[Liblas-commits] r1041 - trunk
liblas-commits at liblas.org
Tue Feb 17 15:26:54 EST 2009
Author: hobu
Date: Tue Feb 17 15:26:53 2009
New Revision: 1041
URL: http://liblas.org/changeset/1041
apply Doug's patch for #66
trunk/configure.ac
Modified: trunk/configure.ac
--- trunk/configure.ac (original)
+++ trunk/configure.ac Tue Feb 17 15:26:53 2009
@@ -144,36 +144,41 @@
dnl #########################################################################
AC_ARG_WITH([geotiff],
- AC_HELP_STRING([--with-geotiff=ARG], [libgeotiff library to use (yes or path)]),,)
-AC_MSG_CHECKING([for libgeotiff])
+ AC_HELP_STRING([--with-geotiff=ARG], [libgeotiff library to use (no or path)]),,)
HAVE_GEOTIFF="no"
GEOTIFF_CONFIG="no"
-if test "$with_geotiff" = "no" -o "$with_geotiff" = "" ; then
- AC_MSG_RESULT([no])
-else
- GEOTIFF_CONFIG=external
+if test "$with_geotiff" != "no" -a "$with_geotiff" != "" ; then
dnl We now require libgeotiff 1.2.5 (for ST_Create the simpletags stuff).
dnl first check if $with_geotiff/lib has the library:
AC_CHECK_LIB([geotiff], [ST_Create],
[GEOTIFF_CONFIG=external], [GEOTIFF_CONFIG=no],
[-L$with_geotiff/lib])
fi
if test "${GEOTIFF_CONFIG}" != "no" ; then
- if test "${GEOTIFF_CONFIG}" = "external" ; then
- LIBS="-L$with_geotiff/lib -lgeotiff $LIBS"
- if test -d ${with_geotiff}/include ; then
- dnl Second path is for Debian using $prefix/include/geotiff/geotiff.h
- GEOTIFF_INC="-I$with_geotiff/include -I$with_geotiff/include/geotiff"
- AC_MSG_RESULT([using libgeotiff from $with_geotiff/include])
- fi
+ dnl libgeotiff 1.2.5, is first version with geo_simpletags.h
+ AC_MSG_CHECKING([for geo_simpletags.h of libgeotiff >= 1.2.5])
+ if test -f ${with_geotiff}/include/geo_simpletags.h ; then
+ GEOTIFF_INC="-I$with_geotiff/include"
+ AC_MSG_RESULT([yes])
+ elif test -f ${with_geotiff}/include/geotiff/geo_simpletags.h ; then
+ GEOTIFF_INC="-I$with_geotiff/include/geotiff"
+ else
+ GEOTIFF_CONFIG="no"
+ AC_MSG_RESULT([no])
fi
+fi
+AC_MSG_CHECKING([for libgeotiff])
+if test "${GEOTIFF_CONFIG}" = "no" ; then
+ HAVE_GEOTIFF="no"
+else
+ LIBS="-L$with_geotiff/lib -lgeotiff $LIBS"
HAVE_GEOTIFF="yes"
fi
AC_SUBST([GEOTIFF_INC])
More information about the Liblas-commits
