[Liblas-commits] r1327 - in branches/1.2: include/liblas
include/liblas/capi include/liblas/detail python/liblas
python/tests src src/detail
liblas-commits at liblas.org
Wed Jul 29 17:22:36 EDT 2009
Author: hobu
Date: Wed Jul 29 17:22:33 2009
New Revision: 1327
URL: http://liblas.org/changeset/1327
Fix for #136
branches/1.2/include/liblas/capi/liblas.h
branches/1.2/include/liblas/detail/reader.hpp
branches/1.2/include/liblas/detail/writer.hpp
branches/1.2/include/liblas/lasheader.hpp
branches/1.2/python/liblas/core.py
branches/1.2/python/liblas/header.py
branches/1.2/python/tests/File.txt
branches/1.2/python/tests/Header.txt
branches/1.2/python/tests/VLR.txt
branches/1.2/src/detail/reader.cpp
branches/1.2/src/detail/reader10.cpp
branches/1.2/src/detail/reader11.cpp
branches/1.2/src/detail/reader12.cpp
branches/1.2/src/detail/writer.cpp
branches/1.2/src/detail/writer10.cpp
branches/1.2/src/detail/writer11.cpp
branches/1.2/src/detail/writer12.cpp
branches/1.2/src/las_c_api.cpp
branches/1.2/src/lasheader.cpp
branches/1.2/src/lasreader.cpp
Modified: branches/1.2/include/liblas/capi/liblas.h
--- branches/1.2/include/liblas/capi/liblas.h (original)
+++ branches/1.2/include/liblas/capi/liblas.h Wed Jul 29 17:22:33 2009
@@ -640,6 +640,14 @@
LAS_DLL uint32_t LASHeader_GetDataOffset(const LASHeaderH hHeader);
+/** Sets the location in number of bytes to start writing point data. Any
+ * space between the end of the LASVLRHs and this value will be written with 0's.
+ * @param hHeader LASHeaderH instance
+ * @param value the long integer to set for byte location determining the end of the header
+ * @return LASError enum
+ LAS_DLL LASError LASHeader_SetDataOffset(const LASHeaderH hHeader, uint32_t value);
/** Returns the number of variable length records in the header
* @return the number of variable length records in the header
Modified: branches/1.2/include/liblas/detail/reader.hpp
--- branches/1.2/include/liblas/detail/reader.hpp (original)
+++ branches/1.2/include/liblas/detail/reader.hpp Wed Jul 29 17:22:33 2009
@@ -74,21 +74,17 @@
bool ReadGeoreference(LASHeader& header);
void Reset(LASHeader const& header);
void SetSRS(const LASSpatialReference& srs);
- void SkipPointDataSignature();
protected:
std::istream& m_ifs;
- std::streamoff m_offset;
uint32_t m_size;
uint32_t m_current;
- uint32_t m_recordlength;
LASSpatialReference m_out_srs;
LASSpatialReference m_in_srs;
OGRCoordinateTransformationH m_transform;
OGRSpatialReferenceH m_in_ref;
OGRSpatialReferenceH m_out_ref;
- bool m_has_pad_bytes;
void FillPoint(PointRecord& record, LASPoint& point);
void Project(LASPoint& point);
Modified: branches/1.2/include/liblas/detail/writer.hpp
--- branches/1.2/include/liblas/detail/writer.hpp (original)
+++ branches/1.2/include/liblas/detail/writer.hpp Wed Jul 29 17:22:33 2009
@@ -67,7 +67,7 @@
virtual void UpdateHeader(LASHeader const& header) = 0;
virtual void WritePointRecord(LASPoint const& point, const LASHeader& header) = 0;
std::ostream& GetStream() const;
- void WriteVLR(LASHeader const& header);
+ uint32_t WriteVLR(LASHeader const& header);
Modified: branches/1.2/include/liblas/lasheader.hpp
--- branches/1.2/include/liblas/lasheader.hpp (original)
+++ branches/1.2/include/liblas/lasheader.hpp Wed Jul 29 17:22:33 2009
@@ -330,7 +330,7 @@
/// Set the georeference
void SetSRS(LASSpatialReference& srs);
private:
typedef detail::Point<double> PointScales;
