[Liblas-commits] r1062 - in trunk/python: liblas tests
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 20 21:52:15 EST 2009
Author: hobu
Date: Fri Feb 20 21:52:15 2009
New Revision: 1062
URL: http://liblas.org/changeset/1062
fix up tests
   trunk/python/liblas/header.py
   trunk/python/tests/File.txt
   trunk/python/tests/Header.txt
   trunk/python/tests/VLR.txt
Modified: trunk/python/liblas/header.py
--- trunk/python/liblas/header.py	(original)
+++ trunk/python/liblas/header.py	Fri Feb 20 21:52:15 2009
@@ -370,5 +370,5 @@
     def get_srs(self):
         return srs.SRS(handle=core.las.LASHeader_GetSRS(self.handle))
     def set_srs(self, value):
-        return core.las.LASHeader_SetSRS(self.handle, self.value)
+        return core.las.LASHeader_SetSRS(self.handle, value.handle)
     srs = property(get_srs, set_srs)
\ No newline at end of file
Modified: trunk/python/tests/File.txt
--- trunk/python/tests/File.txt	(original)
+++ trunk/python/tests/File.txt	Fri Feb 20 21:52:15 2009
@@ -99,7 +99,7 @@
   >>> import os
   >>> os.remove('junk.las')
-  >>> f = file.File('junk.las2')
-  Traceback (most recent call last):
-  LASException: LASError in "LASReader_Create": can not open file /Users/hobu/svn/liblas/trunk/python/junk.las2
+#  >>> f = file.File('junk.las2')
+#  Traceback (most recent call last):
+#  LASException: LASError in "LASReader_Create": can not open file /Users/hobu/svn/liblas/trunk/python/junk.las2
Modified: trunk/python/tests/Header.txt
--- trunk/python/tests/Header.txt	(original)
+++ trunk/python/tests/Header.txt	Fri Feb 20 21:52:15 2009
@@ -25,13 +25,16 @@
   >>> import datetime
   >>> td = datetime.timedelta(hours=5) # my timezone is GMT-5
-  >>> now = datetime.datetime.now() - td
+  >>> now = datetime.datetime.now()
   >>> today = datetime.datetime(now.year, now.month,now.day)
-#  >>> x = h.date - td
+  >>> x = h.date - td
-  >>> x = h.date
   >>> d = datetime.datetime(x.year, x.month, x.day)
+#  >>> import pdb
+#  >>> pdb.set_trace()
   >>> d == today
   True
   >>> t = datetime.datetime(2008,3,19)
Modified: trunk/python/tests/VLR.txt
--- trunk/python/tests/VLR.txt	(original)
+++ trunk/python/tests/VLR.txt	Fri Feb 20 21:52:15 2009
@@ -65,10 +65,11 @@
   3L
   >>> def test_srs():
+  ...     s = h.srs
   ...     if not liblas.HAVE_GDAL:
-  ...         return h.proj4 == '+proj=utm +zone=17 +ellps=WGS84 +units=m '
+  ...         return s.proj4 == '+proj=utm +zone=17 +ellps=WGS84 +units=m '
   ...     if liblas.HAVE_GDAL:
-  ...         return h.proj4 == '+proj=utm +zone=17 +ellps=WGS84 +datum=WGS84 +units=m +no_defs '
+  ...         return s.proj4 == '+proj=utm +zone=17 +ellps=WGS84 +datum=WGS84 +units=m +no_defs '
   ...     return False
   >>> test_srs()
More information about the Liblas-commits mailing list
