[Liblas-commits] r1304 - trunk/apps
liblas-commits at liblas.org
Sun Jul 5 22:48:12 EDT 2009
Author: hobu
Date: Sun Jul 5 22:48:11 2009
New Revision: 1304
URL: http://liblas.org/changeset/1304
more PC updates
trunk/apps/las2oci.cpp
Modified: trunk/apps/las2oci.cpp
--- trunk/apps/las2oci.cpp (original)
+++ trunk/apps/las2oci.cpp Sun Jul 5 22:48:11 2009
@@ -17,6 +17,8 @@
#include <iostream>
#include <fstream>
#include <exception>
+#include <algorithm>
+#include <cctype>
#ifdef HAVE_SPATIALINDEX
#include <spatialindex/SpatialIndex.h>
@@ -139,12 +141,32 @@
ostringstream oss;
OWStatement* statement = 0;
+ oss << "DELETE from hobu ";
+ statement = Run(connection, oss);
+ if (statement != 0) delete statement; else return false;
+ oss.str("");
+ // oss << "DROP table hobu ";
+ // statement = Run(connection, oss);
+ // if (statement != 0) delete statement; else return false;
+ // oss.str("");
oss << "DROP TABLE "<< tableName ;
oss.str("");
+ // Oracle upper cases the table name when inserting it in the
+ // USER_SDO_GEOM_METADATA. We'll use std::transform to do it.
+ // See http://forums.devx.com/showthread.php?t=83058 for the
+ // technique
+ string table(tableName);
+ std::transform(table.begin(), table.end(), table.begin(), static_cast < int(*)(int) > (toupper));
+ oss << "DELETE FROM USER_SDO_GEOM_METADATA WHERE TABLE_NAME='"<<table<<"'" ;
+ oss.str("");
return true;
@@ -379,13 +401,65 @@
return true;
+bool CreatePCEntry( OWConnection* connection,
+ LASQuery* query,
+ const char* blkTableName,
+ const char* pcTableName,
+ const char* cloudName,
+ int nDimension,
+ int srid,
+ int blk_capacity)
+ ostringstream oss;
+ OWStatement* statement = 0;
+ oss.setf(std::ios_base::fixed, std::ios_base::floatfield);
+ oss.precision(2);
+oss << "declare\n"
+" pc sdo_pc;\n"
+"begin\n"
+" -- Initialize the Point Cloud object.\n"
+" pc := sdo_pc_pkg.init( \n"
+" '"<< pcTableName<<"', -- Table that has the SDO_POINT_CLOUD column defined\n"
+" '"<< cloudName<<"', -- Column name of the SDO_POINT_CLOUD object\n"
+" '"<<blkTableName<<"', -- Table to store blocks of the point cloud\n"
+" 'blk_capacity="<<blk_capacity<<"', -- max # of points per block\n"
+" mdsys.sdo_geometry(2003, "<<srid<<", null,\n"
+" mdsys.sdo_elem_info_array(1,1003,3),\n"
+" mdsys.sdo_ordinate_array(\n"
+<< query->bounds.getLow(0) << ","
+<< query->bounds.getLow(1) << ","
+<< query->bounds.getHigh(0) << ","
+<< query->bounds.getHigh(1) << ")), -- Extent\n"
+" 0.5, -- Tolerance for point cloud\n"
+" "<<nDimension<<", -- Total number of dimensions\n"
+" null);\n"
+" -- Insert the Point Cloud object into the \"base\" table.\n"
+" insert into hobu values (pc);\n"
+"end;\n";
+ oss.str("");
+ return true;
void usage() {}
int main(int argc, char* argv[])
std::string input;
- std::string output;
+ std::string connection;
+ std::string username;
+ std::string password;
+ std::string instance;
+ std::string block_table_name;
+ std::string point_cloud_name("CLOUD");
bool bDropTable = false;
liblas::uint32_t nCapacity = 10000;
double dFillFactor = 1.0;
@@ -441,11 +515,21 @@
i++;
srid=atoi(argv[i]);
+ else if ( strcmp(argv[i],"--cloud-column-name") == 0 ||
+ strcmp(argv[i],"-cn") == 0
+ i++;
+ point_cloud_name = std::string(argv[i]);
else if (input.empty())
input = std::string(argv[i]);
+ else if (connection.empty())
+ connection = std::string(argv[i]);
else
usage();
@@ -509,6 +593,15 @@
CreateSDOEntry(con, table_name.c_str(), query, srid );
CreateBlockIndex(con, table_name.c_str());
+ CreatePCEntry( con,
+ query,
+ table_name.c_str(),
+ "HOBU",
+ "CLOUD",
+ 3, // we're assuming 3d for now
+ srid,
+ nCapacity);
// Cleanup(con, "base");
// int iCol = 0;
More information about the Liblas-commits
