[Liblas-commits] r1308 - trunk/apps
liblas-commits at liblas.org
Thu Jul 9 13:51:35 EDT 2009
Author: hobu
Date: Thu Jul 9 13:51:33 2009
New Revision: 1308
URL: http://liblas.org/changeset/1308
fix up our blob writing
trunk/apps/las2oci.cpp
Modified: trunk/apps/las2oci.cpp
--- trunk/apps/las2oci.cpp (original)
+++ trunk/apps/las2oci.cpp Thu Jul 9 13:51:33 2009
@@ -176,11 +176,9 @@
bool GetPointData(LASPoint const& p, bool bTime, std::vector<liblas::uint8_t>& point_data)
// This function returns an array of bytes describing the
- // x,y,z and optionally time values for the point. The caller owns
- // the array.
- std::vector<liblas::uint8_t>* data = new std::vector<liblas::uint8_t>;
- point_data.resize(24);
- if (bTime) point_data.resize(data->size()+8); // Add the time bytes too
+ // x,y,z and optionally time values for the point.
+ point_data.clear();
double x = p.GetX();
double y = p.GetY();
@@ -195,53 +193,56 @@
// doubles are 8 bytes long. For each double, push back the
// byte. We do this for all four values (x,y,z,t)
- for (int i=0; i<8; i++) {
+ // // little-endian
+ // for (int i=0; i<sizeof(double); i++) {
+ // point_data.push_back(y_b[i]);
+ // big-endian
+ for (int i = sizeof(double) - 1; i >= 0; i--) {
point_data.push_back(x_b[i]);
point_data.push_back(z_b[i]);
if (bTime)
point_data.push_back(t_b[i]);
- return data;
+ return true;
std::vector<liblas::uint8_t>* GetResultData(const LASQueryResult& result, LASReader* reader, int nDimension)
list<SpatialIndex::id_type> const& ids = result.GetIDs();
- // calculate the vector size
- // d 8-byte IEEE doubles, where d is the PC_TOT_DIMENSIONS value
+ // d 8-byte IEEE big-endian doubles, where d is the PC_TOT_DIMENSIONS value
// 4-byte big-endian integer for the BLK_ID value
// 4-byte big-endian integer for the PT_ID value
bool bTime = false;
- liblas::uint32_t record_size;
- if (nDimension == 3)
- record_size = ids.size() * (8*3+4+4);
- else if (nDimension == 4)
+ if (nDimension == 4)
- record_size = ids.size() * (8*4+4+4);
bTime = true;
- else
- // throw a big error
- throw std::runtime_error("Dimension must be 3 or 4");
vector<liblas::uint8_t>* output = new vector<liblas::uint8_t>;
- output->resize(record_size);
list<SpatialIndex::id_type>::const_iterator i;
vector<liblas::uint8_t>::iterator pi;
liblas::uint32_t block_id = result.GetID();
std::vector<liblas::uint8_t> point_data;
@@ -253,29 +254,32 @@
bool doRead = reader->ReadPointAt(id);
if (doRead) {
LASPoint const& p = reader->GetPoint();
bool gotdata = GetPointData(p, bTime, point_data);
std::vector<liblas::uint8_t>::const_iterator d;
for (d = point_data.begin(); d!=point_data.end(); d++) {
output->push_back(*d);
- // pi = std::copy(point_data->begin(), point_data->end(), pi);
liblas::uint8_t* id_b = reinterpret_cast<liblas::uint8_t*>(&id);
liblas::uint8_t* block_b = reinterpret_cast<liblas::uint8_t*>(&block_id);
- // add 4-byte big endian integers
- output->push_back(id_b[3]);
- output->push_back(id_b[2]);
- output->push_back(id_b[1]);
- output->push_back(id_b[0]);
+ // 4-byte big-endian integer for the BLK_ID value
+ for (int i = sizeof(liblas::uint32_t) - 1; i >= 0; i--) {
+ output->push_back(block_b[i]);
+ // 4-byte big-endian integer for the PT_ID value
+ output->push_back(id_b[i]);
- output->push_back(block_b[3]);
- output->push_back(block_b[2]);
- output->push_back(block_b[1]);
- output->push_back(block_b[0]);
return output;
@@ -311,7 +315,6 @@
// we only expect one blob to come back
OCILobLocator** locator =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
statement = connection->CreateStatement(oss.str().c_str());
statement->Define( locator, 1 ); // fetch one blob
@@ -332,30 +335,30 @@
- liblas::uint32_t num_bytes = 0;
std::vector<liblas::uint8_t>* data = GetResultData(result, reader, 3);
- std::cout << "Data size: " << data->size() << std::endl;
- // liblas::uint8_t *bytes = (liblas::uint8_t*) new liblas::uint8_t[data->size()];
- // memcpy( (void*)&(bytes[0]), (void*)data[0], data->size() );
- // liblas::uint8_t *bytes;
- int anumber = data->size();
- // liblas::uint8_t *bytes2 = (liblas::uint8_t*) new liblas::uint8_t[data.size()];
- // memset( bytes2, 0, data.size());
-// int nBytesRead = statement->ReadBlob( locator[0],
-// (void*)data,
-// anumber );
-// this could be writing junk
-liblas::uint32_t num_bytes_written = statement->WriteBlob( locator[0],
- data,
- anumber );
+ liblas::uint8_t *bytes = (liblas::uint8_t*) new liblas::uint8_t[data->size()];
+ std::vector<liblas::uint8_t>::const_iterator f;
+ int j = 0;
+ for (f=data->begin(); f!=data->end(); f++) {
+ bytes[j] = *f;
+ j++;
+ liblas::uint32_t wroteblob = statement->WriteBlob( locator[0],
+ bytes,
+ data->size());
+ if (! wroteblob) throw std::runtime_error("No blob bytes could be written!");
+//select dbms_lob.getlength(points) from TO_core_last_clip
+ OWStatement::Free(locator, 1);
delete statement;
- // OWStatement::Free(locator, 1);
- // exit(0);
+ delete bytes;
+ delete data;
return true;
@@ -453,6 +456,7 @@
void usage() {}
+// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 8307) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
int main(int argc, char* argv[])
@@ -549,6 +553,19 @@
password = connection.substr(slash_pos+1, at_pos-slash_pos-1);
instance = connection.substr(at_pos+1);
std::cout << "Connecting with username: " << username << " password: "<< password<< " instance: " << instance << std::endl;
+ // OCI_SUCCESS_WITH_INFO error, which according to google relates to
+ // a warning related to expired or expiring passwords needs to be
+ // handled in the oracle wrapper.
+ // Create the index before connecting to Oracle. That way we don't heartbeat
+ // the server while we're cruising through the file(s).
+ // OS X RAMDISK configuration
+ // http://www.macosxhints.com/article.php?story=20090222092827145
+ // Obj_id is serial for each row in the block table
+ // blk_id is the index leaf node id (this is currently being written incorrectly)
OWConnection* con = new OWConnection(username.c_str(),password.c_str(),instance.c_str());
if (con->Succeeded()) {
std::cout <<"Oracle connection succeded" << std::endl;
@@ -570,7 +587,10 @@
// change filename foo.las -> foo for an appropriate
- // tablename for oracle
+ // block tablename for oracle... must be less than 30 characters
+ // and no extraneous characters.
+ // We need an option for the user to specify the blk tablename
string::size_type dot_pos = input.find_first_of(".");
string table_name = input.substr(0,dot_pos);
More information about the Liblas-commits
