[Liblas-commits] r1302 - in trunk: apps include/liblas/index
src/index
liblas-commits at liblas.org
Sat Jul 4 00:53:50 EDT 2009
Author: hobu
Date: Sat Jul 4 00:53:49 2009
New Revision: 1302
URL: http://liblas.org/changeset/1302
more indexing updates for point cloud creation. almost working.
trunk/apps/Makefile.am
trunk/apps/las2oci.cpp
trunk/apps/lasindex.cpp
trunk/include/liblas/index/index.hpp
trunk/include/liblas/index/query.hpp
trunk/src/index/index.cpp
trunk/src/index/query.cpp
Modified: trunk/apps/Makefile.am
--- trunk/apps/Makefile.am (original)
+++ trunk/apps/Makefile.am Sat Jul 4 00:53:49 2009
@@ -22,7 +22,7 @@
BOOST_FLAGS = @BOOST_CPPFLAGS@ -DHAVE_BOOST=1
endif
-AM_CPPFLAGS = -I../include/liblas/capi -I../include $(GEOTIFF_CPPFLAGS) $(GDAL_CPPFLAGS) $(SPATIALINDEX_CPPFLAGS) $(OCI_CPPFLAGS) $(ZLIB_CPPFLAGS) $(BOOST_FLAGS)
+AM_CPPFLAGS = -I../include/liblas/capi -I../include $(GDAL_CPPFLAGS) $(GEOTIFF_CPPFLAGS) $(SPATIALINDEX_CPPFLAGS) $(OCI_CPPFLAGS) $(ZLIB_CPPFLAGS) $(BOOST_FLAGS)
lasinfo_SOURCES = lasinfo.c lascommon.c
las2las_SOURCES = las2las.c lascommon.c
Modified: trunk/apps/las2oci.cpp
--- trunk/apps/las2oci.cpp (original)
+++ trunk/apps/las2oci.cpp Sat Jul 4 00:53:49 2009
@@ -1,9 +1,60 @@
+// god-awful hack because of GDAL/GeoTIFF's shitty include structure
+#define CPL_SERV_H_INCLUDED
#include "oci_wrapper.h"
+#include <liblas/cstdint.hpp>
+#include <liblas/detail/utility.hpp>
+#include <liblas/laspoint.hpp>
+#include <liblas/lasreader.hpp>
+#include <liblas/lasheader.hpp>
+#include <liblas/index/index.hpp>
#include <string>
#include <sstream>
#include <iostream>
+#include <fstream>
+#include <exception>
+#ifdef HAVE_SPATIALINDEX
+#include <spatialindex/SpatialIndex.h>
+#endif
+#include <oci.h>
using namespace std;
+using namespace liblas;
+#ifdef _WIN32
+#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#endif
+std::istream* OpenInput(std::string filename)
+ std::ios::openmode const mode = std::ios::in | std::ios::binary;
+ std::istream* istrm;
+ if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
+ istrm = &std::cin;
+ else
+ istrm = new std::ifstream(filename.c_str(), mode);
+ if (!istrm->good())
+ delete istrm;
+ throw std::runtime_error("Reading stream was not able to be created");
+ exit(1);
+ return istrm;
OWStatement* Run(OWConnection* connection, ostringstream& command)
@@ -70,23 +121,227 @@
ostringstream oss;
OWStatement* statement = 0;
- oss << "CREATE TABLE "<< tableName <<" (ID VARCHAR2(24), VAL_D1 NUMBER, VAL_D2 NUMBER, VAL_D3 NUMBER)";
+ oss << "CREATE TABLE "<< tableName <<" (OBJ_ID NUMBER, BLK_ID NUMBER, "
+ " BLK_EXTENT MDSYS.SDO_GEOMETRY, BLK_DOMAIN MDSYS.SDO_ORGSCL_TYPE,"
+ " PCBLK_MIN_RES NUMBER, PCBLK_MAX_RES NUMBER, NUM_POINTS NUMBER, "
+ " NUM_UNSORTED_POINTS NUMBER, PT_SORT_DIM NUMBER, POINTS BLOB)";
+ statement = Run(connection, oss);
+ if (statement != 0) delete statement; else return false;
+ oss.str("");
+ return true;
+bool DeleteTable(OWConnection* connection, const char* tableName)
+ ostringstream oss;
+ OWStatement* statement = 0;
+ oss << "DROP TABLE "<< tableName ;
oss.str("");
return true;
+std::vector<liblas::uint8_t>* GetPointData(LASPoint const& p, bool bTime)
+ // This function returns an array of bytes describing the
+ // x,y,z and optionally time values for the point. The caller owns
+ // the array.