Modified: branches/1.2/python/liblas/core.py
--- branches/1.2/python/liblas/core.py (original)
+++ branches/1.2/python/liblas/core.py Wed Jul 29 17:22:33 2009
@@ -358,6 +358,10 @@
las.LASHeader_GetDataOffset.argtypes = [ctypes.c_void_p]
las.LASHeader_GetDataOffset.errcheck = check_value
+las.LASHeader_SetDataOffset.restype = ctypes.c_int
+las.LASHeader_SetDataOffset.argtypes = [ctypes.c_void_p, ctypes.c_int]
+las.LASHeader_SetDataOffset.errcheck = check_return
las.LASHeader_GetRecordsCount.restype = ctypes.c_ulong
las.LASHeader_GetRecordsCount.argtypes = [ctypes.c_void_p]
las.LASHeader_GetRecordsCount.errcheck = check_value
Modified: branches/1.2/python/liblas/header.py
--- branches/1.2/python/liblas/header.py (original)
+++ branches/1.2/python/liblas/header.py Wed Jul 29 17:22:33 2009
@@ -187,7 +187,13 @@
def get_dataoffset(self):
"""Returns the location in bytes of where the data block of the LAS file starts"""
return core.las.LASHeader_GetDataOffset(self.handle)
- data_offset = property(get_dataoffset)
+ def set_dataoffset(self, value):
+ """Sets the data offset
+ Any space between this value and the end of the VLRs will be written with 0's
+ return core.las.LASHeader_SetDataOffset(self.handle, value)
+ data_offset = property(get_dataoffset, set_dataoffset)
def get_recordscount(self):
"""Returns the number of user-defined header records in the header.
@@ -205,7 +211,7 @@
def set_dataformatid(self, value):
"""Sets the point format value
- It can only be 1 (for 1.1 compatible) or 0 (for 1.0 compatible).
+ It can be 3, 2, 1, or 0.
if value not in [3, 2,1,0]:
raise core.LASException("Format ID must be 3, 2, 1, or 0")
Modified: branches/1.2/python/tests/File.txt
--- branches/1.2/python/tests/File.txt (original)
+++ branches/1.2/python/tests/File.txt Wed Jul 29 17:22:33 2009
@@ -101,10 +101,103 @@
>>> cnt
16
+ >>> buffered_header = f.header
+ >>> del f
+ >>> buffered_header.data_offset = 1024
+ >>> f3 = file.File('junk2.las',mode='w',header=buffered_header)
+ >>> f3.header.data_offset
+ 1024L
+ >>> for i in points:
+ ... f3.write(i)
+ >>> f3.close()
+ >>> del f3
+The header's offset will change +=2 because of the 1.0
+requirement to write pad bytes at the end of the header
- >>> f.close()
+ >>> f = file.File('junk2.las')
+ >>> f.header.data_offset
+ 1026L
+ >>> points = []
+ >>> for i in f:
+ ... points.append(i)
+ ... print i # doctest: +ELLIPSIS
+ <liblas.point.Point object at ...>
+ >>> for g in points:
+ ... print int(g.x), int(g.y)
+ 630262 4834500
+ 630282 4834500
+ 630300 4834500
+ 630346 4834500
+ 630327 4834500
+ 630323 4834500
+ 630320 4834500
+ 630280 4834500
+Now try writing a 1.2 version of the junk2.las file above to ensure that
+the data_offset *doesn't* change at all
+ >>> buffered_header.minor_version = 2
+ >>> f3 = file.File('junk3.las',mode='w',header=buffered_header)
+ 1024L
+ ... f3.write(i)
+ >>> f3.close()
+ >>> del f3
+ >>> f = file.File('junk3.las')
+ 1024L
+ >>> points = []
+ >>> for i in f:
+ 630262 4834500
+ 630282 4834500
+ 630300 4834500
+ 630346 4834500
+ 630327 4834500
+ 630323 4834500
+ 630320 4834500
+ 630280 4834500
>>> import os
>>> os.remove('junk.las')
+ >>> os.remove('junk2.las')
+ >>> os.remove('junk3.las')
>>> f = file.File('junk.las', mode="w", header=header)
>>> import liblas.core
@@ -117,7 +210,7 @@
LASException: LASError in "LASWriter_Destroy": Pointer 'hWriter' is NULL in 'LASWriter_Destroy'.
