[Liblas-commits] r1048 - trunk/test/data
liblas-commits at liblas.org
Thu Feb 19 00:27:08 EST 2009
Author: hobu
Date: Thu Feb 19 00:27:08 2009
New Revision: 1048
URL: http://liblas.org/changeset/1048
make files more rigorous
trunk/test/data/1.0_0.las
trunk/test/data/1.0_1.las
trunk/test/data/1.1_0.las
trunk/test/data/1.1_1.las
trunk/test/data/1.2_0.las
trunk/test/data/1.2_1.las
trunk/test/data/1.2_2.las
trunk/test/data/1.2_3.las
trunk/test/data/make_data.py
Modified: trunk/test/data/1.0_0.las
Binary files. No diff available.
Modified: trunk/test/data/1.0_1.las
Modified: trunk/test/data/1.1_0.las
Modified: trunk/test/data/1.1_1.las
Modified: trunk/test/data/1.2_0.las
Modified: trunk/test/data/1.2_1.las
Modified: trunk/test/data/1.2_2.las
Modified: trunk/test/data/1.2_3.las
Modified: trunk/test/data/make_data.py
--- trunk/test/data/make_data.py (original)
+++ trunk/test/data/make_data.py Thu Feb 19 00:27:08 2009
@@ -20,9 +20,10 @@
c.green=12
c.blue=234
p.color = c
-p.time = datetime.datetime.now()
+p.time = datetime.datetime(2008,3,19)
+p.classification = 2
+p.return_number = 2
-print p.time
def write_file(version, format):
h = header.Header()
@@ -30,7 +31,11 @@
h.dataformat_id = format
h.major_version = 1
h.minor_version = version
+ h.min = [p.x, p.y, p.z]
+ h.max = [p.x, p.y, p.z]
+ h.point_return_count = [0L, 1L, 0L, 0L, 0L, 0L, 0L, 0L]
h.proj4 = '+proj=utm +zone=17 +ellps=WGS84 +datum=WGS84 +units=m +no_defs '
+ h.date = p.time
f = file.File('1.%d_%d.las'%(version,format), mode='w', header=h)
f.write(p)
More information about the Liblas-commits