+ std::vector<liblas::uint8_t>* data = new std::vector<liblas::uint8_t>;
+ data->resize(24);
+ if (bTime) data->resize(data->size()+8); // Add the time bytes too
+ double x = p.GetX();
+ double y = p.GetY();
+ double z = p.GetZ();
+ double t = p.GetTime();
+ liblas::uint8_t* x_b = reinterpret_cast<liblas::uint8_t*>(&x);
+ liblas::uint8_t* y_b = reinterpret_cast<liblas::uint8_t*>(&y);
+ liblas::uint8_t* z_b = reinterpret_cast<liblas::uint8_t*>(&z);
+ liblas::uint8_t* t_b = reinterpret_cast<liblas::uint8_t*>(&t);
+ // doubles are 8 bytes long. For each double, push back the
+ // byte. We do this for all four values (x,y,z,t)
+ for (int i=0; i<8; i++) {
+ data->push_back(x_b[i]);
+ data->push_back(y_b[i]);
+ data->push_back(z_b[i]);
+ if (bTime)
+ data->push_back(t_b[i]);
+ return data;
+std::vector<liblas::uint8_t>* GetResultData(const LASQueryResult& result, LASReader* reader, int nDimension)
+ list<SpatialIndex::id_type> const& ids = result.GetIDs();
+ // calculate the vector size
+ // d 8-byte IEEE doubles, where d is the PC_TOT_DIMENSIONS value
+ // 4-byte big-endian integer for the BLK_ID value
+ // 4-byte big-endian integer for the PT_ID value
+ bool bTime = false;
+ liblas::uint32_t record_size;
+ if (nDimension == 3)
+ record_size = ids.size() * (8*3+4+4);
+ else if (nDimension == 4)
+ record_size = ids.size() * (8*4+4+4);
+ bTime = true;
+ else
+ // throw a big error
+ throw std::runtime_error("Dimension must be 3 or 4");
+ vector<liblas::uint8_t>* output = new vector<liblas::uint8_t>;
+ output->resize(record_size);
+ list<SpatialIndex::id_type>::const_iterator i;
+ vector<liblas::uint8_t>::iterator pi;
+ liblas::uint32_t block_id = result.GetID();
+ for (i=ids.begin(); i!=ids.end(); i++)
+ SpatialIndex::id_type id = *i;
+ bool doRead = reader->ReadPointAt(id);
+ if (doRead) {
+ LASPoint const& p = reader->GetPoint();
+ std::vector<liblas::uint8_t> *point_data = GetPointData(p, bTime);
+ std::vector<liblas::uint8_t>::const_iterator d;
+ for (d = point_data->begin(); d!=point_data->end(); d++) {
+ output->push_back(*d);
+ // pi = std::copy(point_data->begin(), point_data->end(), pi);
+ delete point_data;
+ liblas::uint8_t* id_b = reinterpret_cast<liblas::uint8_t*>(&id);
+ liblas::uint8_t* block_b = reinterpret_cast<liblas::uint8_t*>(&block_id);
+ // add 4-byte big endian integers
+ output->push_back(id_b[3]);
+ output->push_back(id_b[2]);
+ output->push_back(id_b[1]);
+ output->push_back(id_b[0]);
+ output->push_back(block_b[3]);
+ output->push_back(block_b[2]);
+ output->push_back(block_b[1]);
+ output->push_back(block_b[0]);
+ return output;
+bool InsertBlock(OWConnection* connection, const LASQueryResult& result, int srid, LASReader* reader, const char* tableName)
+ const SpatialIndex::Region* b = result.GetBounds();
+ liblas::uint32_t num_points =ids.size();
+ ostringstream oss_geom;
+ oss_geom.setf(std::ios_base::fixed, std::ios_base::floatfield);
+ oss_geom.precision(2);
+ oss_geom << "mdsys.sdo_geometry(2003,"<<srid<<", null,"
+ "mdsys.sdo_elem_info_array(1,1003,3),"
+ "mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<b->getLow(1)<<","<<b->getHigh(0) <<","<<b->getHigh(1)<<"))";
