[Liblas-commits] r1066 - trunk
liblas-commits at liblas.org
Mon Feb 23 15:04:01 EST 2009
Author: hobu
Date: Mon Feb 23 15:04:00 2009
New Revision: 1066
URL: http://liblas.org/changeset/1066
add configure logic to use gdal source tree -- not quite done yet
trunk/configure.ac
Modified: trunk/configure.ac
--- trunk/configure.ac (original)
+++ trunk/configure.ac Mon Feb 23 15:04:00 2009
@@ -60,6 +60,8 @@
AC_ARG_ENABLE([debug],
AC_HELP_STRING([--enable-debug=ARG], [Enable debug compilation mode [yes or no, default=${debug_default}]]),,)
+AC_MSG_CHECKING([for debug enabled])
if test "x$enable_debug" = "xyes"; then
CFLAGS="$CFLAGS -g -DDEBUG"
CXXFLAGS="$CXXFLAGS -g -DDEBUG"
@@ -92,6 +94,15 @@
rm -f conftest*
+HAVE_GDAL="no"
+GDAL_CONFIG="no"
+HAVE_GEOTIFF="no"
+GEOTIFF_CONFIG="no"
+USE_GDAL_SOURCE_TREE="no"
dnl #########################################################################
dnl Determine GDAL Support
@@ -100,8 +111,6 @@
AC_HELP_STRING([--with-gdal=ARG], [Path to gdal-config]),,)
AC_MSG_CHECKING([for GDAL])
-HAVE_GDAL="no"
-GDAL_CONFIG="no"
if test "$with_gdal" = "no" -o "$with_gdal" = "" ; then
AC_MSG_RESULT([no])
else
@@ -110,6 +119,17 @@
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
AC_MSG_RESULT([GDAL enabled with provided gdal-config])
GDAL_CONFIG="$with_gdal"
+ elif test -f ${with_gdal}/frmts/gtiff/libgeotiff/geotiff.h; then
+ GEOTIFF_INC="-I$with_geotiff/include/geotiff"
+ GDAL_INC="-I$with_gdal/port -I$with_gdal/ogr -I$with_gdal/alg -I$with_gdal/frmts"
+ GDAL_PREFIX="$with_gdal"
+ HAVE_GDAL="yes"
+ HAVE_GEOTIFF="yes"
+ GEOTIFF_CONFIG="yes"
+ GDAL_CONFIG="yes"
+ USE_GDAL_SOURCE_TREE="yes"
+ LIBS="${with_gdal}/.libs -lgdal ${with_gdal}/ -lgdal $LIBS"
+ AC_MSG_RESULT([GDAL and GeoTIFF enabled with provided GDAL source tree])
else
dnl --with-gdal=yes given, so try to find gdal-config in PATH
GDAL_CONFIG_TMP=`which gdal-config`
@@ -117,12 +137,16 @@
AC_MSG_RESULT([GDAL enabled with gdal-config found in PATH])
GDAL_CONFIG=${GDAL_CONFIG_TMP}
else
- AC_MSG_ERROR([--with-gdal should have yes or a path to gdal-config])
+ AC_MSG_ERROR([--with-gdal should be yes, a path to gdal-config, or a path to GDAL's source tree])
fi
fi
fi
if test "$GDAL_CONFIG" != "no" ; then
+dnl if we are already yes, we don't need to run gdal-config
+ if test "$GDAL_CONFIG" != "yes" ; then
GDAL_VERSION=`$GDAL_CONFIG --version`
AC_MSG_RESULT([$GDAL_CONFIG reports version $GDAL_VERSION])
LIBS="`$GDAL_CONFIG --libs` $LIBS"
@@ -133,6 +157,7 @@
AC_MSG_ERROR([$GDAL_CONFIG says OGR is not enabled])
fi
HAVE_GDAL="yes"
+ fi
fi
AC_SUBST([GDAL_INC])
@@ -146,16 +171,14 @@
AC_ARG_WITH([geotiff],
AC_HELP_STRING([--with-geotiff=ARG], [libgeotiff library to use (no or path)]),,)
-HAVE_GEOTIFF="no"
-GEOTIFF_CONFIG="no"
-if test "$with_geotiff" != "no" -a "$with_geotiff" != "" ; then
+if test "$with_geotiff" != "no" -a "$with_geotiff" != "" -a "${GEOTIFF_CONFIG}" != "yes" ; then
dnl We now require libgeotiff 1.2.5 (for ST_Create the simpletags stuff).
dnl first check if $with_geotiff/lib has the library:
AC_CHECK_LIB([geotiff], [ST_Create],
[GEOTIFF_CONFIG=external], [GEOTIFF_CONFIG=no],
[-L$with_geotiff/lib])
fi
if test "${GEOTIFF_CONFIG}" != "no" ; then
dnl libgeotiff 1.2.5, is first version with geo_simpletags.h
AC_MSG_CHECKING([for geo_simpletags.h of libgeotiff >= 1.2.5])
@@ -165,6 +188,9 @@
elif test -f ${with_geotiff}/include/geotiff/geo_simpletags.h ; then
AC_MSG_RESULT([yes])
+ elif test -f ${with_gdal}/frmts/gtiff/libgeotiff/geo_simpletags.h ; then
+ GEOTIFF_INC="-I$with_gdal/frmts/gtiff/libgeotiff/"
+ AC_MSG_RESULT([yes, from GDAL])
else
GEOTIFF_CONFIG="no"
AC_MSG_RESULT([no])
@@ -176,9 +202,13 @@
HAVE_GEOTIFF="no"
AC_MSG_RESULT([no])
else
- LIBS="-L$with_geotiff/lib -lgeotiff $LIBS"
- HAVE_GEOTIFF="yes"
- AC_MSG_RESULT([yes])
+ if test "${USE_GDAL_SOURCE_TREE}" != "yes" ; then
+ LIBS="-L$with_geotiff/lib -lgeotiff $LIBS"
+ AC_MSG_RESULT([yes])
+ else
+ AC_MSG_RESULT([use GDAL source])
+ fi
fi
AC_SUBST([GEOTIFF_INC])
More information about the Liblas-commits
