[Liblas-commits] r1054 - in trunk: include/liblas include/liblas/capi src
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Feb 19 23:19:21 EST 2009
Author: hobu
Date: Thu Feb 19 23:19:21 2009
New Revision: 1054
URL: http://liblas.org/changeset/1054
C API for LASSRS
   trunk/include/liblas/capi/liblas.h
   trunk/include/liblas/lassrs.hpp
   trunk/src/las_c_api.cpp
   trunk/src/lassrs.cpp
Modified: trunk/include/liblas/capi/liblas.h
--- trunk/include/liblas/capi/liblas.h	(original)
+++ trunk/include/liblas/capi/liblas.h	Thu Feb 19 23:19:21 2009
@@ -60,6 +60,16 @@
 typedef struct LASGuidHS *LASGuidH;
 typedef struct LASVLRHS *LASVLRH;
 typedef struct LASColorHS *LASColorH;
+typedef struct LASSRSHS *LASSRSH;
+/* Fake out the compiler if we don't have libgeotiff */
+#ifndef HAVE_LIBGEOTIFF
+    typedef struct GTIFS * GTIF;
+#else
+#include <geotiff.h>
+#endif
 LAS_C_START
@@ -1056,6 +1066,23 @@
 LAS_DLL LASError LASPoint_SetColor(LASPointH hPoint, const LASColorH hColor);
+/* SRS Operations                                                           */
+/** Creates a new SRS
+ *  @return a new SRS
+LAS_DLL LASSRSH LASSRS_Create(void);
+LAS_DLL const GTIF* LASSRS_GetGTIF(LASSRSH hSRS);
+LAS_DLL char* LASSRS_GetWKT(LASSRSH hSRS);
+LAS_DLL LASError LASSRS_SetWKT(LASSRSH hSRS, const char* value);
+LAS_DLL char* LASSRS_GetProj4(LASSRSH hSRS);
+LAS_DLL LASError LASSRS_SetProj4(LASSRSH hSRS, const char* value);
 LAS_C_END
 #endif
Modified: trunk/include/liblas/lassrs.hpp
--- trunk/include/liblas/lassrs.hpp	(original)
+++ trunk/include/liblas/lassrs.hpp	Thu Feb 19 23:19:21 2009
@@ -146,6 +146,9 @@
     /// \param vlrs - A list of VLRs that contains VLRs describing GeoTIFF keys
     void SetVLRs(const std::vector<LASVLR>& vlrs);
+    /// Add a VLR representing GeoTIFF keys to the SRS
+    void AddVLR(const LASVLR& vlr);
     /// Return a copy of the LASVLRs that LASSRS maintains
     std::vector<LASVLR> GetVLRs() const;
@@ -156,6 +159,8 @@
     ST_TIFF* m_tiff;
     std::vector<LASVLR> m_vlrs;
+    bool IsGeoVLR(const LASVLR& vlr) const;
 protected:
Modified: trunk/src/las_c_api.cpp
--- trunk/src/las_c_api.cpp	(original)
+++ trunk/src/las_c_api.cpp	Thu Feb 19 23:19:21 2009
@@ -49,6 +49,7 @@
 #include <liblas/exception.hpp>
 #include <liblas/lasrecordheader.hpp>
 #include <liblas/guid.hpp>
+#include <liblas/lassrs.hpp>
 #include <liblas/capi/las_config.h>
 #include <liblas/capi/las_version.h>
@@ -59,7 +60,7 @@
 #include <exception>
@@ -72,6 +73,7 @@
 #include <typeinfo>
 #include <vector>
 #include <cstdio>
 using namespace liblas;
 LAS_C_START
@@ -1673,6 +1675,111 @@
     return LE_None;
+LAS_DLL LASSRSH LASSRS_Create(void) {
+    return (LASSRSH) new LASSRS();
+LAS_DLL void LASSRS_Destroy(LASSRSH hSRS){
+    VALIDATE_POINTER0(hSRS, "LASSRS_Destroy");
+    delete (LASSRS*)hSRS;
+    hSRS = NULL;
+LAS_DLL const GTIF* LASSRS_GetGTIF(LASSRSH hSRS) {
+    VALIDATE_POINTER1(hSRS, "LASSRS_GetGTIF", 0);
+    try {
+        return ((LASSRS*) hSRS)->GetGTIF();
+    catch (std::exception const& e) {
+        LASError_PushError(LE_Failure, e.what(), "LASSRS_GetGTIF");
+        return 0;
+    VALIDATE_POINTER1(hSRS, "LASSRS_GetProj4", NULL);
+    LASSRS* srs = (LASSRS*)hSRS;
+    return strdup((srs)->GetProj4().c_str());
+LAS_DLL LASErrorEnum LASSRS_SetProj4(LASSRSH hSRS, const char* value)
+    VALIDATE_POINTER1(hSRS, "LASSRS_SetProj4", LE_Failure);