-# >>> f = file.File('junk.las2')
-# Traceback (most recent call last):
-# LASException: LASError in "LASReader_Create": can not open file /Users/hobu/svn/liblas/trunk/python/junk.las2
+ >>> import os
+ >>> os.remove('junk.las')
Modified: branches/1.2/python/tests/Header.txt
--- branches/1.2/python/tests/Header.txt (original)
+++ branches/1.2/python/tests/Header.txt Wed Jul 29 17:22:33 2009
@@ -108,4 +108,11 @@
>>> test_srs()
True
+ >>> h.data_offset
+ 227L
+ >>> h.data_offset = 742
+ >>> h.data_offset
+ 742L
Modified: branches/1.2/python/tests/VLR.txt
--- branches/1.2/python/tests/VLR.txt (original)
+++ branches/1.2/python/tests/VLR.txt Wed Jul 29 17:22:33 2009
@@ -99,3 +99,19 @@
>>> del f
+ >>> f = file.File('../test/data/srs.las')
+ >>> h = f.header
+ >>> f2 = file.File('junk_srs.las',mode='w',header=h)
+ >>> for p in f:
+ ... f2.write(p)
+ >>> f2.close()
+ >>> del f2
+ >>> f3 = file.File('junk_srs.las')
+ >>> f3.header.records_count
+ 3L
+ 761L
+ >>> import os
+ >>> os.remove('junk_srs.las')
\ No newline at end of file
Modified: branches/1.2/src/detail/reader.cpp
--- branches/1.2/src/detail/reader.cpp (original)
+++ branches/1.2/src/detail/reader.cpp Wed Jul 29 17:22:33 2009
@@ -68,9 +68,8 @@
namespace liblas { namespace detail {
Reader::Reader(std::istream& ifs) :
- m_ifs(ifs), m_offset(0), m_size(0), m_current(0),
- m_recordlength(0), m_transform(0),
- m_in_ref(0), m_out_ref(0)
+ m_ifs(ifs), m_size(0), m_current(0),
+ m_transform(0), m_in_ref(0), m_out_ref(0)
@@ -178,9 +177,7 @@
// Reset sizes and set internal cursor to the beginning of file.
m_current = 0;
- m_offset = header.GetDataOffset();
m_size = header.GetPointRecordsCount();
- m_recordlength = header.GetDataRecordLength();
void Reader::SetSRS(const LASSpatialReference& srs)
@@ -275,34 +272,6 @@
throw std::runtime_error("LAS file of unknown version");
-void Reader::SkipPointDataSignature()
- uint8_t const sgn1 = 0xCC;
- uint8_t const sgn2 = 0xDD;
- uint8_t pad1 = 0x0;
- uint8_t pad2 = 0x0;
- detail::read_n(pad1, m_ifs, sizeof(uint8_t));
- detail::read_n(pad2, m_ifs, sizeof(uint8_t));
- LIBLAS_SWAP_BYTES(pad1);
- LIBLAS_SWAP_BYTES(pad2);
- // FIXME: we have to worry about swapping issues
- // but some people write the pad bytes backwards
- // anyway. Let's check both ways.
