[Liblas-commits] r1064 - trunk/test/data
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 20 22:11:08 EST 2009
Author: hobu
Date: Fri Feb 20 22:11:07 2009
New Revision: 1064
URL: http://liblas.org/changeset/1064
latest version of test data with srs and guids
   trunk/test/data/1.0_0.las
   trunk/test/data/1.0_1.las
   trunk/test/data/1.1_0.las
   trunk/test/data/1.1_1.las
   trunk/test/data/1.2_0.las
   trunk/test/data/1.2_1.las
   trunk/test/data/1.2_2.las
   trunk/test/data/1.2_3.las
   trunk/test/data/make_data.py
Modified: trunk/test/data/1.0_0.las
Binary files. No diff available.
Modified: trunk/test/data/1.0_1.las
Modified: trunk/test/data/1.1_0.las
Modified: trunk/test/data/1.1_1.las
Modified: trunk/test/data/1.2_0.las
Modified: trunk/test/data/1.2_1.las
Modified: trunk/test/data/1.2_2.las
Modified: trunk/test/data/1.2_3.las
Modified: trunk/test/data/make_data.py
--- trunk/test/data/make_data.py	(original)
+++ trunk/test/data/make_data.py	Fri Feb 20 22:11:07 2009
@@ -5,6 +5,7 @@
 from liblas import point
 from liblas import color
 from liblas import srs
+from liblas import guid
 import datetime
@@ -28,8 +29,12 @@
 s = srs.SRS()
 s.proj4 = '+proj=utm +zone=15 +ellps=NAD83 +datum=NAD83 +units=m +no_defs '
+g = guid.GUID(key='8388f1b8-aa1b-4108-bca3-6bc68e7b062e')
 def write_file(version, format):
     h = header.Header()
+    h.guid = g
     h.date = datetime.datetime.now()
     h.dataformat_id = format
     h.major_version = 1
More information about the Liblas-commits mailing list