+ oss << "INSERT INTO "<< tableName << "(OBJ_ID, NUM_POINTS, BLK_EXTENT, POINTS) VALUES ( "
+ << result.GetID() <<"," << num_points << ", " << oss_geom.str() <<", EMPTY_BLOB())";
+ statement = connection->CreateStatement(oss.str().c_str());
+ if (statement->Execute() == false) {
+ delete statement;
+ return false;
+ delete statement; statement = 0;
+ oss.str("");
+ oss << "SELECT POINTS FROM " << tableName << " WHERE OBJ_ID=" << result.GetID() << " FOR UPDATE";
+ // we only expect one blob to come back
+ OCILobLocator** locator =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
+ statement->Define( locator, 1 ); // fetch one blob
+ if( statement->Execute() == false )
+ std::cout << "Unable to execute statement!" << std::endl;
+ delete statement;
+ return false;
+ if( statement->Fetch( 1 ) == false )
+ std::cout << "Unable to fetch POINTS blob!" << std::endl;
+ delete statement;
+ return false;
+ liblas::uint32_t num_bytes = 0;
+ std::vector<liblas::uint8_t>* data = GetResultData(result, reader, 3);
+ std::cout << "Data size: " << data->size() << std::endl;
+ // liblas::uint8_t *bytes = (liblas::uint8_t*) new liblas::uint8_t[data->size()];
+ // memcpy( (void*)&(bytes[0]), (void*)data[0], data->size() );
+ // liblas::uint8_t *bytes;
+ int anumber = data->size();
+ // liblas::uint8_t *bytes2 = (liblas::uint8_t*) new liblas::uint8_t[data.size()];
+ // memset( bytes2, 0, data.size());
+// int nBytesRead = statement->ReadBlob( locator[0],
+// (void*)data,
+// anumber );
+// this could be writing junk
+liblas::uint32_t num_bytes_written = statement->WriteBlob( locator[0],
+ data,
+ anumber );
+ delete statement;
+ // OWStatement::Free(locator, 1);
+ // exit(0);
+ return true;
void usage() {}
int main(int argc, char* argv[])
- int rc = 0;
std::string input;
std::string output;
+ bool bDropTable = false;
+ liblas::uint32_t nCapacity = 10000;
+ double dFillFactor = 1.0;
+ int srid = 8307;
for (int i = 1; i < argc; i++)
@@ -106,27 +361,43 @@
i++;
input = std::string(argv[i]);
- else if ( strcmp(argv[i],"--output") == 0 ||
- strcmp(argv[i],"--out") == 0 ||
- strcmp(argv[i],"-out") == 0 ||
- strcmp(argv[i],"-o") == 0
+ else if ( strcmp(argv[i],"--overwrite") == 0 ||
+ strcmp(argv[i],"-drop") == 0 ||
+ strcmp(argv[i],"-d") == 0
i++;
- output = std::string(argv[i]);
+ bDropTable=true;
- else if (i == argc - 2 && output.empty() && input.empty())
+ else if ( strcmp(argv[i],"--blk_capacity") == 0 ||
+ strcmp(argv[i],"--capacity") == 0 ||
+ strcmp(argv[i],"-c") == 0
- input = std::string(argv[i]);
+ i++;
+ nCapacity=atoi(argv[i]);
- else if (i == argc - 1 && output.empty() && input.empty())
+ else if ( strcmp(argv[i],"--fill") == 0 ||
+ strcmp(argv[i],"-fill") == 0 ||
+ strcmp(argv[i],"-f") == 0
+ i++;
+ dFillFactor=atof(argv[i]);
+ else if ( strcmp(argv[i],"--srid") == 0 ||
+ strcmp(argv[i],"-srid") == 0 ||
+ strcmp(argv[i],"-s") == 0
+ i++;
+ srid=atoi(argv[i]);
+ else if (input.empty())
+ input = std::string(argv[i]);
else
usage();
@@ -135,10 +406,59 @@
OWConnection* con = new OWConnection("lidar","lidar","ubuntu/crrel.local");