- bool found = false;
- if (sgn1 == pad2 && sgn2 == pad1) found = true;
- if (sgn1 == pad1 && sgn2 == pad2) found = true;
- if (!found)
- // If the two bytes we read weren't signature bytes
- // we'll throw an exception. Depending on the version
- // we may want ot throw an error to the user or
- // silently continue on.
- throw std::domain_error("point data signature (1.0's 0xCC and 0xDD padding) not found");
void ReaderFactory::Destroy(Reader* p)
Modified: branches/1.2/src/detail/reader10.cpp
--- branches/1.2/src/detail/reader10.cpp (original)
+++ branches/1.2/src/detail/reader10.cpp Wed Jul 29 17:22:33 2009
@@ -207,24 +207,8 @@
header.SetMax(x1, y1, z1);
header.SetMin(x2, y2, z2);
- // The 1.0 version *requires* the pad bytes, but in
- // many instances, there are files without them. What
- // a fucking mess -- hobu.
- try {
- SkipPointDataSignature();
- m_has_pad_bytes = true;
- catch (std::domain_error const& e)
- // TODO: We'll want to put this error on the validation errors stack
- // but for now, we'll just move back to the offset
Reset(header);
return true;
@@ -242,20 +226,7 @@
if (0 == m_current)
m_ifs.clear();
- m_ifs.seekg(m_offset, std::ios::beg);
- try {
+ m_ifs.seekg(header.GetDataOffset(), std::ios::beg);
if (m_current < m_size)
@@ -295,8 +266,8 @@
if (m_size <= n)
return false;
- std::streamsize pos = (static_cast<std::streamsize>(n) * m_recordlength) + m_offset;
+ std::streamsize pos = (static_cast<std::streamsize>(n) * header.GetDataRecordLength()) + header.GetDataOffset();
m_ifs.clear();
m_ifs.seekg(pos, std::ios::beg);
detail::read_n(record, m_ifs, sizeof(record));
Modified: branches/1.2/src/detail/reader11.cpp
--- branches/1.2/src/detail/reader11.cpp (original)
+++ branches/1.2/src/detail/reader11.cpp Wed Jul 29 17:22:33 2009
@@ -212,20 +212,9 @@
- try {
- // If this call succeeds, we'll want to put this on the
- // validation errors stack. 1.1 files shouldn't have
- // pad bytes.
Reset(header);
return true;
@@ -242,18 +231,7 @@
if (0 == m_current)
m_ifs.clear();
- try {
- // pad bytes.
@@ -296,10 +274,8 @@
if (m_size <= n)
return false;
- if (m_has_pad_bytes) pos += 2;
m_ifs.clear();
Modified: branches/1.2/src/detail/reader12.cpp
--- branches/1.2/src/detail/reader12.cpp (original)
+++ branches/1.2/src/detail/reader12.cpp Wed Jul 29 17:22:33 2009
@@ -218,17 +218,6 @@
- try {
- // validation errors stack. 1.2 files shouldn't have
- // pad bytes.
Reset(header);
@@ -253,18 +242,7 @@
if (0 == m_current)
m_ifs.clear();
- try {
- // pad bytes.
@@ -337,9 +315,7 @@
return false;
m_ifs.clear();
Modified: branches/1.2/src/detail/writer.cpp
--- branches/1.2/src/detail/writer.cpp (original)
+++ branches/1.2/src/detail/writer.cpp Wed Jul 29 17:22:33 2009
@@ -101,10 +101,31 @@
record.point_source_id = point.GetPointSourceID();
-void Writer::WriteVLR(LASHeader const& header)
+uint32_t Writer::WriteVLR(LASHeader const& header)
+ // If this function returns a value, it is the size that the header's
+ // data offset must be increased by in order for the VLRs to fit in
+ // the header.
m_ofs.seekp(header.GetHeaderSize(), std::ios::beg);
+ // if the VLRs won't fit because the data offset is too
+ // small, we need to throw an error.
