[Liblas-commits] r1278 - in trunk: apps src
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jun 8 21:52:13 EDT 2009
Author: hobu
Date: Wed May 20 15:29:40 2009
New Revision: 1278
URL: http://liblas.org/changeset/1278
clean up some leaks
   trunk/apps/lasindex.cpp
   trunk/src/lasindex.cpp
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp	(original)
+++ trunk/apps/lasindex.cpp	Wed May 20 15:29:40 2009
@@ -119,6 +119,7 @@
     delete idxstrm;
     delete index;
     delete reader;
+    delete istrm;
     LASIndex* idx = new LASIndex(input);
@@ -142,77 +143,7 @@
+    if (ids != 0) delete ids;
+    if (idx != 0) delete idx;
-//     std::cout << "Vec length" << ids->size() << std::endl;
-//     delete idx;
-//     LASIndexDataStream* idstrm = new LASIndexDataStream(reader);
-//     LASIndex* index = new LASIndex("MEMORY");
-//     in
-//     //doing it in memory
-//     std::vector<liblas::uint32_t>* ids = 0;
-//     try{
-// //        ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
-// // _zoom
-// //        ids = idx->intersects(630355.0,4834609.0,630395.0,4834641.0,0.0,200.0);
-// // _clip
-// // 630346.830000,4834500.000000,55.260000
-//         ids = index->intersects(630262.300000,4834500.000000,630346.830000,4834500.000000,50.900000,55.260000);
-// //       ids = idx->intersects(630297.0,4834497.0,630302.0,4834501.0,0.0,200.0);
-//     } catch (Tools::Exception& e) {
-//         std::string s = e.what();
-//         std::cout << "error querying index value" << s <<std::endl; exit(1);
-    // LASPoint* p
-    // liblas::uint32_t num_points = reader->GetHeader().GetPointRecordsCount();
-    // for (int i =0; i < num_points ; i++) {
-    //     bool bInserted = index->insert(*p, i);
-    // reader->Index(input);
-    // LASHeader header = reader->GetHeader();
-    // std::cout << "number of points: " << header.GetPointRecordsCount() << std::endl;
-    // for (int i=0; i< header.GetPointRecordsCount(); i++) {
-    //     try{
-    //         bool read = reader->ReadPointAt(i);
-    //         LASPoint p = reader->GetPoint();
-    //     } catch (Tools::IllegalStateException& e) {
-    //         std::string s = e.what();
-    //         std::cout << "error creating index" << s <<std::endl; exit(1);
-    //     std::cout.precision(2);
-    //     std::cout.setf(std::ios_base::fixed);
-    //     // std::cout << "x: " << p.GetX() << " y: " << p.GetY() << std::endl;
-    // LASIndex* idx = reader->GetIndex();
-    // std::vector<liblas::uint32_t>* ids = 0;
-    // try{
-    //     ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
-    // } catch (Tools::IllegalArgumentException& e) {
-    //     std::cout << "error querying index value" << s <<std::endl; exit(1);
-    // std::cout << "Vec length" << ids->size() << std::endl;
-    // delete reader;
-    // delete istrm;
Modified: trunk/src/lasindex.cpp
--- trunk/src/lasindex.cpp	(original)
+++ trunk/src/lasindex.cpp	Wed May 20 15:29:40 2009
@@ -350,15 +350,19 @@
     std::vector<uint32_t>* vect = new std::vector<uint32_t>;
     LASVisitor* visitor = new LASVisitor(vect);
+    SpatialIndex::Region* region = new SpatialIndex::Region(min, max, 3);
     try {
-        m_rtree->intersectsWithQuery(SpatialIndex::Region(min, max, 3), *visitor);
+        m_rtree->intersectsWithQuery(*region, *visitor);
         std::ostringstream os;
         os << "Spatial Index Error: " << e.what();
+        delete region;
         delete visitor;
         throw std::runtime_error(os.str());
+    delete region;
     delete visitor;
     return vect;
More information about the Liblas-commits mailing list
