:09 2009
@@ -44,6 +44,8 @@
// GeoTIFF
@@ -53,6 +55,7 @@
#include "geotiffio.h"
//std
#include <algorithm>
#include <fstream>
@@ -882,5 +885,10 @@
+void LASHeader::SetSRS(LASSRS& srs)
+ m_srs = srs;
Modified: trunk/src/lassrs.cpp
--- trunk/src/lassrs.cpp (original)
+++ trunk/src/lassrs.cpp Sun Feb 15 23:19:09 2009
@@ -41,52 +41,82 @@
namespace liblas {
-LASSRS::LASSRS()
+LASSRS::LASSRS() :
+ m_tiff(ST_Create(), ST_Destroy)
- detail::raii_wrapper<ST_TIFF> m_tiff(ST_Create(), ST_Destroy);
- detail::raii_wrapper<GTIF> m_gtiff(GTIFNewSimpleTags(m_tiff.get()), GTIFFree);
-// LASPoint::LASPoint(LASPoint const& other) :
-// m_intensity(other.m_intensity),
-// m_flags(other.m_flags),
-// m_class(other.m_class),
-// m_angleRank(other.m_angleRank),
-// m_userData(other.m_userData),
-// m_pointSourceId(other.m_pointSourceId),
-// m_gpsTime(other.m_gpsTime)
+LASSRS::LASSRS(const std::vector<LASVLR>& vlrs) :
+ std::string const uid("LASF_Projection");
+ for (uint16_t i = 0; i < vlrs.size(); ++i)
+ LASVLR record = vlrs[i];
+ std::vector<uint8_t> data = record.GetData();
+ if (uid == record.GetUserId(true).c_str() && 34735 == record.GetRecordId())
+ int count = data.size()/sizeof(int16_t);
+ ST_SetKey(m_tiff.get(), record.GetRecordId(), count, STT_SHORT, &(data[0]));
+ if (uid == record.GetUserId(true).c_str() && 34736 == record.GetRecordId())
+ int count = data.size() / sizeof(double);
+ ST_SetKey(m_tiff.get(), record.GetRecordId(), count, STT_DOUBLE, &(data[0]));
+ if (uid == record.GetUserId(true).c_str() && 34737 == record.GetRecordId())
+ int count = data.size()/sizeof(uint8_t);
+ ST_SetKey(m_tiff.get(), record.GetRecordId(), count, STT_ASCII, &(data[0]));
+bool LASSRS::HasKeys()
+ return (m_tiff.get()->key_count > 0);
+// LASSRS::LASSRS()
-// std::memcpy(m_coords, other.m_coords, sizeof(m_coords));
+// // m_tiff = NULL;
+// // m_gtiff = NULL;
-// LASPoint& LASPoint::operator=(LASPoint const& rhs)
+// LASSRS::LASSRS(LASSRS const& other) :
+// m_tiff(other.m_tiff),
+// m_gtiff(other.m_gtiff)
-// if (&rhs != this)
-// m_coords[0] = rhs.m_coords[0];
-// m_coords[1] = rhs.m_coords[1];
-// m_coords[2] = rhs.m_coords[2];
-// m_intensity = rhs.m_intensity;
-// m_flags = rhs.m_flags;
-// m_class = rhs.m_class;
-// m_angleRank = rhs.m_angleRank;
-// m_userData = rhs.m_userData;
-// m_pointSourceId = rhs.m_pointSourceId;
-// m_gpsTime = rhs.m_gpsTime;
-// return *this;
+LASSRS& LASSRS::operator=(LASSRS const& rhs)
+ if (&rhs != this)
+ m_tiff = rhs.m_tiff;
+ return *this;
/// Fetch the SRS as WKT
std::string LASSRS::GetWKT() const
- GTIFDefn sGTIFDefn;
+ GTIFDefn sGTIFDefn;
char* pszWKT = NULL;
- if( GTIFGetDefn( m_gtiff, &sGTIFDefn ) ) {
- pszWKT = GTIFGetOGISDefn( m_gtiff, &sGTIFDefn );
+ detail::raii_wrapper<GTIF> m_gtiff(GTIFNewSimpleTags(m_tiff.get()), GTIFFree);
+ if( GTIFGetDefn( m_gtiff.get(), &sGTIFDefn ) ) {
+ pszWKT = GTIFGetOGISDefn( m_gtiff.get(), &sGTIFDefn );
if (pszWKT) {
std::string tmp(pszWKT);
std::free(pszWKT);
@@ -102,6 +132,22 @@
m_wkt = v;
+std::string LASSRS::GetProj4() const
+ GTIFDefn defn;
+ if (GTIFGetDefn(m_gtiff.get(), &defn))
+ char* proj4def = GTIFGetProj4Defn(&defn);
+ std::string tmp(proj4def);
+ std::free(proj4def);
+ return tmp;
+ return std::string("");
More information about the Liblas-commits