- if (con->Succeeded()) printf("succeded");
+ if (con->Succeeded()) std::cout <<"Oracle Connection succeded" << std::endl;
+ try {
+ istrm = OpenInput(input);
+ } catch (std::exception const& e)
+ std::cout << e.what() << std::endl;
+ std::cout << "exiting..." << std::endl;
+ exit(-1);
+ // change filename foo.las -> foo for an appropriate
+ // tablename for oracle
+ string::size_type dot_pos = input.find_first_of(".");
+ string table_name = input.substr(0,dot_pos);
+ if (bDropTable) DeleteTable(con, table_name.c_str());
+ CreateTable(con, table_name.c_str());
+ LASReader* reader = new LASReader(*istrm);
+ LASIndexDataStream* idxstrm = new LASIndexDataStream(reader);
+ // reader->Reset();
+ LASIndex* idx = new LASIndex(input);
+ idx->SetType(LASIndex::eExternalIndex);
+ idx->SetLeafCapacity(nCapacity);
+ idx->SetFillFactor(1.0);
+ idx->Initialize(*idxstrm);
+ LASQuery* query = new LASQuery;
+ idx->Query(*query);
+ if (idx != 0) delete idx;
+ if (reader != 0) delete reader;
+ if (istrm != 0 ) delete istrm;
+ std::list<LASQueryResult>& results = query->GetResults();
+ std::list<LASQueryResult>::const_iterator i;
+ std::istream* istrm2;
+ istrm2 = OpenInput(input);
+ LASReader* reader2 = new LASReader(*istrm2);
+ for (i=results.begin(); i!=results.end(); i++)
+ bool inserted = InsertBlock(con, *i, srid, reader2, table_name.c_str());
- Cleanup(con, "base");
- CreateTable(con, "inptab");
+// Cleanup(con, "base");
// int iCol = 0;
// char szField[OWNAME];
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp (original)
+++ trunk/apps/lasindex.cpp Sat Jul 4 00:53:49 2009
@@ -9,16 +9,16 @@
#include <liblas/lasvariablerecord.hpp>
-#ifdef HAVE_BOOST
-#include <boost/iostreams/filter/zlib.hpp>
-#include <boost/iostreams/filtering_streambuf.hpp>
-#include <boost/iostreams/filtering_stream.hpp>
-#include <boost/iostreams/device/array.hpp>
-#include <boost/iostreams/device/back_inserter.hpp>
-#include <boost/iostreams/copy.hpp>
-#include <boost/range/iterator_range.hpp>
-#include <boost/format.hpp>
-#endif
+// #ifdef HAVE_BOOST
+// #include <boost/iostreams/filter/zlib.hpp>
+// #include <boost/iostreams/filtering_streambuf.hpp>
+// #include <boost/iostreams/filtering_stream.hpp>
+// #include <boost/iostreams/device/array.hpp>
+// #include <boost/iostreams/device/back_inserter.hpp>
+// #include <boost/iostreams/copy.hpp>
+// #include <boost/range/iterator_range.hpp>
+// #include <boost/format.hpp>
+// #endif
@@ -165,9 +165,19 @@
std::string nothing = std::string("");
- LASIndex* idx = new LASIndex(nothing);
- idx->SetType(LASIndex::eMemoryIndex);
+ idx->SetLeafCapacity(10000);
+ idx = 0;
+ idx = new LASIndex(input);
std::vector<liblas::uint32_t>* ids = 0;
try{
@@ -191,52 +201,60 @@
std::cout << ids->at(i) <<",";
std::cout << std::endl;
+ if (ids != 0) delete ids;
+ if (query != 0 ) delete query;
// if (ids != 0) delete ids;
// if (idx != 0) delete idx;
// idx = 0;
- namespace io = boost::iostreams;
- // io::filtering_ostream ofilter;
- // std::stringstream junk;
- // std::vector<liblas::uint8_t> compressed;
- std::string compressed;
- io::filtering_streambuf<io::output> ofilter;