+    VALIDATE_POINTER1(value, "LASSRS_SetProj4", LE_Failure);
+    try {
+         ((LASSRS*) hSRS)->SetProj4(value);
+        LASError_PushError(LE_Failure, e.what(), "LASSRS_SetProj4");
+        return LE_Failure;
+    return LE_None;
+    VALIDATE_POINTER1(hSRS, "LASSRS_GetWKT", NULL);
+    return strdup((srs)->GetWKT().c_str());
+LAS_DLL LASErrorEnum LASSRS_SetWKT(LASSRSH hSRS, const char* value)
+    VALIDATE_POINTER1(hSRS, "LASSRS_SetWKT", LE_Failure);
+    VALIDATE_POINTER1(value, "LASSRS_SetWKT", LE_Failure);
+    try {
+         ((LASSRS*) hSRS)->SetWKT(value);
+        LASError_PushError(LE_Failure, e.what(), "LASSRS_SetWKT");
+    return LE_None;
+LAS_DLL LASErrorEnum LASSRS_AddVLR(LASSRSH hSRS, const LASVLRH hVLR) {
+    VALIDATE_POINTER1(hSRS, "LASSRS_AddVLR", LE_Failure);
+    VALIDATE_POINTER1(hVLR, "LASSRS_AddVLR", LE_Failure);
+    try {
+        ((LASSRS*) hSRS)->AddVLR(*((LASVLR*)hVLR));
+        LASError_PushError(LE_Failure, e.what(), "LASSRS_AddVLR");
+    return LE_None;
+LAS_DLL LASErrorEnum LASSRS_ResetVLRs(LASSRSH hSRS) {
+    VALIDATE_POINTER1(hSRS, "LASSRS_ResetVLRs", LE_Failure);
+    try {
+        ((LASSRS*) hSRS)->ResetVLRs();
+        LASError_PushError(LE_Failure, e.what(), "LASSRS_ResetVLRs");
+    return LE_None;
 LAS_C_END
 #ifdef _MSC_VER
Modified: trunk/src/lassrs.cpp
--- trunk/src/lassrs.cpp	(original)
+++ trunk/src/lassrs.cpp	Thu Feb 19 23:19:21 2009
@@ -113,21 +113,49 @@
     // They must have an id of "LASF_Projection" and a record id that's related.
     for (i = vlrs.begin(); i != vlrs.end(); ++i)
-        //GTIFF_GEOKEYDIRECTORY == 34735
-        if (uid == (*i).GetUserId(true).c_str() && 34735 == (*i).GetRecordId()) {
-            m_vlrs.push_back(*i);
-        // GTIFF_DOUBLEPARAMS == 34736
-        if (uid == (*i).GetUserId(true).c_str() && 34736 == (*i).GetRecordId()) {
-        // GTIFF_ASCIIPARAMS == 34737
-        if (uid == (*i).GetUserId(true).c_str() && 34737 == (*i).GetRecordId()) {
+        if (IsGeoVLR(*i)) {
+        // //GTIFF_GEOKEYDIRECTORY == 34735
+        // if (uid == (*i).GetUserId(true).c_str() && 34735 == (*i).GetRecordId()) {
+        //     m_vlrs.push_back(*i);
+        // // GTIFF_DOUBLEPARAMS == 34736
+        // if (uid == (*i).GetUserId(true).c_str() && 34736 == (*i).GetRecordId()) {
+        // // GTIFF_ASCIIPARAMS == 34737
+        // if (uid == (*i).GetUserId(true).c_str() && 34737 == (*i).GetRecordId()) {
+void LASSRS::AddVLR(const LASVLR& vlr)
+    if (IsGeoVLR(vlr)) {
+        m_vlrs.push_back(vlr);
+bool LASSRS::IsGeoVLR(const LASVLR& vlr) const
+    std::string const uid("LASF_Projection");
+    if (uid == vlr.GetUserId(true).c_str() && 34735 == vlr.GetRecordId()) {
+        return true;
+    // GTIFF_DOUBLEPARAMS == 34736
+    if (uid == vlr.GetUserId(true).c_str() && 34736 == vlr.GetRecordId()) {
+        return true;
+    // GTIFF_ASCIIPARAMS == 34737
+    if (uid == vlr.GetUserId(true).c_str() && 34737 == vlr.GetRecordId()) {
+        return true;
+    return false;
 std::vector<LASVLR> LASSRS::GetVLRs() const
@@ -375,8 +403,7 @@
     if( poSRS->importFromWkt((char **) &poWKT) != OGRERR_NONE )
         delete poSRS;
-        throw std::invalid_argument("could not import proj4 into OSRSpatialReference GetProj4");
-        return FALSE;
+        return std::string("");
     char* proj4;
More information about the Liblas-commits mailing list