+ uint32_t vlr_total_size = 0;
+ // Calculate a new data offset size
+ for (uint32_t i = 0; i < header.GetRecordsCount(); ++i)
+ LASVariableRecord vlr = header.GetVLR(i);
+ vlr_total_size += vlr.GetTotalSize();
+ int32_t difference = header.GetDataOffset() - (vlr_total_size + header.GetHeaderSize());
+ if (difference < 0)
+ return difference;
@@ -118,6 +139,14 @@
std::streamsize const size = static_cast<std::streamsize>(data.size());
detail::write_n(m_ofs, data.front(), size);
+ // if we had more room than we need for the VLRs, we need to pad that with
+ // 0's. We must also not forget to add the 1.0 pad bytes to the end of this
+ // but the impl should be the one doing that, not us.
+ if (difference > 0) {
+ detail::write_n(m_ofs, "\0", difference);
+ return 0;
Modified: branches/1.2/src/detail/writer10.cpp
--- branches/1.2/src/detail/writer10.cpp (original)
+++ branches/1.2/src/detail/writer10.cpp Wed Jul 29 17:22:33 2009
@@ -150,7 +150,12 @@
detail::write_n(m_ofs, n2, sizeof(n2));
// 14. Offset to data
- n4 = header.GetDataOffset();
+ // Because we are 1.0, we must also add pad bytes to the end of the
+ // header. This means resetting the dataoffset +=2, but we
+ // don't want to change the header's actual offset until after we
+ // write the VLRs or else we'll be off by 2 when we write the pad
+ // bytes
+ n4 = header.GetDataOffset() + 2;
detail::write_n(m_ofs, n4, sizeof(n4));
// 15. Number of variable length records
@@ -201,14 +206,28 @@
detail::write_n(m_ofs, header.GetMaxZ(), sizeof(double));
detail::write_n(m_ofs, header.GetMinZ(), sizeof(double));
- WriteVLR(header);
+ // If WriteVLR returns a value, it is because the header's
+ // offset is not large enough to contain the VLRs. The value
+ // it returns is the number of bytes we must increase the header
+ // by in order for it to contain the VLRs.
+ int32_t difference = WriteVLR(header);
+ if (difference < 0) {
+ header.SetDataOffset(header.GetDataOffset() + difference );
+ WriteVLR(header);
+ // Write the pad bytes.
detail::write_n(m_ofs, sgn1, sizeof(uint8_t));
detail::write_n(m_ofs, sgn2, sizeof(uint8_t));
+ // We can now reset the header's offset to +=2. If we monkeypatched
+ // the offset because we were too small to write the VLRs, this will
+ // end up being header.GetDataOffset() + difference + 2 (see above).
+ header.SetDataOffset(header.GetDataOffset() + 2);
// If we already have points, we're going to put it at the end of the file.
// If we don't have any points, we're going to leave it where it is.
if (m_pointCount != 0)
Modified: branches/1.2/src/detail/writer11.cpp
--- branches/1.2/src/detail/writer11.cpp (original)
+++ branches/1.2/src/detail/writer11.cpp Wed Jul 29 17:22:33 2009
@@ -208,7 +208,15 @@
- WriteVLR(header);
+ if (difference != 0) {
+ header.SetDataOffset(header.GetDataOffset() + difference);
+ WriteVLR(header);
Modified: branches/1.2/src/detail/writer12.cpp
--- branches/1.2/src/detail/writer12.cpp (original)
+++ branches/1.2/src/detail/writer12.cpp Wed Jul 29 17:22:33 2009
@@ -210,7 +210,15 @@
- WriteVLR(header);
+ WriteVLR(header);
Modified: branches/1.2/src/las_c_api.cpp
--- branches/1.2/src/las_c_api.cpp (original)