- ofilter.push(io::zlib_compressor());
- ofilter.push(back_inserter(compressed));
- LASVariableRecord *vlr = idx->GetVLR();
- std::string data("some junkdsfasdfasdfqwerasdfasdfasdfasdfasdfweradsfasdfasdfasdfasdfasdqwerasdfasdfasdfasdfqwerasdfasdfv");
- // std::string data(vlr->GetData());
- std::cout << "uncompressed size " << data.size() << std::endl;
- io::copy(boost::make_iterator_range(data),ofilter);
- // std::vector<liblas::uint8_t>& d= *(vlr->GetData());
- // io::copy(boost::make_iterator_range(d.begin(), d.end()),ofilter);
- std::cout << "compressed size " << compressed.size() << std::endl;
+ // namespace io = boost::iostreams;
+ // // io::filtering_ostream ofilter;
+ // // std::stringstream junk;
+ // // std::vector<liblas::uint8_t> compressed;
+ // std::string compressed;
+ // io::filtering_streambuf<io::output> ofilter;
// ofilter.push(io::zlib_compressor());
// ofilter.push(back_inserter(compressed));
// LASVariableRecord *vlr = idx->GetVLR();
- // std::cout << "VLR length: " << vlr->GetRecordLength() << std::endl;
- // ofilter << "some junkdsfasdfasdfqwerasdfv";
- // // ofilter << *vlr;
- // std::cout << "stream size: " << ofilter.size() << std::endl;
+ // std::string data("some junkdsfasdfasdfqwerasdfasdfasdfasdfasdfweradsfasdfasdfasdfasdfasdqwerasdfasdfasdfasdfqwerasdfasdfv");
+ // // std::string data(vlr->GetData());
+ // std::cout << "uncompressed size " << data.size() << std::endl;
- // ofilter.flush();
- // std::cout << "compressed size: " << compressed.size() << std::endl;
+ // io::copy(boost::make_iterator_range(data),ofilter);
+ // // std::vector<liblas::uint8_t>& d= *(vlr->GetData());
+ // // io::copy(boost::make_iterator_range(d.begin(), d.end()),ofilter);
+ // std::cout << "compressed size " << compressed.size() << std::endl;
+ // // ofilter.push(io::zlib_compressor());
+ // // ofilter.push(back_inserter(compressed));
+ // // LASVariableRecord *vlr = idx->GetVLR();
+ // // std::cout << "VLR length: " << vlr->GetRecordLength() << std::endl;
+ // // ofilter << "some junkdsfasdfasdfqwerasdfv";
+ // // // ofilter << *vlr;
+ // // std::cout << "stream size: " << ofilter.size() << std::endl;
+ // // ofilter.flush();
+ // // std::cout << "compressed size: " << compressed.size() << std::endl;
Modified: trunk/include/liblas/index/index.hpp
--- trunk/include/liblas/index/index.hpp (original)
+++ trunk/include/liblas/index/index.hpp Sat Jul 4 00:53:49 2009
@@ -54,7 +54,7 @@
#include <liblas/index/datastream.hpp>
#include <liblas/index/storage.hpp>
#include <liblas/index/visitor.hpp>
+#include <liblas/index/query.hpp>
//std
#include <string>
@@ -114,7 +114,31 @@
/// Get index page size for indexes that are stored externally
/// \return index page size.
uint32_t GetPageSize() { return m_Pagesize; }
+ /// Sets the index leaf capacity
+ /// \param v - leaf capacity value. Defaults to 1000.
+ void SetLeafCapacity(uint32_t v) { m_idxLeafCap = v; }
+ /// Get index leaf capacity
+ /// \return index leaf capacity value.
+ uint32_t GetLeafCapacity() { return m_idxLeafCap; }
+ /// Sets the index capacity
+ /// \param v - capacity value. Defaults to 100.
