[Liblas-commits] r1319 - branches/1.2/apps
liblas-commits at liblas.org
Mon Jul 27 13:12:49 EDT 2009
Author: hobu
Date: Mon Jul 27 13:12:49 2009
New Revision: 1319
URL: http://liblas.org/changeset/1319
fix #144 so unnamed arguments are so position sensitive
branches/1.2/apps/las2las.c
branches/1.2/apps/las2txt.c
branches/1.2/apps/lasinfo.c
branches/1.2/apps/txt2las.c
Modified: branches/1.2/apps/las2las.c
--- branches/1.2/apps/las2las.c (original)
+++ branches/1.2/apps/las2las.c Mon Jul 27 13:12:49 2009
@@ -273,15 +273,11 @@
remove_extra_header = TRUE;
- else if (i == argc - 2 && file_name_in == NULL && file_name_out == NULL)
+ else if (file_name_in == NULL && file_name_out == NULL)
file_name_in = argv[i];
- else if (i == argc - 1 && file_name_in == NULL && file_name_out == NULL)
- file_name_in = argv[i];
- else if (i == argc - 1 && file_name_in != NULL && file_name_out == NULL)
+ else if (file_name_in != NULL && file_name_out == NULL)
file_name_out = argv[i];
Modified: branches/1.2/apps/las2txt.c
--- branches/1.2/apps/las2txt.c (original)
+++ branches/1.2/apps/las2txt.c Mon Jul 27 13:12:49 2009
@@ -266,15 +266,11 @@
i++;
- else if (i == argc - 2 && file_name_in == 0 && file_name_out == 0)
+ else if (file_name_in == 0 && file_name_out == 0)
- else if (i == argc - 1 && file_name_in == 0 && file_name_out == 0)
- else if (i == argc - 1 && file_name_in && file_name_out == 0)
+ else if (file_name_in && file_name_out == 0)
Modified: branches/1.2/apps/lasinfo.c
--- branches/1.2/apps/lasinfo.c (original)
+++ branches/1.2/apps/lasinfo.c Mon Jul 27 13:12:49 2009
@@ -204,7 +204,7 @@
skip_vlr = TRUE;
- else if (i == argc - 1 && file_name == NULL)
+ else if (file_name == NULL)
file_name = argv[i];
Modified: branches/1.2/apps/txt2las.c
--- branches/1.2/apps/txt2las.c (original)
+++ branches/1.2/apps/txt2las.c Mon Jul 27 13:12:49 2009
@@ -512,22 +512,13 @@
i++;
file_creation_year = (unsigned short)atoi(argv[i]);
- else if ( i == argc - 2
- && file_name_in == NULL &&
+ else if ( file_name_in == NULL &&
- else if ( i == argc - 1 &&
- file_name_in == NULL &&
- file_name_out == NULL
- file_name_in &&
+ else if ( file_name_in &&
More information about the Liblas-commits