+++ branches/1.2/src/las_c_api.cpp Wed Jul 29 17:22:33 2009
@@ -883,7 +883,19 @@
return value;
+LAS_DLL LASErrorEnum LASHeader_SetDataOffset(const LASHeaderH hHeader, liblas::uint32_t value) {
+ VALIDATE_LAS_POINTER1(hHeader, "LASHeader_SetDataOffset", LE_Failure);
+ try {
+ ((LASHeader*) hHeader)->SetDataOffset(value);
+ } catch (std::exception const& e)
+ LASError_PushError(LE_Failure, e.what(), "LASHeader_SetDataOffset");
+ return LE_Failure;
+ return LE_None;
LAS_DLL liblas::uint32_t LASHeader_GetRecordsCount(const LASHeaderH hHeader) {
@@ -969,6 +981,7 @@
return LE_None;
LAS_DLL double LASHeader_GetScaleX(const LASHeaderH hHeader) {
VALIDATE_LAS_POINTER1(hHeader, "LASHeader_GetScaleX", 0.0);
Modified: branches/1.2/src/lasheader.cpp
--- branches/1.2/src/lasheader.cpp (original)
+++ branches/1.2/src/lasheader.cpp Wed Jul 29 17:22:33 2009
@@ -262,17 +262,6 @@
throw std::out_of_range("version minor out of range");
m_versionMinor = v;
- uint32_t size = 0;
- uint32_t const dataSignatureSize = 2;
- // Add the signature if we're a 1.0 file
- if (eVersionMinorMin == m_versionMinor) {
- size = dataSignatureSize;
- SetDataOffset(GetHeaderSize()+size);
std::string LASHeader::GetSystemId(bool pad /*= false*/) const
@@ -373,8 +362,9 @@
throw std::out_of_range("data offset out of range");
m_dataOffset = v;
uint32_t LASHeader::GetRecordsCount() const
@@ -552,31 +542,6 @@
void LASHeader::AddVLR(LASVariableRecord const& v)
m_vlrs.push_back(v);
- uint32_t end_size = 0;
- std::vector<LASVariableRecord>::const_iterator i;
- // Calculate a new data offset size
- for (i = m_vlrs.begin(); i != m_vlrs.end(); ++i)
- end_size += (*i).GetTotalSize();
- size = end_size + dataSignatureSize;
- } else {
- size = end_size;
- // We're assuming that the reader or writer has reset
- // the VLR count to 0 before adding them back with AddVLR
- // FIXME I think this is still broken - hobu
m_recordsCount += 1;
@@ -592,14 +557,9 @@
std::vector<LASVariableRecord>::iterator i = m_vlrs.begin() + index;
- // Deal with the dataoffset when deleting
- uint32_t size = (*i).GetTotalSize();
m_vlrs.erase(i);
m_recordsCount = static_cast<uint32_t>(m_vlrs.size());
- SetDataOffset(GetDataOffset() - size);
@@ -655,9 +615,6 @@
std::string const uid("LASF_Projection");
- uint32_t beg_size = 0;
std::vector<LASVariableRecord> vlrs = m_vlrs;
std::vector<LASVariableRecord>::iterator j;
@@ -665,7 +622,7 @@
LASVariableRecord record = *i;
- beg_size += (*i).GetTotalSize();
+ // beg_size += (*i).GetTotalSize();
std::string user = record.GetUserId(true);
if (uid == user.c_str())
@@ -715,27 +672,6 @@
// and update header information
m_vlrs = vlrs;
- else
- size = end_size;
void LASHeader::SetGeoreference()
@@ -763,6 +699,5 @@
m_srs = srs;
} // namespace liblas
Modified: branches/1.2/src/lasreader.cpp
--- branches/1.2/src/lasreader.cpp (original)
+++ branches/1.2/src/lasreader.cpp Wed Jul 29 17:22:33 2009
@@ -56,7 +56,6 @@
LASReader::LASReader(std::istream& ifs) :
m_pimpl(detail::ReaderFactory::Create(ifs))
- //MakePIMPL(ifs);
Init();
@@ -121,6 +120,7 @@
m_pimpl->ReadGeoreference(m_header);
m_pimpl->Reset(m_header);
std::istream& LASReader::GetStream() const
More information about the Liblas-commits