+ void SetIndexCapacity(uint32_t v) { m_idxCapacity = v; }
+ /// Get index capacity
+ /// \return index capacity value.
+ uint32_t GetIndexCapacity() { return m_idxCapacity; }
+ /// Sets the fill factor
+ /// \param v - fill factor value. Defaults to 0.7.
+ void SetFillFactor(double v) { m_idxFillFactor = v; }
+ /// Get the index fill factor
+ /// \return index fill factor.
+ double GetFillFactor() { return m_idxFillFactor; }
/// Sets the index type
/// \param v - index type. Defaults to eExternalIndex.
void SetType(IndexType v) { m_idxType = v; }
@@ -125,6 +149,7 @@
LASVariableRecord* GetVLR();
+ void Query(LASQuery& query);
private:
SpatialIndex::IStorageManager* m_storage;
Modified: trunk/include/liblas/index/query.hpp
--- trunk/include/liblas/index/query.hpp (original)
+++ trunk/include/liblas/index/query.hpp Sat Jul 4 00:53:49 2009
@@ -39,8 +39,8 @@
* OF SUCH DAMAGE.
-#ifndef LIBLAS_INDEX_VISITOR_HPP_INCLUDED
-#define LIBLAS_INDEX_VISITOR_HPP_INCLUDED
+#ifndef LIBLAS_INDEX_QUERY_HPP_INCLUDED
+#define LIBLAS_INDEX_QUERY_HPP_INCLUDED
#ifndef _MSC_VER
@@ -53,25 +53,55 @@
#include <string>
#include <vector>
#include <stack>
+#include <queue>
#include <sys/stat.h>
namespace liblas {
+class LASQueryResult
+private:
+ std::list<SpatialIndex::id_type> ids;
+ SpatialIndex::Region* bounds;
+ uint32_t m_id;
+ LASQueryResult();
+public:
+ LASQueryResult(uint32_t id) : bounds(0), m_id(id){};
+ ~LASQueryResult() {if (bounds!=0) delete bounds;};
+ /// Copy constructor.
+ LASQueryResult(LASQueryResult const& other);
+ /// Assignment operator.
+ LASQueryResult& operator=(LASQueryResult const& rhs);
+ std::list<SpatialIndex::id_type> const& GetIDs() const;
+ void SetIDs(std::list<SpatialIndex::id_type>& v);
+ const SpatialIndex::Region* GetBounds() const;
+ void SetBounds(const SpatialIndex::Region* b);
+ uint32_t GetID() const {return m_id;}
+ void SetID(uint32_t v) {m_id = v;}
class LASQuery : public SpatialIndex::IQueryStrategy
private:
+ std::queue<SpatialIndex::id_type> m_ids;
+ uint32_t m_count;
+ std::list<LASQueryResult> m_results;
public:
LASQuery();
+ ~LASQuery() {
+ std::cout << "child count was" << m_count << std::endl;
+ std::cout << "results count was" << m_results.size() << std::endl;};
void getNextEntry(const SpatialIndex::IEntry& entry, SpatialIndex::id_type& nextEntry, bool& hasNext);
+ std::list<LASQueryResult>& GetResults() {return m_results;}
-#endif // LIBLAS_INDEX_VISITOR_HPP_INCLUDED
+#endif // LIBLAS_INDEX_QUERY_HPP_INCLUDED
Modified: trunk/src/index/index.cpp
--- trunk/src/index/index.cpp (original)
+++ trunk/src/index/index.cpp Sat Jul 4 00:53:49 2009
@@ -67,7 +67,7 @@
m_idxId = 1;
m_idxCapacity = 100;
- m_idxLeafCap = 100;
+ m_idxLeafCap = 1000;
m_idxDimension = 3;
m_idxFillFactor = 0.7;
@@ -159,6 +159,7 @@
else
return new LASVariableRecord();
SpatialIndex::ISpatialIndex* LASIndex::CreateIndex(LASIndexDataStream& strm)
using namespace SpatialIndex;
@@ -213,10 +214,9 @@
using namespace SpatialIndex::StorageManager;
- std::cout << "index type:" << m_idxType << std::endl;
SpatialIndex::IStorageManager* storage = 0;
if (m_idxType == eExternalIndex) {
+ std::cout << "index type was eExternalIndex" << std::endl;
if (ExternalIndexExists(filename) && !filename.empty()) {
std::cout << "loading existing DiskStorage " << filename << std::endl;
try{
@@ -241,6 +241,7 @@
} else if (m_idxType == eMemoryIndex) {
+ std::cout << "index type was eMemoryIndex" << std::endl;
try{
std::cout << "creating new createNewVLRStorageManager " << filename << std::endl;
@@ -377,8 +378,10 @@
+void LASIndex::Query(LASQuery& query)
+ m_rtree->queryStrategy(query);
} // namespace liblas
\ No newline at end of file
Modified: trunk/src/index/query.cpp
--- trunk/src/index/query.cpp (original)
+++ trunk/src/index/query.cpp Sat Jul 4 00:53:49 2009
@@ -49,21 +49,108 @@
#include <vector>
#include <stdexcept>
namespace liblas
-LASQuery::LASQuery() {}
+ LASQuery::LASQuery() :m_count(0){}
void LASQuery::getNextEntry(const SpatialIndex::IEntry& entry, SpatialIndex::id_type& nextEntry, bool& hasNext) {
- // the first time we are called, entry points to the root.
+ // the first time we are called, entry points to the root.
+ const SpatialIndex::INode* n = dynamic_cast<const SpatialIndex::INode*>(&entry);
+ // if (n !=0 ) {
+ // for (size_t i = 0; i < n->getChildrenCount(); i++)
+ // m_ids.push(n->getChildIdentifier(i));
+ // traverse only index nodes at levels 2 and higher.
+ if (n != 0 && n->getLevel() > 0)
+ m_count +=n->getChildrenCount();
+ for (size_t cChild = 0; cChild < n->getChildrenCount(); cChild++)
+ m_ids.push(n->getChildIdentifier(cChild));
+ if (n->isLeaf()) {
+ SpatialIndex::IShape* ps;
+ entry.getShape(&ps);
+ SpatialIndex::Region* pr = dynamic_cast<SpatialIndex::Region*>(ps);
+ ids.push_back(n->getChildIdentifier(cChild));
+ LASQueryResult result(n->getIdentifier());
+ result.SetIDs(ids);
+ result.SetBounds(pr);
+ m_results.push_back(result);
+ if (! m_ids.empty())
+ nextEntry = m_ids.front(); m_ids.pop();
+ hasNext = true;
+ else
+ hasNext = false;
+ // // stop after the root.
+ // hasNext = false;
+ // SpatialIndex::IShape* ps;
+ // entry.getShape(&ps);
+ // // ps->getMBR(m_indexedSpace);
+ // delete ps;
- // stop after the root.
- hasNext = false;
+std::list<SpatialIndex::id_type> const& LASQueryResult::GetIDs() const
+ return ids;
- SpatialIndex::IShape* ps;
- entry.getShape(&ps);
- // ps->getMBR(m_indexedSpace);
- delete ps;
+void LASQueryResult::SetIDs(std::list<SpatialIndex::id_type>& v)
+ ids.resize(v.size());
+ std::copy(v.begin(), v.end(), ids.begin());
+const SpatialIndex::Region* LASQueryResult::GetBounds() const
+ return bounds;
+void LASQueryResult::SetBounds(const SpatialIndex::Region* b)
+ bounds = new SpatialIndex::Region(*b);
+LASQueryResult::LASQueryResult(LASQueryResult const& other)
+ ids.resize(other.ids.size());
+ std::copy(other.ids.begin(), other.ids.end(), ids.begin());
+ m_id = other.m_id;
+ bounds = other.bounds->clone();
+LASQueryResult& LASQueryResult::operator=(LASQueryResult const& rhs)
+ if (&rhs != this)
+ ids.resize(rhs.ids.size());
+ std::copy(rhs.ids.begin(), rhs.ids.end(), ids.begin());
+ m_id = rhs.m_id;
+ bounds = rhs.bounds->clone();
+ return *this;
More information about the Liblas-commits
